Old 03-09-2011, 09:55 PM   #1
awdfury
awdfury's Avatar
awdfury has a spectacular aura aboutawdfury has a spectacular aura aboutawdfury has a spectacular aura aboutawdfury has a spectacular aura aboutawdfury has a spectacular aura aboutawdfury has a spectacular aura about
Rebuild Won't Start. Please Help!!!
So here is the story:
I recently rebuilt the top half of my SR20DET with HKS 264 Cams, HKS adjustable cam gears. The intake manifold and head have been port, polished and flow matched. I changed the valve springs and retainers to Greddy Springs and Titanium Retainers. The valves had a vlave grind performed and after assembly the head was pressure tested before installing it on the block.
Now that everything is back together I cannot get the engine to start.
I have tested for spark and I know the engine is getting fuel. I was able to get one puff of flame out the exhaust but other then that I cannot get the engine to turn over.
Any Ideas?
Everything happens for a reason.
awdfury is offline   Reply With Quote
Old 03-09-2011, 10:18 PM   #2
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
your timing is off.
sr20sean is offline   Reply With Quote
Old 03-09-2011, 10:21 PM   #3
archaeic_bloke
archaeic_bloke's Avatar
archaeic_bloke is an unknown quantity at this point
yea, it's gotta be timing... do you have a timing light?
if not definitely run to what ever is closest and pick one up, they're so cheap and it'll save you from potentially destroying your brand new head!
The SkyLife Community & News Website: --> http://www.skylife4ever.com
archaeic_bloke is offline   Reply With Quote
Old 03-09-2011, 10:28 PM   #4
napz510
napz510's Avatar
Trader Rating: (36)
napz510 is an unknown quantity at this point
Feedback Score: 36 reviews
check your cam timing and your cas.......
napz510 is offline   Reply With Quote
Old 03-10-2011, 12:59 AM   #5
Andrew@9K
Andrew@9K's Avatar
Andrew@9K is an unknown quantity at this point
Timing forsure! I think I could shead some light on this. Sometimes if you get the cam timing wrong it sounds like its popping off back thru the intake. If its CAS timing it will have a hard or start but awkwardly.. hope this helps
Andrew@9K is offline   Reply With Quote
Old 03-10-2011, 08:07 PM   #6
awdfury
awdfury's Avatar
cas it was thanks for the help. Should of thought of that myself.
