![]() Join Date: May 2002
SR oxygen sensor problems
I have a 91 S13 with a 91 redtop from a 180SX. It has a bolt in the exhaust menifold currently, becuase I just sent my third oxygen sensor back to courtesy nissan. My first one I got from autozone, and my second one was from baxter auto parts. All three are the right size (the small one), but all three had the wrong plug, and did not read correctly. They had 4 pin square plugs, using 3 pins, and the plug on my harness is a 3 pin plug, oval casing.
The sensor from courtesy nissan was from a Z31 300SX turbo. I let the guy look up the part # for me, he said he was familiar with SRs. THe part number on the invoice and the box is: 22690-21P11 When plugged into my car it reads 200mv constantly. It goes down to 190 mv if you rev it hard. This is at a stand still, with the car warmed up (about 800ºF EGT). When the car is in motion, it reads lean all the time, and never changes on my autometer AF gauge. The gauge has 12v, and is hooked up proporly. I probably have at least 10 hours of experience soldering, and All my wiring is proporly soldered. I am trying to firure this one out, so if anyone has any thoughts, please share. Joey
Exceed 400x200 size limit |
Joey,
Did you find a solution? I just installed my AF Gauge today and I am having the exact same symptoms. I get about 200mV constant, which changes a little bit, but not much. I have an S13 black top in my S13 convertible. My understanding is that the three wires that come out of the o2 sensor are: black: heater wire black: heater wire white: output wire Theoretically the o2 sensor should work without the heaters plugged in, but the sensor must reach 600 degrees first. So I wired the output directly to the AF gauge and drove the car hard for a while. Acted exactly the same as having everything plugged in. Then I wired the heater wires to the battery and tried again, no change. Darren |
according to a few sources
S13 SR20DET REDTOP o2 sensor = 22690-19P20 ('87 280ZX) Hope that helps Edit: just noticed this thread is OLD ![]()
92 FastBack - Project 98 SE - Daily Driver |
The thread is old, but the problem is not! I brought this back up because it was relevant.
Well, I don't really know for sure if my information is screwy or if the o2 sensor is bad. I need confirmation either way.. anyone know about this? |
Good thought, and I do have a full 12.8 V at the gauge... so that isn't it.
Regardless, I have had a voltmeter on the output wire from the o2 sensor and I have verified that the signal is what is screwy. Hmmm.. anyone? |
![]() Join Date: Dec 2003
i am having the same problem, 90 240 with redtop sr, my a/f gauge is all hooked up properly lights up n everything, mine reads really rich tho, im not sure but i heard it might be cause of my cat, i had custom exhaust built 2 1/2 from downpipe back but i kept the old cat on there cuz im yet to get my high flow cat and i heard it might cuz the cat might be shit but i dont no.
chris
chris's sr |
Hmmm... the o2 sensor diagnostic?
The first thing I did was hooked the air/fuel gauge to the wire at the ECU and got the strange reading. Secondly I verified that the wire I was connected to was the same as the one at the o2 sensor using the ohmmeter. Check. Next I ran a wire directly to the o2 sensor to a voltmeter in the car. Same result. What diagnostic are you refering to? Darren |
#12 | |
Darren |
#17 |
![]() Join Date: Apr 2004
A wideband would help you tune your car if you had an safc. Don't worry about it. Mjjstang just meant air/fuel ratio gauges aren't accurate at all, they're just a dancing light show.
#18 | |
I do have an AFC and I plan on using my o2 sensor and gauge to do rough tuning before hitting the dyno. I dynoed it last weekend (without touching any of the default settings on the AFC) and I am running RICH throughout the pull. But without something to give me a reading I can't exactly adjust my fuel accurately.
The AF Gauge shows dancing lights, yes, but they correspond directly to the output voltage of the o2 sensor, right? If the o2 sensor is not hooked up to the ECU then I think the ECU runs in closed loop mode -- it shouldn't be trying to constantly adjust the fuel mixture based on the o2 readings. The o2 sensor is only "crazy" at idle I thought -- while the ECU was trying to optimize the fuel mixture. Under heavy throttle the gauge should process the information from the o2 sensor accurately, no? What I want to know is how a wideband o2 sensor differs from a normal o2 sensor... so I went out on the net and found this: Quote:
Darren |
#19 | |
More good information from dyezak at DSMTuners.com:
