Old 08-25-2011, 07:45 PM   #1
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
Clutch pedal wont come up
S-14, new master and slave. I have noticed that the clutch pedal has slowly sank to the floor. I can still shift and drive the car I think the pedal is sitting at the level where there is some pressure. I dont know if thats where it sits or not.
So my question is are there springs that bring the pedal back up or is off the pressure of the master
Slide Happy
chuy is offline   Reply With Quote
Old 08-25-2011, 08:04 PM   #2
Dolph_KYAS13
Dolph_KYAS13's Avatar
Dolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond repute
have you bled your clutch?
-Jordie Lewis
'93 Skyline Type M
Dolph_KYAS13 is offline   Reply With Quote
Old 08-25-2011, 08:06 PM   #3
Ben10
Ben10 is an unknown quantity at this point
^ what he said. bleed the clutch line. it will fix the problem
Ben10 is offline   Reply With Quote
Old 08-25-2011, 08:36 PM   #4
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
Make sure to bleed the surge system as well, or do yourself a favor and get rid of it completely.
khilgers is offline   Reply With Quote
Old 08-26-2011, 07:39 AM   #5
willysk8
willysk8's Avatar
willysk8 is an unknown quantity at this point
isn't it called the damper box? i just got rid of mine
willysk8 is offline   Reply With Quote
Old 08-26-2011, 07:40 AM   #6
khilgers
yeah you're right, but at least we're talking about the same thing.
Old 08-26-2011, 06:43 PM   #7
chuy
oh sorry there's a stainless steel line that runs from master to slave. no damper box, is there some springs underneath the dash board? everything was fine for 2 months
Slide Happy
Old 08-26-2011, 07:09 PM   #8
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
I have the same issue. Bleeding didn't help, changing to a stainless line and eliminating the damper box didn't help either. I've tried adjusting the pedal itself and that didn't help either. Mine actually affects shifting as well.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 08-26-2011, 07:14 PM   #9
heyitzalan
heyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant futureheyitzalan has a brilliant future
remove all the lines and change into one braided clutch line, bleed the whole system. and call it a day. lol
heyitzalan is offline   Reply With Quote
Old 08-26-2011, 07:49 PM   #10
Trap Star
Learn to read. Both of us did that.
Old 08-26-2011, 08:04 PM   #11
Poorboy
Poorboy is an unknown quantity at this point
I am not an expert by any means, but I think there is a spring in the clutch pedal assembly that could be to blame. My guess is if you get yourself under there with a flashlight you should be able to see whats wrong with a visual inspection. If there's a spring out of place or hanging or snapped, then you'd see that.
You could check the FSM to see if there's a diagram of the pedal assembly and use that to reference when you're looking at yours, or find another 240 MT car to compare with.
Poorboy is offline   Reply With Quote
Old 08-26-2011, 08:20 PM   #12
Trap Star
I've spent some time under there but didn't see anything out of the ordinary. Dunno about the OP but mine is usually fine until you put pressure on the pedal. Once you do that you can take your foot off the pedal and watch it slowly move towards the firewall until its fully depressed. If I let the car sit for a few days the pedal will be fully depressed when I get into the car. Its pretty weird.
