Old 08-28-2011, 12:08 PM   #1
93sr20240
93sr20240 is an unknown quantity at this point
knock sensor need power?
just as title states... i am haveing code 34 show and i replaced knock sensor and still shows code.... im wondering if power goes to knock sensor i check and there is non i also checked from ecu and no signal coming from ecu...
93sr20240 is offline   Reply With Quote
Old 08-28-2011, 01:07 PM   #2
PoorMans180SX
PoorMans180SX's Avatar
Knock sensors don't receive power or "signal".
They are a piezoelectric sensor that takes a vibration and turns it into voltage. This voltage is then transferred to the ECU, which translates it as knock and reacts accordingly.
Is your car running crappy? If not, I wouldn't worry about it.
Old 08-28-2011, 01:22 PM   #3
93sr20240
yah running like crap.... on the sr20det faq page it says it recieves 5volts and has 560ohms resistance... im running super rich idle and all
Old 08-28-2011, 05:27 PM   #4
nismolvr
nismolvr's Avatar
nismolvr is an unknown quantity at this point
^^^^^^^^^^Wrong!!!! I have searched the web and used FSM and found limited info on how to fix code 34.I found write ups on how to bypass the sensor using a resistor,did not want to go that route ,cause if i did and my engine did begin to ping/knock The ECU would not be able to retard timing ,thus preventing engine damage,just want to protect my investment.
1.code 34 means there is something wrong with the knock sensor circuit.It does not mean your engine is knocking.
2.The knock sensor is a Resistor and should read 560M Ohms.DOES NOT PRODUCE ITS OWN VOLTAGE!
3.on ECU pin 27 (white wire) should produce 5volts with knock sensor disconnected KOEO. KS plug is located between intake runners 3 and 4 disconect it before checking supplied voltage.If OK move on to next step
4.With the KS plug still being disconected check resistance from A (white wire) to engine ground ,it should read 560ohms,wiggle wire connection under manifold ,if resistance changes ,theres your problem,remove KS and check plug and KS for cracks .Replace if ks is out of specs.
This is how the knock circuit works, ECU supplies 5 volts to knock sensor ,KS has a base resistance of 560M ohms when the engine is not knocking.The voltage is stepped down to 2.5 volts (this is normal).The ECU needs to see this 2.5Volts all the time if it doesnt you get a code 34.
When the KS senses knocking vibration or pinging the sensor changes resistance in the circuit ,this causes the Voltage to oscillate above and below 2.5volts.Then the ECU retards timing in order to prevent engine damage.
nismolvr is offline   Reply With Quote
Old 08-28-2011, 05:36 PM   #5
nismolvr
nismolvr's Avatar
s13
I got your PM. SR and K24 ECU Knock circuits operate the same.If your ECU you shoud have 5 volts going out going directly into K sensor . If Not .Check directly on your ECU with a DVOM .Make sure you ground negative side of Volt meter in a good contact area. Turn key "ON" engine OFF and check for 5V in the assigned KSensor pin.
If your not gettin Voltage ,Replace ECU.
Old 08-28-2011, 05:44 PM   #6
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Or just ground it to the body off the ecu using a 1meg ohm resistor
Memberofthe600hpkaclub is offline   Reply With Quote
Old 08-28-2011, 05:53 PM   #7
nismolvr
nismolvr's Avatar
Problem is , hes not getting voltage out , so installing a resistor would be useless . Id fix it correctly and not jerry rig it to fool ECU.Especially if he has a turbo.Timing needs to retard , otherwise you run the risk of damaging motor.
Old 08-28-2011, 05:59 PM   #8
nismolvr
nismolvr's Avatar
s13
I wrote that stickie
Old 08-28-2011, 06:37 PM   #9
93sr20240
thanks and yah thas why i pm'd you... i ran across your sticky... ill check next time i get to messing with it with a multimeter i was checking earlier with test light and wasnt getting anything out of #27..... i have a rs enthalpy tunned ecu if im not getting any out of ecu would it possibly be in tune or whole ecu?
Old 08-28-2011, 06:44 PM   #10
nismolvr
nismolvr's Avatar
s13
I dont know what ECU you have but make sure your probing the correct one by studying the pin outs.Never use a test light to check power on ECU pinouts! Always use A DVOM ... 5 volts will not light up a test light set for 12volts..So check it and hope you do have the 5volt reference.
Old 08-28-2011, 07:25 PM   #11
93sr20240
ok thanks and its a e5 ecu and im checking #27 white wire
