Old 03-27-2011, 05:11 PM   #1
blackoutt
blackoutt's Avatar
blackoutt is an unknown quantity at this point
FS/FT: 95 240sx built KA-T/version select/mb battles/k-sport
1.)1995 Nissan 240sx SE
- clean title in hand, 115K on chassis 1,500 on built motor
Power windows
Power locks
Power moon roof
5-lug hubs
Cruise control (all components still in car but does not work)
Engine
Motor built by HRT Performance in Durham, NC
HRT Performance
Standard KA24DE-T package plus CP pistons and ARP head studs
Parts hot tanked and cleaned
Block bored and honed .020" over
Block square decked with front cover
Block magnafluxed to check for cracks
New freeze plugs installed
Crankshaft polished
Rods resized with new ARP hardware
Rotating assembly computer spin-balanced
Head pressure tested for cracks
Head resurfaced with upper timing cover
High-performance 3 angle valve job
All clearances checked and blueprinted
Professionally assembled
Red painted block, valve cover, and transmission
Enthalpy ROM-tuned ECU and adapter harness
Apex'i AFC Neo fuel controller
Stage 3 clutch and lightweight flywheel
Turbo kit
-Top mount turbo manifold
-Oil line kit
-EMUSA T3/To4e turbo (comes with spare turbo also)
New style Turbosmart wastegate, dumped into downpipe 10psi
Knockoff ssqv BOV
FMIC and piping (retained front bumper support by channeling it)
New battery, relocated to trunk
300zxTT fuel filter
Oil catch can
Apex'i turbo timer
Manual boost controller
EGR blockoff
Sard 550cc injectors
Z32 MAF with adapter and filter
Walbro 255 fuel pump
Megan Racing adjustable fuel pressure regulator
3" stainless downpipe, midpipe w/flex, and apexi resonator/cut off catback with 4" tip.
Project Silvia motor mounts
Delrin transmission mount
Blackworks aluminum radiator
Silicone radiator hoses
All Vacuum lines replaced with new thick silicone
2-12" electric fans (needs new relay but manual switch works fine)
NGK BKR6E spark plugs
No A/C components left on car
New water pump
New power steering pump
New throttle position sensor
New distributor cap and rotor
New plug wires
Interior
Autometer boost gauge
AEM UEGO wideband AFR
Dual A-pillar gauge pod
JVC Stereo
Newer driver side window switch
Non SE door panels
S13 front and rear seats
No carpet, just rubber floor mats
Gutted trunk
"Crown Royal" shift boot
Silvia gauge cluster (higher redline shown matches tuned ecu, tach needle jumps but signal is good at ecu and AFC?)
Exterior
Version Select type 1 body kit
Fresh Gray exterior paint including door jambs
Black engine bay
Rolled fenders (no pull)
Tucked wire harness in drivers side fender for clearance
Shaved antenna
Smooth trunk
*Needs new windshield seal, it doesn't leak it just looks bad.
Chassis/Suspension
K-sport fully adjustable coilovers w/ front pillowball upper mounts, recently disassembled and cleaned.
Adjustable front tension rods
Adjustable rear upper control arms, traction links, and toe links
Front strut tower bar
MB Battle 17x9.5 +15 wheels in bronze
225/45/17 Rotalla tires, fronts like new, rears camber/toe worn.
Rear subframe collars
Welded s14 differential
Nismo axles
The bad
Tach on cluster jumps around as seen in the video, but the signal at the ecu and reading on the safc are good.
Relay for electric fans is bad but the manual switch on the dash works.
Waterspot in the clear on the hood, scratches on bottom of front bumper from old front license plate mount.
Windshield seal has been rtv'ed, seals fine, just doesn't look pretty.
New exhaust manifold installed but the car still runs rich so I checked the ecu and it throws a code 12 "airflow circuit" causing a safe/limp mode.
I don't have the time or desire to keep chasing down problems on this project anymore and need it gone out of my friends garage. First person that shows up with a trailer and my asking price in cash takes it. Located in Horseheads, NY.
Price
$6,500 as is bring your own wheels
$7,000 as is
*Compression test results added 4/20/11 by request. Perfect, I might add.
YouTube - Built KA-T cold start up walkaround
YouTube - Compression test Cylinder 1
YouTube - Compression test Cylinder 2
YouTube - Compression test Cylinder 3
YouTube - Compression test Cylinder 4
blackoutt is offline
Old 04-01-2011, 08:36 AM   #2
blackoutt
blackoutt's Avatar
Will be available Sunday to meet someone halfway on a road trip for either a trade or cash!
Will trade for 600cc or smaller sport/sport touring bike + cash, s2000, 350z, g35, audi TT, 4x4 diesel truck, or vip car. Can add some cash on my end also.
Old 04-06-2011, 01:26 PM   #3
MalasMan24
MalasMan24 is an unknown quantity at this point
trade for a built 5.0 mustang?
MalasMan24 is offline
Old 04-06-2011, 05:14 PM   #4
hopefull
hopefull's Avatar
hopefull is an unknown quantity at this point
whats up with your tac???
hopefull is offline
Old 04-06-2011, 06:17 PM   #5
brizzle3000
brizzle3000 is an unknown quantity at this point
SOLD TO ME IN 2WEEKENDS! haha seriously
brizzle3000 is offline
Old 04-06-2011, 08:50 PM   #6
Seabass
Seabass's Avatar
Seabass is an unknown quantity at this point
soo sick! wish i could have this thing
Seabass is offline
Old 04-06-2011, 09:53 PM   #7
Sr20SilviaS13
Sr20SilviaS13's Avatar
Sr20SilviaS13 is an unknown quantity at this point
sex on fucking wheels.
Sr20SilviaS13 is offline
Old 04-07-2011, 05:40 AM   #8
blackoutt
blackoutt's Avatar
Sale pending to brizzle as stated. Fell through.
Old 04-07-2011, 07:29 AM   #9
brizzle3000
OHH YEAHH! cant wait until i finally get free time so i can pick it up
Old 04-07-2011, 04:32 PM   #10
CGraves
CGraves's Avatar
CGraves is an unknown quantity at this point
god damn i want this
CGraves is offline
Old 04-07-2011, 04:43 PM   #11
blackoutt
blackoutt's Avatar
No links
Not a link to more pictures for your enjoyment, the last one is how low it sits now. Ready for the summer.
Forgot I can't have that here.
Old 04-08-2011, 09:18 PM   #12
speedracer5
speedracer5's Avatar
Trader Rating: (24)
speedracer5 is on the path to ruinspeedracer5 is on the path to ruin
Feedback Score: 24 reviews
nice really really nice
speedracer5 is offline
Old 04-10-2011, 10:51 AM   #13
limptod
limptod is an unknown quantity at this point
would you trade for a 88 c/k 1500 with a 5.7 motor it has 9inchs of lift 35inch tires trail master shocks it has a wench up front tucked under custom bumper and has more stuff if you wont to see pic let me know thanks for your time
limptod is offline
Old 04-17-2011, 04:44 PM   #14
blackoutt
blackoutt's Avatar
Not interested in a lifted truck sorry.
Still have the car up for sale after this weekend!
Old 04-17-2011, 06:05 PM   #15
brizzle3000
IM A SERIOUS BUYER!!!
This saturday was a MONSOOON so we couldnt make it up..
Me and my dad want to give you a NON REFUNDABLE 500 dollar deposit
to show you we really want the car...We told you to give us a call...
if you can get a title and meet us this monday or wednesday we would be more then happy to
meet up with you ANYTIME during the week.... we just cant leave the business we had here thats all ... we want to take this car from you asap
Old 04-17-2011, 06:09 PM   #16
brizzle3000
If not this weekend its a 1000% on saturday the 23rd since there wont be a tornado warming and torrential downpours like there as this saturday.. lol
Old 04-17-2011, 07:05 PM   #17
kyledunn
kyledunn is an unknown quantity at this point
brizzle is right i was in philly that night too. it was an epic storm
kyledunn is offline
Old 04-17-2011, 09:00 PM   #18
blackoutt
blackoutt's Avatar
Spoke to brizzle senior, the sale is again pending.
After meeting his requests he backed out. Looking for serious buyers.
Old 04-17-2011, 09:06 PM   #19
calikidder
calikidder is an unknown quantity at this point
want to trade for an sr86??
calikidder is offline
Old 04-17-2011, 09:34 PM   #20
trexm3
trexm3 is an unknown quantity at this point
i have cash pmed you
trexm3 is offline
Old 04-17-2011, 11:05 PM   #21
s14sport
s14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura abouts14sport has a spectacular aura about
this car is sick
JG's RB Silvia 2009
s14sport is offline
Old 04-20-2011, 08:51 PM   #22
blackoutt
blackoutt's Avatar
Added compression test videos to the original post to prove the motor itself is perfect for a 9.0:1 built motor.
Old 05-05-2011, 12:15 PM   #23
blackoutt
blackoutt's Avatar
Sale pending!
Edit: still available and price lowered a ton. Ka-t specialist pricing special, check the first post!
Old 05-09-2011, 12:21 PM   #24
blackoutt
blackoutt's Avatar
Bump it to the top for the new lowww price, check the first post!
Old 05-09-2011, 12:54 PM   #25
racerx2k1
460
racerx2k1's Avatar
No links
Sale pending!
racerx2k1 is offline
