Old 02-03-2004, 11:55 AM   #1
pinoi007
pinoi007 is an unknown quantity at this point
s14 Recently purchased 95 240SX.. Got some questions
I purchased a 95 240SX with 125000 miles on it a few weeks ago. My cousin and I did a compression test on it and the numbers were 150-149-139-141 across. I know those are the minimum specs or lower and Im not burning any oil. We tested one hole with oil and concluded that it was the valve. I know I can't turbo this engine without a rebuild but I was wondering
1) how much to rebuild the entire engine and what parts are going/needing to be fixed so it will be strong enough for a turbo
2) Also, with the car being daily driven, how much life does it have left so i know what to expect in the future so I can prepare(save up) for it.
I have read that rebuilding the engine will cost as much as swapping a SR20. Correct me if I am wrong, but I read that KA-T will be more powerful than stock SR20DET but the SR20 has more potential?
Finally, as for now, there is a rattle in the middle muffler connected to the intermediate pipe when the engine is at around 2k RPM. I was wondering if there is something inside that can make the noise and if so, if it can be fixed w/out buying new/used parts.
Below is a pictorial view of the location of the exhaust problem:
Noise.
The brackets are the mufflers.
Please dont flame a NEWBIE. I have read alot before posting this. Any help/suggestions/opinions will be good. Thanks.
pinoi007 is offline   Reply With Quote
Old 02-03-2004, 11:57 AM   #2
pinoi007
Correction to picture:
==[ ]====[NOISE]=====[ ]=
Old 02-03-2004, 12:06 PM   #3
christopher
christopher's Avatar
christopher is an unknown quantity at this point
Well, yes you will make more power with a turbo KA than a stock SR.
As far as that noise goes, you could have a damaged catalytic converter. Loose parts rattle. Hard to say. I would take the exaust apart, its not hard. Just take a look.
I couldn't tell you about the cost for rebuilding the motor, it can vary.
Anyone from the Twin Cities?
http://www.heiruspecs.com/
[email protected]
89 coupe
Red top SR
Blown Stereo....
christopher is offline   Reply With Quote
Old 02-03-2004, 01:09 PM   #4
Sanchi
Macadamia Nut
Sanchi's Avatar
Sanchi is an unknown quantity at this point
YA the cost of rebuilding can vary depending on how much of it needs work. My friend and his dad did a partial rebild, and it cost around 1k. Thats them doing it them selves.
"Fear is the path to the Dark Side..., Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering…" -Yoda
Sanchi is offline   Reply With Quote
Old 02-03-2004, 01:22 PM   #5
pinoi007
Thanks for the reply. How long will the engine last, if maintenance is of utmost?
Old 02-03-2004, 03:37 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
rebuild it with aftermarkets and itll last. Biggest weakness of the KA is its pistons and rods.
CLICK HERE!!!
Old 02-03-2004, 04:26 PM   #7
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
drive it into the ground stock and then swap it...
if you go easy on it it'll prolly last a good bit longer..if you rage on it prepare to be swapping or rebuilding soon...
good luck..
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 02-03-2004, 05:10 PM   #8
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
yeah, and if you don't want or need to go sr, just swap in another KA. could end up being cheaper/easier than a rebuild.
s0ldats is offline   Reply With Quote
Old 02-03-2004, 06:28 PM   #9
pinoi007
How much is a full rebuild of the KA around? And how much do KA motors usually go for?
Old 02-03-2004, 09:02 PM   #10
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Motor = cheap. Rebuild to turbo spec = not. I spent juabout $5.5k on my motor. That was forged pistons, rods, bearings, oil pump, gasket set, Apexi exhaust, JWT cams, new valves, springs, rings, timing components, Serdi 3-angle valve job, port and polish, port matching, injectors, fuel pump, fuel rail, jwt ecu, FMIC (previous turbo setup lacked that), and maybe some other shit, check my site for specs.
-Jeff
Whatup?
Old 02-03-2004, 09:05 PM   #11
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
-Jeff
Not sure if your aware of it, or maybe its temperory, but your website is down
ca18guy is offline   Reply With Quote
Old 02-03-2004, 10:07 PM   #12
pinoi007
Thanks Jeff.
Old 02-03-2004, 10:25 PM   #13
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
good luck..
Heheh, I was thinking the same thing 2 years ago. I've been raggin on my 145k miles KA for the last 2 years and it still running like a champ, I haven't had a single problem since I bought the car 2 years ago.
WilloW is offline   Reply With Quote
Old 02-03-2004, 10:47 PM   #14
nokeone
on strike three.
nokeone's Avatar
mine was the same...190000+
Pink GodziRa
Old 02-04-2004, 12:40 AM   #15
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Lol.. Not sure if you're aware of it, I transfered it to a temporary server while I get my domain name out of hock. Bastard last person to register my domain failed to renew it or something.. took my money, and now unless I pay $23-ish, I can't get the name back. So I can either A) bitch and moan until I get a job (While telling myself it's the principle of "I PAID ALREADY!"), or B) Start a "Let's get Jeff's site out of hock" fund. It's at www.obsidian-hosting.com/240sxturbostyle or, you can just click the link, don't type in the straight 240sxturbostyle domain tho, it won't work..
-Jeff
Whatup?
Old 02-04-2004, 12:51 AM   #16
pruto
pruto's Avatar
pruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to allpruto is a name known to all
i love my KA, i've done some stupid shit with it and its like a rock. Not too much power, but awesome for daily driving. it should last you a while if it is stock. my KA is at 161k right now, i've personally put... oh, 35 on it in the last 2 and a half years.
enjoy your car.
Paul
Black and Red
pruto is offline   Reply With Quote
Old 02-04-2004, 02:32 AM   #17
Sanchi
Macadamia Nut
Sanchi's Avatar
ya i got about 130k on mine now the odo stoped acouple of k miles ago i think... well its still as stonge as ever since i got it a year and a half ago! lovein it!!
Old 02-04-2004, 02:34 AM   #18
pinoi007
To the people that have had their KA for a while.. What are ya'lls compression results when the car was bought and recent results?
Old 02-04-2004, 03:04 AM   #19
kandyflip445
kandyflip445's Avatar
Damn filipinos....LOL.(I'm one too) The rods aren't really that weak from factory they're actually pretty good. They've been seen to last under ~300hp daily driven conditions. The pistons are really not that good though. Weak ring lands on them. IIRC the s14a(i think it was 'a' correct me if I'm wrong) had stronger pistons, they were hypereutectic cast. They came in the later s14's, the ones with the "shark eyes"
My 240 vBgarage
Old 02-04-2004, 05:47 AM   #20
WilloW
WilloW's Avatar
I didn't care at the moment when I bought the car, too happy that the owner agreed to sell the car to me. I haven't got any time, and I still don't care to check the compression right now since it running fine..
Old 02-04-2004, 05:54 AM   #21
kandyflip445
Hey I didn't even see that. My compression results were around 160 psi at all four, pretty good really, esp. for a 91'.
My 240 vBgarage
Old 02-04-2004, 11:33 AM   #22
Jeff240sx
I hate you too...
Jeff240sx's Avatar
No, you're wrong. I'll correct you. All KA24DE's had the same pistons. '91-'98. Same part number, same strength, same piston.
-Jeff
Whatup?
Old 02-04-2004, 04:54 PM   #23
kandyflip445
Are you sure Jeff? I was sure that they had hypereutectic pistons on the late model s14's...oh well.
My 240 vBgarage
Old 02-04-2004, 06:00 PM   #24
Jeff240sx
I hate you too...
Jeff240sx's Avatar
LOL! Yea, I'm sure. I tried buying some pistons when I blew my motor, and asked.
-Jeff
Whatup?
Old 02-04-2004, 06:47 PM   #25
pinoi007
what is IIRC?
Old 02-04-2004, 08:10 PM   #26
Jeff240sx
I hate you too...
Jeff240sx's Avatar
what is IIRC?
If I remember correctly. There is a thread in the FAQ section for noobies to message boards to learn the abbreviations.
-Jeff
Whatup?
Old 02-04-2004, 08:52 PM   #27
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
i have around 175k on my 95, and i run it hard everyday with no problems, but im really good about my mantance, so if you want to drive it hard take care of it. my machinest is rebuilding my kade for 750 with a decked block intake port & exauest port & pollish with a port match and a little extra for a 5 angel valve job i think, but yeah with pistons and rods it will end up to be almost 2000. but at the same time if you buy an sr your probly not going to keep it stock and you should want a rebuild on it. so youl end up spending alot of money eather way so its really boils down to, what do you really want to do to your car?
driftyour40 is offline   Reply With Quote
