Old 06-28-2011, 08:58 AM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Parts LIQUIDATION! NISMO cl/fly, carbon hood, swaybars, more!!!
I have decided to set my 240sx aside for a while and liquidate my parts. Prices are firm unless the item is listed OBO and DO NOT INCLUDE SHIPPING. I am definitely willing to make package deals if you are buying multiple items. I would vastly prefer local pickup, but I am willing to ship within the continental US. Due to the fact that I still do not have a working home computer, photo uploading is difficult. If you request photos of something, don't expect them immediately. Due to that fact, parts will be added slowly to the post.
NISMO clutch and flywheel setup for SR
I was REALLY looking forward to using this setup on my N/A SR, but unfortuanetly that didn't work out. All parts are authentic NISMO parts and are in very good shape. There is LOTS of life left on the clutch disc, minimal heat spots on the flywheel, no noticeable wear on the flywheel, no heat spotting on the pressure plate.
clutch disc P/N: RS225
pressure plate P/N: RS540
flywheel P/N: RS541
$450 OBO
Autometer mechanical oil pressure guage
This is an autometer mechanical oil temperature guage with the plastic tube. All you need is an adapter to screw it into your oil pressure port to make it work. The guage is als lighted as well. It is in good working condition. The size of the guage is 2"...
$30
Redtop SR20DET coilpack harness
This is a great condition coilpack harness from a redtop SR20DET. All connectors, insulation, and wiring are in great condition.
$20
S-14 SE stock rear swaybar (bottom in pic)
This is a stock S-14 SE 16mm hollow rear swaybar. It will work with either s-13 or s-14. The bar is in good shape, no bends, no significant rust. The endlinks are still attached to the bar, but I do not have brackets and bushings.
$10
S-13 stock rear swaybar w/poly bushings (second from bottom)
This is a stock s-13 15mm solid rear swaybar with energy suspension urethane bushings and brackets. The bar is in good shape and is what I used to use in the rear on my track car.
$15
S-13 SE 17mm rear swaybar (middle in pic)
This is a little thicker than a stock rear swaybar for those who want to try a small change. No bushings/brackets/or endlinks are included, but I do have urethane bushings available for this bar as well for an additional charge.
$20
S-13 hicas 21mm solid rear swaybar (second from top)
This is the stock swaybar off a usdm s-13 w/super hicas. It is 21mm in diameter and is solid. This is a significant upgrade from stock. Bushings/brackets/endlinks not included...
$40
S-13 JDM 22mm hollow rear swaybar (top in pic)
This is definitely the most desirable stock rear swaybar out there. Is is just a little under 22mm in diameter and is hollow in construction. It is very light and possibly one of the best rear swaybars available period. Bushings/brackets/endlinks not included...
SOLD!
S-13 25mm front sway, adjustable, w/bushings (top in pic)
This is the swaybar that I personally used on my 240. It is a stock s-13 SE 25mm front swaybar, but it has been drilled for a stiffer adjustment. Trust me when I tell you that drilling out those holes was a big PITA, but it made a large difference in front end stiffness. Included are urethane bushings and brackets.
$30
S-14 27mm hollow sway, adjustable (bottom in pic)
This is a stock s-14 27mm hollow front swaybar, that has also been drilled out for a stiffer adjustment. This was also a big PITA to drill as well. This bar can work for s-13 or s-14. No bushings/brackets/endlinks included...
$25
S-13 stock front endlinks w/poly bushings
I used these before I went spherical. The bushings/joints are in good shape and the bushings are energy suspension urethane.
$10
S-13 15mm poly rear swaybar bushings (unpackaged in pic)
These are brand new urethane bushings for a stock s-13 15mm rear swaybar.
$10
S-13 17mm poly rear swaybar bushings (bagged in pic)
These are also brand new and pretty rare. Most companies don't offer bushings for the 17mm rear bars since they're not very common, even on SE's...
$15
BARE S-13 rear subframe
The subframe is on good shape, no bends. I was planning on bracing it and installing solid bushings in it, but never got around to it. It is completely bare, no bushings, no arms, nothing...
$30
S-13 DOHC throttle cable
This is a stock s-13 DOHC throttle cable. It is longer than the SOHC one and is necessary for a dualcam swap.
$20
Since I don't like to list items without pictures and uploading pics is difficult at the moment I have some stuff that is not pictured or is still on my shell. Below is a "preview" list of those items. I will not list descriptions/prices though. If you want to know more you'll have to shoot me a PM...
-Enkei NT03+M's, 17x9.5 +38 5x114.3, powdercoated bronze
-300zx Porterfield R4S pads, used/full set (fr/r)
-Briaded steel 300zx conversion lines, full set (fr/r)
-redtop SR coolant temp sensor subharness
Old 06-28-2011, 09:29 AM   #2
economix
economix's Avatar
economix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud of
Hey bro, none of your pics are showing up, I gotta think many folks are passing these offers up bc of those broken or missing images.
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S
economix is offline   Reply With Quote
Old 06-28-2011, 09:31 AM   #3
racepar1
racepar1's Avatar
The pics are working fine on my screen...
Old 06-28-2011, 09:31 AM   #4
economix
economix's Avatar
Shit. They must block images from here at my office, niiiice.
Old 06-28-2011, 10:12 AM   #5
RBMadess
RBMadess is an unknown quantity at this point
haha sucks for you... the pics work fine for me here in my office.
anyway, free bump glws
RBMadess is offline   Reply With Quote
Old 06-28-2011, 10:46 AM   #6
economix
economix's Avatar
Seriously, just the images on this thread don't show in my office. Every thread otherwise is fine. IDK what's going one. The internet must be broke. Hurry and withdraw all your cash from the bank so it's not lost!
Old 06-28-2011, 01:38 PM   #7
onevia drift
onevia drift's Avatar
Trader Rating: (18)
onevia drift is an unknown quantity at this point
Feedback Score: 18 reviews
can i get aprice and pics of the Gracer front and sides
onevia drift is offline   Reply With Quote
Old 06-28-2011, 01:52 PM   #8
racepar1
racepar1's Avatar
I'll shoot you a PM right now with more info and a price. However, pics will take a couple days to line-up...
Old 07-02-2011, 02:58 PM   #9
racepar1
racepar1's Avatar
First bump........
Old 07-02-2011, 03:24 PM   #10
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
Could you please PM shipped price for these two? Location: 94545 NorCal
Thanks in advance
roushman90 is offline   Reply With Quote
Old 07-02-2011, 03:29 PM   #11
LimeLite Racing
LimeLite Racing's Avatar
Trader Rating: (24)
LimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfectionLimeLite Racing is close to perfection
Feedback Score: 24 reviews
Bump for a super legit seller.
Drift.
LimeLite Racing is offline   Reply With Quote
Old 07-02-2011, 04:02 PM   #12
blingbling
blingbling's Avatar
blingbling is an unknown quantity at this point
S14 hollow sway to chandler az 85226
blingbling is offline   Reply With Quote
Old 07-02-2011, 08:23 PM   #13
racepar1
racepar1's Avatar
Thanks in advance
Shipping is definitely available and I'll PM both of you with quotes ASAP...
Old 07-06-2011, 09:17 AM   #14
racepar1
racepar1's Avatar
Last bump........
