Old 04-11-2011, 03:43 AM   #1
blakeZX
blakeZX's Avatar
blakeZX is an unknown quantity at this point
Send a message via AIM to blakeZX
RB RB25, S14, Exhaust, BOV, Spacers, etc.. oem & am stuff
Made some changes to my setup so I am now offering some parts for sale that should help someone get their RB25DET swap up and running. Also some misc aftermarket and OEM stuff you may need.
*Note : All prices are BEFORE shipping; shipping is on your dime. All parts are in good/excellent condition unless otherwise noted.
Modified RB25 oil pan for use with RB26DETT (clears 26 oil pickup) - $65
Was test-fitted and filled with oil but never used. This pan was modified to be used for an RB26 RWD conversion. I’m running a regular old 25 so no need for the extra clearance. Your gain!
R33 Skyline crossmember - $150
RB25 OEM motor mounts - $30
RB25 OEM transmission mount - SOLD
RB25-into-S14 3-inch mandrel bent aluminum turbo-back exhaust - SOLD
Modified elbow to clear LHD steering column
Downpipe from elbow to test pipe
Test pipe
Cat-back section with resonator
GT-Spec style muffler with removable silencer included
All gaskets, hangers and hardware included; I’d recommend you replace some gaskets.
I went straight pipe so I no longer need this setup. Passed a CA modified exhaust fix-it ticket inspection with silencer installed :P
RB25 aftermarket turbo dump elbow, divorced wastegate - SOLD
RB25 OEM turbo recirculation valve - $20
RB25 R1 Racing Sports intake pod filter with MAF adapter - SOLD
This is a good choice for swaps because it doesn't take up a lot of space compared to cone filters, yet it flows well. Fits N60/N62 MAFs.
RB25 OEM sidemount intercooler with piping/couplers - SOLD
I think this also fits RB20's due to the similarities in the manifolds.
Sheepdog PROF blow-off valve on OEM RB25 cold pipe - $110
Super-mad-tight JDM, rare in the states. If you know what it is, you know it sounds awesome. Will not separate from cold pipe. Includes original packaging, vacuum hose, a legit white decal, and Japanese instructions.
RB25 OEM clutch kit, includes pressure plate, disc, throwout bearing - $60
Lots of meat on the clutch, was new when motor was swapped. Changed it out for an ACT 6-puck after a couple oil changes..also fits RB20 and VG30DE.
RB25/VG30DE/TT OEM Thermostat - $10
Works great, removed to install colder Nismo unit. Includes Permatex thermostat housing gasket maker at no extra charge, lol.
Mishimoto 19psi (1.3bar) high-pressure radiator cap - $20
Used for two oil changes..then I installed a PSM swirl tank which came with a different cap. So I no longer need this. I think Nismo caps are only 16psi..this is 19. Accidentally deleted the pic but it is squeaky clean!
Samco blue silicone radiator hoses for RB20/25/26 - $70
Brand new, never used. Just collecting dust; someone can use these I'm sure.
Miscellaneous R33/240SX AC lines - SOLD
The two lines on the left were cut with tinsnips from an R33 front clip so they obviously need to be cut again and welded to work with your lines. Others are extras I don’t need.
S14 Nismo Power Brace – $120
I couldn’t use this because I found out it hits the AC pulley on my RB25 after I hooked up my AC. Perfect for those of you who aren’t running AC, or are running KA’s/SR’s/what have you.
Wheel spacers:
-Powered By Max 20MM bolt-on (5x114.3) - SOLD
With removable hub rings. Discontinued part. Includes nuts.
-Generic 10MM slip-ons (5x114.3 and 4x114.3) - $25
-Generic 7MM slip-ons (Universal 5-lug) - $15
240SX S14 SE OEM black steering wheel, with airbag and cruise control - SOLD
Includes airbag, airbag hub, all wiring, cruise buttons, etc.
S14 tiny coolant hose (filler neck to overflow tank, with clamps) - $5
S14 OEM suspension links:
RUCA's - $15
Toe rods - $15
Tension rods (oem bushings are a little bit janky but they work fine) - $10
*Buy the whole set for $25.
S14 OEM front rotors - $20/pair
Great condition, includes dust shields if you want them. I swapped them out for Z32's so no longer needed.
S14 OEM black glovebox - $15
Couple of scratches but overall looks decent. The locking mechanism is not in it so you can swap in the matching lock from your car's set..I may have it around somewhere.
S14 OEM grey rearview mirror - $20
Great condition, no nicks/scratches. Just dusty from sitting in my garage.
PAYMENT:
Obviously, cash is preferred if you are local. Please add 3% for all payments made through PayPal to cover fees. If you want multiple items, I may be able to cut you a package deal. It never hurts to ask. No refunds/exchanges, all sales are final.
SHIPPING:
All items ship from San Diego, CA. Please provide your zip code and a list of the items you are interested in for a shipping quote. Small items will ship within 1-2 days of cleared payment; please allow an extra day or two for large or heavy items as I will have to obtain packing materials for them.
If you are interested in picking up locally, let me know. If you’re coming from LA or OC and you are buying a large item or a lot of small items, I can meet you as far north as Oceanside on one of my days off.
Please PM me or text sixONEnine-NINEtwoNINE-sixONEnineSIX. My name is Blake. Thanks.
-blakeZX | 1997 240SX SE (RB25DET), 2008 350Z Nismo Edition (VQ35HR)
blakeZX is offline
Old 04-11-2011, 08:27 AM   #2
rb20240sx
rb20240sx's Avatar
rb20240sx is an unknown quantity at this point
S14 sterring wheel
Do you have more pics of the steering wheel like the front. Mine looks like it works out. and shipping to 32579. Thanks
95 SE Serengeti sand- RB25 Neo
rb20240sx is offline
Old 04-11-2011, 11:00 AM   #3
blakeZX
blakeZX's Avatar
Transmission mount is sold.
Received a couple of PM's about the 20mm spacers; they are pending local sale but if that falls through I will honor the order of PM received.
As for the steering wheel, it is probably one of the cleanest ones you'll find but if you'd like I can get more pics for you. I'll be at the garage today getting the spacers so I'll snap a couple more for you, and figure out how much it weighs.
Thanks,
blakeZX is offline
Old 04-11-2011, 11:01 AM   #4
s14canyoncity
s14canyoncity's Avatar
Trader Rating: (50)
s14canyoncity is an unknown quantity at this point
Feedback Score: 50 reviews
good price on the Nismo brace, where you located?
Nissan S14 Navan Zenki
s14canyoncity is offline
Old 04-11-2011, 11:07 AM   #5
DailyDrivenS14
DailyDrivenS14 is an unknown quantity at this point
all ac lines to 37122 pm or text 615-474-3029
- RB25DET,precision pt67, greddy intake mani, e85, nistune, tune and dyno numbers end of march
DailyDrivenS14 is offline
Old 04-11-2011, 11:19 AM   #6
blakeZX
blakeZX's Avatar
Thanks. Downtown San Diego
Text sent
blakeZX is offline
Old 04-11-2011, 10:18 PM   #7
blakeZX
blakeZX's Avatar
AC lines, SMIC, and 20MM spacers sold.
Sent pics of steering wheel out with shipping quote.
Added silicone hoses to original posting!
All PM's replied.
blakeZX is offline
Old 04-13-2011, 02:02 PM   #8
blakeZX
blakeZX's Avatar
If you bought stuff from me, it was shipped today and you should already have a tracking number in your PM box.
Steering wheel is sold.
All PM's replied with shipping quotes.
I bought a scale so if you need quotes I should be able to get them done faster now, lol.
blakeZX is offline
Old 04-20-2011, 12:54 PM   #9
rb20240sx
rb20240sx's Avatar
Got my steering wheel yesterday looks awsome. Thanks BlakeZX. Buy from this guy.
Old 04-21-2011, 01:47 PM   #10
MudRacer
MudRacer's Avatar
MudRacer is an unknown quantity at this point
nismo power brace to 92881?
MudRacer is offline
Old 04-21-2011, 05:22 PM   #11
blakeZX
blakeZX's Avatar
Thanks for the nice feedback!
All PM's replied with shipping quotes. Thanks guys
blakeZX is offline
Old 04-23-2011, 08:52 AM   #12
Backyardjoe
Trader Rating: (33)
Backyardjoe is an unknown quantity at this point
Feedback Score: 33 reviews
Hi,
RB25 aftermarket dump tube & Nismo Power brace $150 shipped to Simi Valley,Ca 93063?
Thanks.
Backyardjoe is offline
Old 04-23-2011, 08:59 PM   #13
blakeZX
blakeZX's Avatar
Originally Posted by Backyardjoe View Post
Hi,
Thanks.
Sent you a PM.
If you asked me for a shipping quote, you should have one in your PM box. If I missed anyone please let me know. Thanks
blakeZX is offline
Old 04-23-2011, 09:20 PM   #14
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
how much for just the test pipe?
iamtheyi is offline
Old 04-23-2011, 09:28 PM   #15
blakeZX
blakeZX's Avatar
$350 and I'll throw in the rest of the exhaust for free. But seriously, the whole exhaust is pending sale, if I don't receive the money on Monday it will be available again. I am not parting it out at this time. Thanks
blakeZX is offline
Old 04-24-2011, 12:12 AM   #16
enjoisk8board891
enjoisk8board891 has made poor choicesenjoisk8board891 has made poor choicesenjoisk8board891 has made poor choicesenjoisk8board891 has made poor choicesenjoisk8board891 has made poor choicesenjoisk8board891 has made poor choices
He'll take the test pipe, ill take the modified elbow (assuming all welds are professionally done) and downpipe. You can sell the cat back separate? yay or nay?
EDIT---bahaha im an idiot and didnt read the rest of the post. . .let us know if the buyer falls threw?
enjoisk8board891 is offline
Old 04-24-2011, 12:23 PM   #17
blakeZX
blakeZX's Avatar
I'm not opposed to parting it as long as I have buyers for everything. But I'll let you guys know tomorrow if that is a possibility.
blakeZX is offline
Old 04-24-2011, 07:19 PM   #18
95s14rb25
95s14rb25 is an unknown quantity at this point
is the power brace still available? $120 shipped to 21122?
95s14rb25 is offline
Old 04-24-2011, 08:12 PM   #19
blakeZX
blakeZX's Avatar
You've got a pm
blakeZX is offline
Old 04-24-2011, 10:20 PM   #20
95RB
95RB is an unknown quantity at this point
i can promis yall this...the buyer wont fall through my engine is coming this week and i dont want to pay sumit racing 1000 bucks to come out to make me one. there are no exahust shops out here that i trust to do it...lol
95RB is offline
Old 04-25-2011, 06:36 PM   #21
blakeZX
blakeZX's Avatar
Full exhaust, aftermarket elbow, and intake SOLD.
blakeZX is offline
Old 04-25-2011, 06:44 PM   #22
ohhhizzzy
ohhhizzzy is an unknown quantity at this point
10mm spacers shipped to 53114 thanks
ohhhizzzy is offline
Old 04-25-2011, 07:19 PM   #23
blakeZX
blakeZX's Avatar
You've got a PM
blakeZX is offline
Old 04-25-2011, 08:56 PM   #24
racerx2k1
460
racerx2k1's Avatar
All PM's replied.
Sent you a PM.
You've got a pm
You've got a PM
racerx2k1 is offline
crossmember, exhaust, rb25, s14, spacers
