Old 04-04-2011, 10:19 AM   #1
240Holla
240Holla is an unknown quantity at this point
s13 Sr20 idling @ 2000 rpm
Just like the title says my Redtop idles @ 2k. I don't want to jus adjust iacv just in case my timing is off. So is there a way check or test to see if timing is the issue without a timIng light?
240Holla is offline   Reply With Quote
Old 04-04-2011, 10:24 AM   #2
rbsilvias14
rbsilvias14's Avatar
rbsilvias14 is an unknown quantity at this point
sure its not a boost leak??
spray some brake cleaner or starter fluid near all of your vacuum hoses and see if the idle goes up
rbsilvias14 is offline   Reply With Quote
Old 04-04-2011, 11:49 AM   #3
jholman
jholman's Avatar
jholman is an unknown quantity at this point
You will have to have a timing light at the minimum to check your timing...
jholman is offline   Reply With Quote
2000rpm, high idle, timing
