Old 05-08-2011, 09:41 PM   #1
240ez
240ez's Avatar
240ez is an unknown quantity at this point
s13 Weird headlight Issue..
A few days ago I notices that my right headlight (pop-ups), stays ome for a few minutes, then shuts off. Leaving my driving with only one headlight on.
Soooo.....I did the usual..
Checked the fuses...they're good.
Checked battery connections...pass.
Checked bulbs....good.
No corrosion or burned marks on the headlight.
The wiring doesn't look burned or frayed.
Whats left to do??
240ez is offline   Reply With Quote
Old 05-08-2011, 09:46 PM   #2
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Check your grounds.....Try another head light.....or switch your headlights and see if it does the same thing on the other side???
davirene is offline   Reply With Quote
Old 05-08-2011, 10:12 PM   #3
240ez
240ez's Avatar
s13
Checking right now..
Old 05-08-2011, 10:37 PM   #4
240ez
240ez's Avatar
s13
Ok...
Checked grounds...they are good.
I switched them...
The left one stays on still, while the right one has no power,
Then i hit the high beams, and the left one came on.
then switched them to low beam again.
They are both on.
Switched to high beam again. The right comes on only. Switched back...the left one is lit...not the right.....(scratching head with confusion)
Old 05-08-2011, 11:05 PM   #5
240ez
240ez's Avatar
s13
It might just be the battery...
May need a little charging...
took it out..
I have it charging now :T
Old 05-09-2011, 06:10 PM   #6
91s13ForMeeh
91s13ForMeeh is an unknown quantity at this point
Maybe there's some wire damage. pin hole insulation sliced open causing a short to power?
91s13ForMeeh is offline   Reply With Quote
Old 05-09-2011, 06:13 PM   #7
240sx .25mile
240sx .25mile is an unknown quantity at this point
it could be your head light switch i think. about a year ago i replaced mine because my right highbeam wouldnt come on. put a new switch in and it has worked ever since.
240sx .25mile is offline   Reply With Quote
Old 05-09-2011, 06:32 PM   #8
91s13ForMeeh
Nah it's not the switch. The switch would effect both headlights. Therefore it's not a flasher/relay either.
Old 05-09-2011, 09:39 PM   #9
240ez
240ez's Avatar
s13
Thanks for the help guys.
Hmm. Its not the switch, or relays, or fuses, or bulbs.
I just did a light check a few minutes ago.
Flipped them up, the left came on only.
Flashed the high-beams, only the right goes to high-beam.
Then I flashed the high-beams a whole bunch of times, now both lights work.....weird.
But...when flashing high beams, only the right goes to high beam...the left is dark.
So the only culprit for this problem I can think of the the wiring itself.
The robber protective grommet (behind the female plug for the Hb2)
on the right headlight wiring is chewed up, leaving the wires exposed
and old looking.
Old 05-11-2011, 10:46 AM   #10
Corey121
Corey121 is an unknown quantity at this point
I had the same problem and I replaced the switch and it fixed it, the contact in the switch get old and brittle and cause problems that don't always effect both lights that what I would replace...
Corey121 is offline   Reply With Quote
