![]() Join Date: Feb 2004
Vacuum line everywhere, how much can i take off...
Im not sure what all the lines are for, some look to be EGR related some look legit.
What if can i pull off my motor? Ill be running a KA-T, so the more simple, the better. I have no intentions of ever running an emmissions system again, so the more i can take off, the better... heres a pic. Also, is there a reason all the vacuum lines run all the way across the engine bay just for the charcoal canister?
Kick Ass 2.4Liter Engine! |
![]() Join Date: Nov 2001
all you need is ONE vacuum line, and that is for the fuel pressure regulator.
EGR = junk BPT = junk AIV = junk Charcoal Canister = junk am I missing anything else? Oh yeah, you're round tail light 30 dollar special = junk ![]() |
EGR might but it didn't for me. Mine is a late 93' s13 and it was originally sold in texas. In the FSM, it makes a distinction about whether there is a sensor which will trip an check engine light. It says that it happens for california models only but I've heard otherwise.
alright pulled of the intake manifold and yanked all the lines... simple enough....
now you say i only need 1 to the FPR, what about the intake manifold flappers?
![]() Join Date: Jul 2001
Doesnt the AIV (air intake valve) use metered air? If you were to run the AIV line open to the atmoshpere, wouldnt that cause problems?
Im assuming you talking about the idle air intake valve that is. |
#7 | |
I hate you too...
-Jeff
Whatup? |
AutoX Junkie
The air intake valve (AIV) and idle air control (AIC) are two different things. You can remove the AIV system completely (the little black box and metal hard lines connecting the air box to the manifold) as long as you cap the holes. Could be wrong, but I don't recall the AIV using any vacuum source anyway.
