Old 08-22-2011, 11:44 AM   #1
Jake1992
Jake1992's Avatar
Jake1992 is an unknown quantity at this point
s14 Apexi Power fc car won't start .. any suggestions pls?
First of all i bought the car with the ecu not installed ...
the old owner did not have an commander so made things
difficult. I borrowed a friends commander and turned off the
boost kit.
I reseted the ecu on the commander.
car turns on for a second or less and then dies ...
overfuel ? bad ecu ?
any ideas
Jake1992 is offline   Reply With Quote
Old 08-22-2011, 11:45 AM   #2
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Mods on car?
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 08-22-2011, 11:57 AM   #3
Jake1992
Jake1992's Avatar
z32 maf... can't access the maf menu though its not in the list
Old 08-22-2011, 12:05 PM   #4
EsChassisLove
Trader Rating: (26)
You're sure its a L Jetro Pfc not a d Jetro?
Old 08-22-2011, 01:45 PM   #5
dustky43
dustky43 is an unknown quantity at this point
What's the part number on the Power FC?
dustky43 is offline   Reply With Quote
Old 08-22-2011, 02:59 PM   #6
Jake1992
Jake1992's Avatar
Serial # =
415-F001
It says apexi power dull computer unit on it...
i can't get in the setting of airlow on the handheld
Old 08-22-2011, 03:18 PM   #7
Jake1992
Jake1992's Avatar
I think mine was like this ...
Old 08-22-2011, 03:45 PM   #8
EsChassisLove
Trader Rating: (26)
Why did you upgrade the maf and nothing else?
Old 08-22-2011, 04:20 PM   #9
Jake1992
Jake1992's Avatar
got the car with it changed...
got front mount intercooler , and intake changed...
going full 3" exhaust as soon as my apexi works
my NTR gives a black dot and WRN light , IGN , and ECC
might any be the problem with the car not staying on , it starts then dies
Old 08-22-2011, 04:20 PM   #10
dustky43
Serial # =
415-F001
That's the number for the FC commander, what's the number on the actual ECU?
Old 08-22-2011, 04:36 PM   #11
Jake1992
Jake1992's Avatar
PFC s141010-0040
Old 08-23-2011, 05:35 PM   #12
VATOCLOWN
VATOCLOWN is an unknown quantity at this point
just got off the phone with apexi and your serial # is for an s14 sr20det 93-96 i didnt ask if it was ljetro or djetro sorry what motor and stock ecu# are you using right now
VATOCLOWN is offline   Reply With Quote
Old 08-23-2011, 08:51 PM   #13
Jake1992
Jake1992's Avatar
i'll have to check my # in the morning....
im running a sr20det and my car is 94 with a 95 engine in it ... so full harness is from an 95....
Im going to throw the stock sr20det map back on it for an s14.
i do have an z32 maf , FMIC , Intake , and 3" full exhaust...
so have to make some changes in the airflow right ? hmmm im putting it on
a datalogit tommorow instead of using my friends handheld commander
Old 08-24-2011, 04:44 PM   #14
VATOCLOWN
did you get it working?
Old 08-25-2011, 09:12 PM   #15
Jake1992
Jake1992's Avatar
Today i did , hooked it up too datalogit and put a stocks14 map back
on guess i had something completly wrong on it...
in the 30 min idle self learning time ... what hapapends if i give a little bit off gas?
It was my first time working with datalogit and middle in a street... this friend borrowed me his and we were doing it infront of his restaurant...
so next time i think ill get a better look at my data... im in need of an commander...
