Not starting after auto to manual swap...
Alright guys I ran into a slight problem somewhere in my s14 auto to manual swap. Heres what I did,
Replace 96' auto ECU with 96' manual ECU Wired up the manual harness correctly Jumped the top connector of the fuse box Hooked up the backup lights Neutral position switch 5th position switch My problem is it wont start. Every swap mentions that once the top connector of the fuse box has been jumped, it will start. Mine wont start ![]() |
![]() Join Date: Sep 2006
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
I can almost garuntee you it has something to do with that little sensor that a lot of us bypass on the clutch pedal. I would hook up that clutch cancel switch and then try starting it up, or if you can always push start it! Haha
Speaking of starting, is the starter wired in? Some things get overlooked |
#3 | |
![]() Out of all the swaps ive seen, i saw NOTHING on the wiring on the clutch pedal so i figured nothing of it. The whole point of the fuse box loop around is that the car should start in ANY gear, even when the clutch is not depressed so im lost ![]() ![]() Hopefully someone else whos done the swap can join in? |
![]() Join Date: May 2003
Unless you wired the new clutch switch into the brake switch harness, then that's a non-issue.
The starter circuit will be completed and the car will "turn over" if you do nothing other than splice the 2 big wires behind the fuse box - The top plug. The ECU will not prevent the car from *trying* to start. You've either got: -- A dead/dying battery (not enough juice to turn it over) -- A corroded battery connection (can supply 12v to accessories and such, but not the amperage needed to turn the starter) -- OR you didn't splice the correct plug (??) - Brian
www.KA24DEvelopment.com |
yea like some one said... double check your starter wiring, make sure you did the neutral position switch correctly, just doing another once over on your wiring.
i did this swap last year and ran into no problems but was also on an s13 not s14 |
#8 | |
My battery was going low and I hooked it up on the charger. When i turn the ignition on I can hear my fuel pump but no turn over. I will try another battery out. The correct plug was spliced. |
![]() Join Date: Dec 2009
i JUST finished my swap this past weekend and the only you need to start the car is that top plug...
i havent wired anything from my trans yet and it runs great except for no speedo. you might have a power issue... |
#11 | |
Well guys i found my problem... The 2nd to bottom connector on the fuse box (engine bay) needed to be hooked up. I spliced them together and she runs and drives beautifully! Thank you for the help!
