Old 05-31-2011, 07:09 PM   #1
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
How to clean up engine bay?
Any tips on how to clean up engine bays?
I already have a relocated battery (it's in the trunk) but I have a rusty nasty looking battery tray with a cool blitz intercooler pipe going through it. There's a bunch of wires everywhere (safely). I just cleaned up some grounding locations and the car runs great.
Just the bay looks like shit. I'm tired of mine looking like a wiring nightmare.
Looking for maybe some aftermarket positive terminals, cool ground locations?
Battery tray removal tips?
I know there's a lot of guys on here with cool clean looking engine bays, let me know what you did to clean them up and what kind of parts you used.
Old 05-31-2011, 07:11 PM   #2
SaNTi
SaNTi's Avatar
SaNTi is an unknown quantity at this point
I'd like to know as well.
SaNTi is offline   Reply With Quote
Old 05-31-2011, 07:15 PM   #3
Jdm240sx123
Jdm240sx123 is an unknown quantity at this point
Just ripp out everything your not using or don't need and get a wire tuck!!!
Jdm240sx123 is offline   Reply With Quote
Old 05-31-2011, 07:16 PM   #4
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
first remove anything not needed and hide everything that u can. rewiring motor is the best way to clean up engine bay. a nice powdercoated valve cover makes a hell of a difference aswell as any other parts you can powdercoat. electric fans cleans it up and adds more space. definitely relocate battery and remove tray. reroute fuel lines remove all ac stuff.
Old 05-31-2011, 08:34 PM   #5
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
tubs... it will get rid of the nasty rusty battery tray and also make it look more subtle. Im currently in the process ive remvoved all smog shit that isnt needed and started hiding wires.
If you really want to get into it look up chase bays or other companies with brake line kits and hide them. Get a ss clutch line and just hide it. Many little things can make a difference, Oh yeah and old school yellow drift freaq mounts lighten it up too lol
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 05-31-2011, 08:52 PM   #6
chiboy002
relocate the wire harness for the injectors/maf/dizzy/temp sensors/ and such between the intake manifold runners/lower plenum.
Relocate fuel filter/lines to behind the lower rear portion of the intake manifold, there should be a spot you can make a bracket for it, or use the stock one. Fuel lines between the 2nd and 3rd runners and route them under the upper manifold.
Remove excessive vacuum lines/PAIR stuff/EGR and block off at the hardlines or at the manifold with freeze plug type of stuff
Clean everything nice and dandy/route spark plug cables in an organized fashion
Clean all the rubber hoses or upgrade to ss lines (black looks super nice) and route the reservoir somewhere hidden but still functional.
Reroute fuse boxes to better locations like next to battery or in the center console. Glove box almost always looks sloppy
Split the stock engine harness better, if you don't plan on rerouting it, and sleeve it or buy one from chasebays or w.e
Clean everything and cover all the small holes left behind from bolts/brackets and repaint.
Trim battery tray, use braille slim battery with a custom battery box in engine bay if too lazy to reroute.
Reroute harness locations that enter the engine bay, so its through the firewall or under the tranny tunnel.
Remove cruise control if you have it, all associated lines, and reroute vacuum lines for stuff like brake booster and such
List continues lol
street dancer.
GLEAM
Old 05-31-2011, 09:08 PM   #7
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I did an 1/8" ABS plate that I cut to fit perfectly inside the battery tray. Then obviously cut the holes for the intercooler piping and 4 awg positive/negative battery cables. I don't have any super good pics, but this will give you some idea:
...... actually, I forgot I took some pics when I was removing everything:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 05-31-2011, 09:41 PM   #8
Drift_86
Drift_86's Avatar
Trader Rating: (60)
Feedback Score: 60 reviews
If u got any oil junk u should get some engine cleaner and spry it only around the the junk and rins it off with some water. Also you can get a big brush and just dust of all the tight arears it makes a big diffrest if you try dusting everything.
Old 06-01-2011, 10:16 AM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I did a similar thing as Toby did, made an aluminum tray for that area, seperate battery dealio, and then made a nice hole cut for the intercooler pipe
I'll say this, the battery tray is a MFER and there are a ton of spot welds
Old 06-01-2011, 10:32 AM   #10
jr_ss
It sure is an MF'r... I drilled all my spot welds and removed mine. Huge pain in the ass.
Old 06-01-2011, 10:42 AM   #11
Ratpack_Chad
Ratpack_Chad's Avatar
Ratpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the roughRatpack_Chad is a jewel in the rough
I took out my battery tray. Took like 40 min of grinding down spot welds. Pain in the ass, if you can avoid it i would.
Ratpack_Chad is offline   Reply With Quote
Old 06-01-2011, 03:25 PM   #12
260sx KOUKI
260sx KOUKI is an unknown quantity at this point
Strip the intake of all the sensors and block the openings
260sx KOUKI is offline   Reply With Quote
Old 06-01-2011, 04:04 PM   #13
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
anyone have any small coolant overflow tanks on there s13's? i dont have room for a stocker, and the CXRacing one i have (looks like circutsports) i dont like the look/size of. looking for something like the size of a soda can. any ideas?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 06-01-2011, 04:10 PM   #14
dt-p88
dt-p88 is an unknown quantity at this point
I like this thread, good info.
dt-p88 is offline   Reply With Quote
Old 06-01-2011, 05:09 PM   #15
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
You could get the Powered by Max one?
Old 06-01-2011, 05:15 PM   #16
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
My engine bay is a mess. Next time I pull my motor out I'm going to be cleaning EVERYTHING up.
Old 06-01-2011, 05:20 PM   #17
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
That's a swirl pot, not an overflow tank. I actually talked to Dan about this a couple of months ago. He recommended running an oil catch for a coolant reservoir because it's a little bigger than the swirl pot and then just use the swirl pot as a swirl pot. That's what he's running too.
Pandapants is offline   Reply With Quote
Old 06-01-2011, 05:41 PM   #18
dopplganger1
dopplganger1 is an unknown quantity at this point
2x10" Stainless Radiator Overflow Tank Street Rat Rod | eBay, there are more sizes then just make a bracket to mount it next to the radiator.
dopplganger1 is offline   Reply With Quote
Old 06-01-2011, 10:37 PM   #19
codyace
codyace's Avatar
Trader Rating: (58)
I had one made to about that same size. Top fitting obviously vents downward, bottom fitting (imagine a mini catch can) is where the overflow line is hooked up too.
Fits nice and snug in there, doesn't interfere with any AC stuff either
Old 06-01-2011, 10:56 PM   #20
chiboy002
idk if you know Fred, with the white FC, but he has a japanese soda bottle that he uses for something along those lines. I believe its an oil catch can but it's about the size of a waterbottle but made of thick aluminum, its hard to dent.
You can have a shop weld bungs on it or drill and do it yourself, 1 in the bottom and 1 at the top.
Hey Toby, where do you buy your abs plastic? I bought some 1/8" thick online and it sucked. It would have so many burrs when cut and they edges wouldn't come out nice and clean
street dancer.
GLEAM
Old 06-01-2011, 11:52 PM   #21
Broadfield
Broadfield's Avatar
You are simply not putting in the effort man. After you cut with a jig saw or whatever you are using, then I go over it with 80 grit then work my way down to finer grits to get a perfect polished edge if necessary. I may start with a bench belt sander or an air sander to get the burrs off quickly. Nothing custom comes easy man. You have no idea how much time I have into the custom interior stuff I do. I might sit there and sand with a finger tip for 3 hours straight just to get a contour perfect.
Also, use a coarse blade when cutting. If you use a blade for cutting metal, it will simply melt the plastic as you are cutting it. So when I'm using a jig saw, I use a gnarly wood blade, but set the orbital action to the lowest setting and just go slow physically.... still fast speed on the trigger though. This will give you a fine cut, but not melt the plastic too much.
My Portfolio
Please Share
Check Out My Builds
Old 06-02-2011, 12:26 AM   #22
jusuravragecrakr
jusuravragecrakr's Avatar
jusuravragecrakr is an unknown quantity at this point
s13
i used one of those limited edition mountain dew aluminum long neck bottle for mine dont have pix right now but it actually gets a lot of attention in my super stock engine bay
jusuravragecrakr is offline   Reply With Quote
Old 06-02-2011, 10:48 PM   #23
aalbert240
aalbert240's Avatar
aalbert240 is an unknown quantity at this point
to remove my battery tray i used a spot weld cutter a regeluar drill bit will just drill right thru jus took mine out yesterday. pretty easy just kinda hard locating the spot welds.
IMAG0280.jpg by arenas211, on Flickr
spot weld cutter
IMAG0281.jpg by arenas211, on Flickr
aalbert240 is offline   Reply With Quote
Old 06-09-2011, 11:51 PM   #24
SaNTi
SaNTi's Avatar
Keep this coming!
Old 06-10-2011, 12:39 AM   #25
chiboy002
thats prolly where my problem was lol
i used a metal blade and didn't really sand it, tried removing burrs with a knife but made it worse
street dancer.
GLEAM
