Old 08-09-2011, 11:09 AM   #1
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Stripped threads on oil-feed into block? (Help advise)
So the threads on my Oil feed line going into the block pulled out...of the block, while installing my oil line last night. FML.
I have a braided SS line, that has a -3AN fitting on it. Can I just tap the block out to 1/4" NPT and then run an adaptor to my -3AN line? Or will that fuck up the oil pressure to the turbo, not having a banjo bolt/fitting in there?
Pics and experience would be awesome!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 08-09-2011, 11:13 AM   #2
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
yes you can tap the block to whatever fitting you can use.
but you will need a restrictor IIRC .60 for journal bearing and .30 for ball bearing turbo.
they have restrictors that screw into the turbo, and will allow you to connect the -3AN line to.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 08-09-2011, 11:16 AM   #3
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
Use helicoil. Do a search. This question is asked at least 3 times a month.
"Home is where the armor is"
nassin31spr is offline   Reply With Quote
Old 08-09-2011, 11:18 AM   #4
BlackZenkiS14
Searched. Found what I needed. I can just use the -3AN straight, because its -3AN, if I had -4AN i would need a restrictor.
Thanks guys.
Good write-up for others after me: http://forums.nicoclub.com/diy-strip...t-t443899.html
-Kyle
Old 08-09-2011, 11:46 AM   #5
cotbu
cotbu's Avatar
The restrictor you would need for the turbo (BB or JB) regardless of line or fitting , for the line you would need a reducer, that's if you used a 4-an fitting to your current 3-an line.
So, if you are using a bb turbo you would still need the restrictor, with 3-an fitting and 3-an line.
Old 08-09-2011, 12:58 PM   #6
BlackZenkiS14
Im using a Zenki S14 T28. Should be JB
-Kyle
