Old 04-16-2011, 08:51 AM   #1
fender-startocaster
fender-startocaster's Avatar
fender-startocaster is an unknown quantity at this point
Idle suddenly going up and down. Vid included.
On my way home last night suddenly my idle began to fluctuate. I am not sure where to start looking to solve this problem. A link to the video is located below. There you can see the idle fluctuating. Any thoughts or ideas are appreciated
Parts replaced withing the past 6k miles
fuel pump,
fuel filter,
spark plugs and wires,
almost all vacuum hoses.
YouTube - IMG 0458
fender-startocaster is offline   Reply With Quote
Old 04-16-2011, 09:42 AM   #2
Darren
Darren's Avatar
Darren is an unknown quantity at this point
really hard to tell from inside the car, you may want to get a vid from under the hood..
Normal reasons for the idle going up and down:
- vacuum / boost leak
- air pockets in the coolant
- timing
I'd start there, and pull the codes to see if maybe a random sensor took a dump.
Darren is offline   Reply With Quote
Old 04-16-2011, 09:56 AM   #3
junn
junn's Avatar
junn is an unknown quantity at this point
If it just happend out of the blue most likely it's a vacuum leak
junn is offline   Reply With Quote
Old 04-16-2011, 10:43 AM   #4
statickx991
statickx991 is an unknown quantity at this point
bleed the coolent system. look for vacuum leaks and maybe try to clean the IAC
im a f18 bro
statickx991 is offline   Reply With Quote
Old 04-16-2011, 11:02 AM   #5
fender-startocaster
- timing
I will check all of the above and report back. The engine is a stock kae btw so that rules out boost leak. My check engine light is not on, should i still check?
Old 04-16-2011, 01:56 PM   #6
mr.booie
mr.booie's Avatar
mr.booie is an unknown quantity at this point
unplug the coolant temp sensor while it is running and see if it makes any difference. if it idles better with the temp sensor out then you need a new one. do the same with the MAF. if this doesnt work then check the IAC. thats where i personally would start. good luck. text me if you need any help.
http://zilvia.net/f/image.php?type=sigpic&userid=70890&dateline=122764  6693
mr.booie is offline   Reply With Quote
Old 04-16-2011, 11:42 PM   #7
o0o
o0o's Avatar
o0o is an unknown quantity at this point
i had that shit on my rb20det atm
clean your idle valve and replace all hoses if they're hard...i removed my coldstart valve cause it was leaking like an asshole
do some pressuretests for your intercooler piping to make it 100%sure, that all helped at me alot
o0o is offline   Reply With Quote
Old 04-27-2011, 07:16 AM   #8
fender-startocaster
Just some updates.
Replaced coolant temp sensor and problem persists.
Ive always had a very slight air leak but could never find it. Replaced most hoses in attempt to find it. I got nothing.
I unplugged the maf and iddle shot up, i unplugged the aicv and it didnt do anything. I then cleaned it and still, nothing.
I am going to pick up a few aicv from the junk yard to see if that helps.
Old 05-04-2011, 11:18 AM   #9
fender-startocaster
Problem fixed!! Turns out my aicv took a dump.
