Old 08-15-2011, 09:49 AM   #1
GldnBbyNuts
GldnBbyNuts's Avatar
GldnBbyNuts is an unknown quantity at this point
New to 240s Question for wiring guys
Whats going on guys! I jus got my first s13 about a week ago and im liking it so far! Well im having a wiring issue that i cant figure out for the life of me and im usually pretty good at this shit! Well for one whenever i get on the brake, my radio flickers off and then comes back on! wtf....then whenever i turn the car on the reverse lights stay on no matter what idk what it could be! and lastly when ever i roll the drivers side window all the way up the interior lights come on and stay on! and help would be great guys! thank!
GldnBbyNuts is offline   Reply With Quote
Old 08-15-2011, 07:49 PM   #2
l2edken
l2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the roughl2edken is a jewel in the rough
you need to get a video of this haha sorry i have no aid to give.
l2edken is offline   Reply With Quote
Old 08-15-2011, 07:55 PM   #3
spectra
spectra is an unknown quantity at this point
Def. Custom.
spectra is offline   Reply With Quote
Old 08-15-2011, 08:07 PM   #4
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Reverse light, u have a KA or SR?
SLiDe_WaYz is offline   Reply With Quote
Old 08-15-2011, 08:13 PM   #5
GldnBbyNuts
its a KA!!!
Old 08-15-2011, 08:19 PM   #6
SLiDe_WaYz
SLiDe_WaYz's Avatar
Wait, are you the guy that just bought the s14 in Shreveport on 318? Anyways do your reverse lights work, maybe the reverse wires are broken for the rear lights. Mine don't work in my SR.
Old 08-15-2011, 08:23 PM   #7
GldnBbyNuts
bought the s14 sold it and bought a s13! but yea the reverse lights work they just stay on as soon as i turn the car turns ons
Old 08-16-2011, 07:33 PM   #8
GldnBbyNuts
something else i noticed...sometimes while im driving the door open light flashes on and off and my dome light flickers with it....
Old 08-16-2011, 07:55 PM   #9
mitcheyismyname
mitcheyismyname is an unknown quantity at this point
^^^^ your door switch is faulty or loose. Look by the door jamb, there a little switch. All I did to fix that problem is put 3m adhesive tape because it's thick so it holds the switch in while I drive.
Edit: I'll try to get a pic up if this is confusing. Check both driver and passenger side.
mitcheyismyname is offline   Reply With Quote
Old 08-16-2011, 08:42 PM   #10
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
First thing to always check is the wiring under the fenders.. thats where 90% of all 240 wiring problem starts from. Next check the lower harness for any short. If not check your relays because they are not closing properly.
PeaceOnesxWai is offline   Reply With Quote
Old 08-17-2011, 09:13 AM   #11
GldnBbyNuts
I'll be checking under the fenders today. Your the second person that's said that so ill let you all know if that helps!
Sent from my ADR6400L using Tapatalk
Old 08-17-2011, 10:14 AM   #12
DERRICKMC
DERRICKMC is an unknown quantity at this point
Alright tire well wire harness is the first thing to check. next check your transmisson a lot of times the lower harness is always jacked up and the sensor for reverse, fifth gear, and neutral safety are broken or jerry rigged in some sort of way. that should fix your reverse lights. radio flickering check that the radio is grounded just through the radios antenna is not good enough. other than that I dont know bro hopefully this helps you some.
DERRICKMC is offline   Reply With Quote
Old 08-17-2011, 10:21 AM   #13
GldnBbyNuts
Thanks a lot derrick ill check that when it cools down outside.
Old 08-17-2011, 06:28 PM   #14
GldnBbyNuts
Ok update...I fixed the window rolled up and dome light problem and the reverse light problem! Didn't get a Chance to pull my fender to check the other stuff yet...
New problem occurred...these lights sometimes stay on even after I've turned the car off and taken the keys out
Could it be the same culprit?
