Old 04-04-2011, 05:43 AM   #1
NismoPlsr
NismoPlsr is an unknown quantity at this point
S13 DSS steel, KADE Clutchmasters 4-puck, S14 KA24DE
Local pickup only on the engine and transmission in Bristol, CT.
S14 KA24DE:
"112,XXX miles"
All emissions deleted
Comes with 370cc injectors
Pre-welded oil pan with hose for turbo oil drain
All accessories.
$400 pick up only
Gallery here.
S13 5spd trans. Shifts fine, all gears work. Seen in pics above.
$100 pick up only
KADE ECU with daughter-board pre-tuned for s14 T28 turbo and 370cc injectors. Unknown brand. It is Flash memory and not eeprom.
$80 +shipping
S13 5spd swap parts.
Flywheel
Throttle pedal
Clutch pedal
Clutch slave
Clutch master
Clutch line
5spd cross member
5spd non-ABS drive shaft
$175 +shipping
Drive Shaft Shop s13 non-abs steel.
Good u-joints. Seems barely used.
Fits KA/SR/CA.
$300 shipped in the 48
Used Clutchmasters 4 puck unsprung ceramic disc with HD pressure plate.
It is for a KA24DE but should fit on a CA18 if you take a dowel pin out of the flywheel or drill a new hole in the pressure plate.
$200 +shipping
Lowballers will be ignored.
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
Old 04-05-2011, 05:43 PM   #2
NismoPlsr
No knockoffs here.
Old 04-06-2011, 12:03 AM   #3
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Ill keep you in mind about the driveshaft, unexpected dental work will be taking all money fo now, lll let you know
andisan is offline   Reply With Quote
Old 04-06-2011, 05:20 PM   #4
NismoPlsr
andison, just let me know.
Bump.
Old 04-09-2011, 07:11 PM   #5
NismoPlsr
All still for sale.
Old 04-14-2011, 06:46 PM   #6
1slwride
1slwride is an unknown quantity at this point
Would the drive shaft work on a s14?
1slwride is offline   Reply With Quote
Old 04-14-2011, 10:29 PM   #7
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
Negative...
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 04-17-2011, 04:51 PM   #8
nnichols1147
nnichols1147's Avatar
nnichols1147 is an unknown quantity at this point
willing to seperate 5 speed parts?
nnichols1147 is offline   Reply With Quote
Old 04-17-2011, 09:07 PM   #9
Sr20Bluebird
Sr20Bluebird's Avatar
Sr20Bluebird is an unknown quantity at this point
Awesome stuff, bump for you Sr.
Friends don't let friends drive stock...
Sr20Bluebird is offline   Reply With Quote
Old 04-17-2011, 09:40 PM   #10
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
Miles on Clutch?
Any discount if I buy clutch & driveshaft?
Could you PM me price + shipping cost to 94545?
Thank you
-Roush
roushman90 is offline   Reply With Quote
Old 04-18-2011, 07:55 PM   #11
Chris_518
Chris_518 is an unknown quantity at this point
Hey I'm interested in the S13 5spd transmission, and all the S13 5spd swap parts.
(Flywheel, Throttle pedal, Clutch pedal, Clutch slave, Clutch master, Clutch line, 5spd cross member, and 5spd non-ABS drive shaft).
Just wondering if there's a clutch that will come with it (not the clutch masters one you have for sale separate, wasn't sure if you had a stock clutch in the tranny now), and if you have a lower wire harness for it as well.
Chris_518 is offline   Reply With Quote
Old 04-29-2011, 04:56 AM   #12
NismoPlsr
Final bumpski.
Old 04-29-2011, 06:22 AM   #13
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
Are the 5-speed swap parts and driveshaft still available?
driver11324 is offline   Reply With Quote
