Old 04-23-2011, 05:22 PM   #1
kenseis14
kenseis14 is an unknown quantity at this point
s14 rb wont stay on...any suggestions?
ok....i was driving late one night last week in the rain and my car suddenly cut off. a few days later i tried starting it up. it cranks and turns over ever time but shuts off right after. i found a water leak where the cpu is and its a little wet still but not much. i checked the alternator at auto zone and it passed. i checked the fuel pump, vacuum hose, battery, lower wiring, fuses, and gas. what else is there to check? could it be the the cpu is shorted out or does it need to be reprogramed if thats possible?
any thing will help right now....its my daily. its a s14 rb25..thanks guys
kenseis14 is offline   Reply With Quote
Old 04-23-2011, 08:58 PM   #2
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
when you put the key on position 2 does the light on ecu come on?
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 04-24-2011, 12:22 AM   #3
Sileighty_85
Sileighty_85's Avatar
check ECU for codes
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-24-2011, 11:43 AM   #4
trollin240
trollin240's Avatar
trollin240 is an unknown quantity at this point
i would check you mafs also
89 s13/rb20det swapped
93 p10(soon to be the new dd)
trollin240 is offline   Reply With Quote
Old 04-24-2011, 06:09 PM   #5
redline racer510
Any
Update?
