Old 04-05-2011, 11:58 PM   #1
i83fish
i83fish is an unknown quantity at this point
KA ka24de swap not starting
Hi everybody,
I am just finishing my swap and I'm stumped. Can't find anybody else with the same problem as I do, any help would be much appreciated.
I have a 1990 s13 that I bought with a ka24E with a massive rod knock.
My brother gave me a RUNNING 1993 ka24de since he was going SR20det.
here is some info...
-1990 s13 body
-1993 ka24de engine and transmission
-original 1993 ka24de ECU
-upper harness is from a ka24de (unkown year)
-lower harness is from the original 1990 ka24e
-the 5th position switch doesn't have a corresponding plug on trans
-disconnected the PAIR valve and blocked off appropriate vac lines under throttle body
-getting spark in every cylinder
-getting fuel, I can see/smell it on the spark plugs
-the engine was running well before it was taken out
-there are several ground wires that the ka24de body has that my 1990 body does not
-dremelled my grounds, nice and clean
-I can smell gas in my exhaust pipe and standing over my engine after cranking it
-since the car had been sitting around for around a year, I drained the 8 gallons of gas in the car and put in 3 gallons of fresh 95 octane gasoline
Thank you for reading,
-Andrew
i83fish is offline   Reply With Quote
Old 04-06-2011, 12:02 AM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
I have the same problem. Sad thing is I posted like 3 days ago. You mustve not seen it yeah.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-06-2011, 12:08 AM   #3
i83fish
I saw it but I don't have a connector for the crank sensor on my harness, which is what I got out of your thread. Did you happen to get anywhere with yours?
My engine was cranking with a random blip of combustion here and there, but now its not even doing that, just cranking...
Old 04-06-2011, 02:21 AM   #4
Pro ViZIon
Pro ViZIon's Avatar
How is the dizzy connected then?
Old 04-06-2011, 02:52 PM   #5
i83fish
I've been playing with the distributor and I've gotten it to the point where I am confident that it is on the right timing.
The engine was running when it was taken out, so I think the problem might be the harness or the ecu
Old 04-08-2011, 05:56 PM   #6
i83fish
solved!
The issue ended up just being that the fuel lines were switched. I thought that they were correct because a few people that own 240's said they looked fine. I had to look at quite a few pictures to get convinced otherwise, but now I know!
Old 04-08-2011, 09:55 PM   #7
Pro ViZIon
Pro ViZIon's Avatar
Haha well that was simple enough. Have fun with the car man.
Glad to see you posted your solution for others who may be searching.
240sx, fuel, ka24de, spark, start
