Old 07-16-2011, 06:11 PM   #1
Hanzi
Hanzi's Avatar
Hanzi is an unknown quantity at this point
Is there a detail tutorial to remove tail lights from a s13 hatch?
Is there any detailed video that go step by step on how to remove the tail lights of a s13 hatch?
Originally Posted by udon! View Post
does bride make a steering wheel?
http://chrisreese.tumblr.com/
Hanzi is offline   Reply With Quote
Old 07-16-2011, 06:20 PM   #2
innovation
innovation's Avatar
innovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really niceinnovation is just really nice
open trunk, remove lining covering the tail lights. Proceed to disconnect plug from lights. Unscrew bolts holding down lights. Remove tail lights. DONE =)
innovation is offline   Reply With Quote
Old 07-16-2011, 06:24 PM   #3
cardoza
cardoza is an unknown quantity at this point
Yeah, everything is pretty easily seen. If you pull on the light and it doesn't come out, you forgot something.
cardoza is offline   Reply With Quote
Old 07-16-2011, 06:47 PM   #4
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
If you removed everything and it still doesnt come out, keep pulling, its the black rubber sealer stuff holding it in, its pretty sticky, but not unmanagable. Make sure you have new black sealer stuff aka butyl rubber seal ready for when you reinstall
Ilya is offline   Reply With Quote
Old 07-16-2011, 10:45 PM   #5
charat
charat is an unknown quantity at this point
yeah, its in the FSM.
charat is offline   Reply With Quote
Old 07-16-2011, 11:14 PM   #6
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
check the FAQ the thread tittle is some thing like fixing a leaking hatch or water getting in your trunk
Old 07-17-2011, 02:06 AM   #7
Bushido
Bushido's Avatar
take the center taillight out first, then the left and right.
no need to undo the lower bolts that hold the metal under taillight trim
Old 07-17-2011, 09:27 AM   #8
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
no____________
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 07-17-2011, 09:45 AM   #9
bookoo
bookoo's Avatar
bookoo is an unknown quantity at this point
This, make sure to take the center garnish out or you will crack/break it.
bookoo is offline   Reply With Quote
Old 07-17-2011, 11:03 AM   #10
ballinnmiami240sx
ballinnmiami240sx's Avatar
ballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura aboutballinnmiami240sx has a spectacular aura about
lol you should run away from a 240 if you need a video to take off the tail lights
1994 FD3S Drift // 945garage // sumospeed.com
ballinnmiami240sx is offline   Reply With Quote
Old 07-17-2011, 11:08 AM   #11
ixfxi
Guest
Posts: n/a
1) remove center panel
2) remove tail lights
3) do it on a hot day so that the sealant loosens
done and done
Old 07-17-2011, 01:47 PM   #12
olah.inc
olah.inc's Avatar
olah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enougholah.inc will become famous soon enough
shots fired
olah.inc is offline   Reply With Quote
Old 07-17-2011, 10:53 PM   #13
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
come on guys help the guy out.
1) open trunk
2) remove liner
3) unplug lights
4) theres a few clips that are holding the trunk release that are clipped over the end of a few of the nuts.
5) remove the 8mm nuts that hold in the center garnish
6) remove center garnish
7) remove the 8mm nuts that hold the side tail lights
8) remove tail light (you will have a bit of a rough time being that there is quite a bit of that rubber sealant around them holding them in. just wiggle)
9) repeat on the other side.
10) you are finished.
install:
1) whole thing above just backwards. before installing make sure to use new rubber sealant or they will leak.
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 07-21-2011, 08:33 AM   #14
NissanEnthus
NissanEnthus's Avatar
NissanEnthus is an unknown quantity at this point
^2nd this....Its super easy, really....Seeing that your 17 your doing the right thing by gathering knowledge first, but honestly only you need is a bit of confidence too
NissanEnthus is offline   Reply With Quote
Old 07-22-2011, 05:04 AM   #15
bladetech8
bladetech8's Avatar
Trader Rating: (32)
bladetech8 is an unknown quantity at this point
Feedback Score: 32 reviews
Searching works wonders aye?
http://zilvia.net/f/archive-faqs/103...taillamps.html
Pictures and step-by-step disassembly.. Follow it backwards for reassembly.
bladetech8 is offline   Reply With Quote
Old 07-22-2011, 03:36 PM   #16
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
240sx FSM, Full Service Manuals, S13, S14, KA24E, KA24DE : 240sx General Discussion
Tantwoforty is offline   Reply With Quote
