Old 03-14-2011, 10:56 PM   #1
Sr20Bluebird
Sr20Bluebird's Avatar
Sr20Bluebird is an unknown quantity at this point
CA-WTB S13 Ka24de 5spd Swap Parts.
I need everything so far. Here's a list of what im looking for.
5 speed trans
5 speed trans crossmember
manual flywheel with bolts
manual engine backing plate
manual trans to engine bolts
clutch pedal
brake pedal
clutch line upper
clutch line lower
clutch dampner
clutch master
clutch slave
lower shift boot with plate
upper shift boot
Thanks
Sr20Bluebird is offline   Reply With Quote
Old 03-15-2011, 01:20 AM   #2
traded13b-4-240
traded13b-4-240's Avatar
traded13b-4-240 is an unknown quantity at this point
I got all this except the flywheel bolts. Shoot me a reasonable offer.
traded13b-4-240 is offline   Reply With Quote
Old 03-15-2011, 01:33 AM   #3
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
You dont need the clutch damper, its almost impossible bleeding the clutch with it still on
palmdale_mob is offline   Reply With Quote
Old 03-15-2011, 08:05 AM   #4
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
Prices are OBO and I might even have more stuff I need to check after work - I can get you good deal on S/H too.
- S14 96' 5 speed ECU - $100.00
- S14 5 speed brake pedal assembly - includes all sensors and connectors with pigtail to wire them in - $65.00
- S14 5 speed brake booster & master cylinder - $65.00
- S14 5 speed cross member - includes tranny mount - $65.00
- KA24DE used OEM clutch & flywheel (needs resurface) - comes with all mounting bolts - $55.00
- KA24DE 5 speed motor to tranny dust plate - $50.00
JDS Performance is offline   Reply With Quote
Old 03-15-2011, 08:11 AM   #5
jdmspooge
jdmspooge's Avatar
Trader Rating: (39)
jdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura about
Feedback Score: 39 reviews
I have the clutch and slave cylinders. Lmk asap!
jdmspooge is offline   Reply With Quote
Old 03-15-2011, 02:20 PM   #6
Sr20Bluebird
You have been txt.
I had heard that the damper is expendable didnt know it caused such a pain in the butt. Thanks
Im not sure but can you bolt the s14 parts to the s13?
Might be working out a deal with traded13b-4-240 so ill let you kno.
Old 03-15-2011, 02:24 PM   #7
sasmar929
sasmar929 is an unknown quantity at this point
i just did a 5 speed swap, and my auto dust plate thing worked fine. if you think about it, its in between the motor and flywheel, wont effect the clutch stuff at all
sasmar929 is offline   Reply With Quote
Old 04-16-2011, 12:00 AM   #8
Sr20Bluebird
Bump**
I have someone offering me all the parts for the swap but its been a month and still no parts. I wasn't in need for them in a hurry before but my car is to the point where Im waiting for them now. I still need everything so let me know what you have to offer. Thanks
Friends don't let friends drive stock...
