Old 03-16-2011, 09:34 PM   #1
Xxs13240xX
Xxs13240xX's Avatar
Xxs13240xX is an unknown quantity at this point
s14 Sr20 no start
So I bought a friends friends s14 brought it home yesterday everything was running smooth after we got the tires to not rub in the front
Anywho today I head out to school and on my way back it starts acting odd it would act like it just shut off the key and then i started it back up and it was fine then once more it stalled out just this time i couldn't get it to start back up the negative battery terminal connector was bad went and replaced that. Drove fine shut it off started it back up was perfect then last but not least I was on my way to work and the car shut off right in the intersection couldn't get it to start tried jump starting it then tried bump starting it nothing.
Symptons are now:
All dash lights will stay on even when key is out of ignition
Car's reverse lights work even when key is out of ignition
ECU relay buzzing at random times when I try starting it then it stays buzzing
Things I've tried:
I've 95% of the fuses under the dash and every fuse under the hood
I've checked the grounds even added a new one where I thought it could use one since the old one was going bad.
Swapped out relays from under hood to the ecu still nothing
I'm quite stumped on this right now basically everything is electronically stock besides the MINES TUNE ECU... Help me out I miss it already
Oh also this car was running perfectly fine for the time that he had it and then yesterday the ground terminal connector was bad so I replaced that and this is all that's its doing now
Complete car specs
PULSAR GTI-R T28 turbo with the S14 compressor housing swap
adjustable wastegate running 12 psi
megan dump pipe
megan downpipe test pipe combo
blitz 85mm exhaust
255 walbro fuel pump
front mount
greddy bov
fidanza aluminum flywheel
fidanza 4.3 clutch with 6 pad sprung disc
mmr tranny mount
4.4 gears with vlsd
aluminum alt and water pump pulley
big aluminum rad with dual 12 in fans
MINES TUNE ecu
NISMO fuel pressure regulator
Xxs13240xX is offline   Reply With Quote
Old 03-16-2011, 09:36 PM   #2
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
Bad battery.
I had a cool signature
holemilk00 is offline   Reply With Quote
Old 03-16-2011, 09:38 PM   #3
Xxs13240xX
Xxs13240xX's Avatar
Tested it and it was good I still had power to headlights and everything nothing would go dim if I added anymore electrical power usage
Old 03-16-2011, 09:39 PM   #4
holemilk00
holemilk00's Avatar
Trader Rating: (33)
Did you test it with a multimeter? Because the dash light thing sounds like the battery, how did you test it?
Old 03-16-2011, 09:45 PM   #5
statickx991
statickx991 is an unknown quantity at this point
try to get a load tester or take the battery to a shop and get them to test it. ive seen cars do what ur saying with a bad battery and alt.
im a f18 bro
statickx991 is offline   Reply With Quote
Old 03-17-2011, 01:39 AM   #6
skakemokid
skakemokid is an unknown quantity at this point
Did you ground out the harness? since you said the front was rubbing?
skakemokid is offline   Reply With Quote
Old 03-17-2011, 05:08 AM   #7
Xxs13240xX
Xxs13240xX's Avatar
Took it to advance auto parts and the front tires were rubbing from a bad offset
Old 03-17-2011, 06:49 AM   #8
ceniack
ceniack is an unknown quantity at this point
what he is wondering is if it rubbed though the harness in the driver side wheel well...
ceniack is offline   Reply With Quote
Old 03-17-2011, 06:56 AM   #9
Xxs13240xX
Xxs13240xX's Avatar
Oh no it was only rubbing the coilover from a bad offset on the rim itself
Old 03-17-2011, 07:04 AM   #10
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Related to the battery suggestions, but check your grounds. If you had a disconnected or corroded ground, it might give symptoms like a bad battery...
Good luck, keep us updated
Darren is offline   Reply With Quote
Old 03-17-2011, 07:17 AM   #11
Xxs13240xX
Xxs13240xX's Avatar
I thought that it might have been the battery terminal since it was cracked when I first got it so I replaced it and followed the ground to where it was grounding sanded it down to bare metal and put it back in also put a positive wire one on and nothing
Old 03-17-2011, 07:29 AM   #12
holemilk00
holemilk00's Avatar
Trader Rating: (33)
There are more grounds than just the one that comes off the negative battery terminal. Check out some of the online diagrams for the engine harness for them. If I wasn't running out the door right now I would find them and link you to them. Sorry I can't be of more help.
Old 03-17-2011, 07:35 AM   #13
Xxs13240xX
Xxs13240xX's Avatar
Alright I'll check them then go from there I'll keep you all posted thanks so far for the quick responses
Old 03-17-2011, 09:27 PM   #14
Xxs13240xX
Xxs13240xX's Avatar
Got it running it was the wires from under the left front fender but the lights on the gauge cluster still stay on as long as I unplug the negative terminal when I shut it off it'll be good unless you guys may have an option
no start, s14, sr20
