Old 07-18-2011, 07:11 PM   #1
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
C&R radiator, gt28rs, dohc lines, s14 brakes, ichiba 5 lug, 180sx rhd, stuff look**
My name is Scott, I live in Raleigh NC. Im paypal verfied with a business account and an adult. I ship fast and take care to do it right. You can text me any time for an immediate reply. No trades right now and everything is obo so ask, worst I could do is say no but I wont get mad. Thanks in advance and please bump it if you can.
919-749-6261 Scott
I have a set of sr20det coilpacks with harness. Sorry no picks in good working order, $90 obo. text for pics.
Z32 uprights, full aluminum. You can pick up the whole thing or I can just ship the uprights. $50 obo
By flashorlightning at 2011-07-17
S14 rear brakes, one ebrake line is cut and the calipers need a rebuild. S13 rear ichiba hubs in good condition. Rotors and pads all with good front s14 calipers and pads. Rear ebrake plates. Pretty straight forward. Ill sell the lot for $250 or the hubs alone for $150.
300zx 92 right e brake cable, used $25
This is pretty cool. A 1998 nissan oem rhd type x knee guard. It was attached to the dash, it keeps your knee in place when clutching it in a rhd vehicle. $50 obo
Nissan oem new but installed and never used water pump. Sr20det engine. $60 obo
Sr20det coilpack cover, $25 the rubber needs to be readheased to it but ill leave that up to the new owner. In good used condition.
Nissan 1998 type x blacktop full engine harness. Sr20det with 2 j4 ecus. Its uncut and has both sides of pigtails for the harness. $250obo.
By flashorlightning at 2011-06-15
Z32 maf. The first screen was cut out. Has pigtail and a random cold pipe attached with 3 to 2 1.5 inche couplings. $100 obo
C&R radiator, this is a full race setup for an s14 sr20det but can be used on any car. It can be mounted any way you want, it was meant for a v mount. Comes with a csi filler, and 16inch spawl fan, and has a stock s14 temp sensor welded in with bung on the radiator. $200 obo
Stock sr20det manifold with an excellent conditon heat shield. One bolt broken off on heat shield. $30 obo
This is a used T25/t28 dsm hybrid turbo for the sr20det. Its a direct bolt up. Has no fin damage and minimal shaft play. Its been sitting for a couple of years so I dont know how the seals are. Easy rebuild though. $180 obo.
Dohc 1992 nissan 240sx power steering lines. everything for the swap. $75.
Sr20det lower intake manifold with iacv still attached and some hoses. Good to go. Theres a new oem gasket on the iacv. $100 obo
full s13 chassis harness. It was a 1993 coupe with power options and moon roof. All intact with a couple of relays fuses and bulbs missing. No cuts in the harness. $150 obo.
S13 double din with brackets. I have a couple of these. $20 obo
Gt28rs china made turbo, Bought it off ebay a couple of years ago. Never ran it. Just had it on the motor and did some pulls with it. No shaft play in new used conditon. It has earls oil inlet line with fittings for the block and an earls oil restrictor line. All coolent lines oem nissan sr20det, ssac header, and ssac o2 housing. direct bolt on on a sr20det. Even has the turbo inlet oem sr with new oem gasket. $500 obo.
"Home is where the armor is"
nassin31spr is offline
Old 07-19-2011, 08:01 PM   #2
nassin31spr
Update, manifold is sold, dohc lines are sold. Please bump it if you can so I can get some stuff sold. Thank you.
Old 07-19-2011, 08:07 PM   #3
mr.flores
mr.flores is an unknown quantity at this point
knee pad is cool bro! GLWS!
mr.flores is offline
Old 07-19-2011, 08:54 PM   #4
RHD95S14
RHD95S14 is an unknown quantity at this point
I'll be in touch. I want that radiator!
RHD95S14 is offline
Old 07-20-2011, 10:29 AM   #5
nassin31spr
obo on the knee pad... you really arent going to see another on any time soon.
Old 07-22-2011, 06:04 PM   #6
nassin31spr
last and final bump. Ill close it and start a new one in 3 days.
Old 07-23-2011, 07:17 AM   #7
wannabe240
wannabe240's Avatar
wannabe240 is an unknown quantity at this point
How much for just the high pressure line shipped to 97045?
wannabe240 is offline
Old 07-23-2011, 09:30 AM   #8
nassin31spr
Im sorry the high pressure line is not sold seperatly, thanks though
Old 07-23-2011, 09:54 AM   #9
racerx2k1
460
racerx2k1's Avatar
racerx2k1 is offline
