Old 03-20-2004, 01:44 AM   #1
Matt_240
Internet Drifter
Matt_240 is an unknown quantity at this point
s14 My Problem: Massive Bogging
ok, ive got a 95 240sx. im getting my car painted by some sidejob guys and they took it to their house to bodywork it. after they body work it, they try to drive it and its bogging. i go over there to check it out and all through the gears it bogs. like crazy bogging. when i let the car go by itself w/o pushing throtttle, it's fine. it's when i hit the gas pedal that it bogs. 1st gear and 2nd gear is horrible. one thing that's really weird is that i left it in 1st and let it go w/o pressing the gas pedal, and it didnt die! wtf!? anyway, before you tell me to search, ive done a lot of searching. heres what i got so far:
1. Clean Mafs, TPS, AIV, all sensors
2. Check injectors
3. Check battery terminal
4. Seafoam throttle body
5. Check for loose wires
6. Check for vacuum leak
7. Entire Distributor?
i thought maybe the dust from primer got into the MAF sensor so i cleaned the MAF sensor with alcohol, but it didn't change anything. Changed the rotor but that didnt change anything either. im going to change my spark plugs tomorrow. i was wondering if anyone else had this problem and how they fixed it. id like to know what the most likely problem is cause i want to fix this asap. Thanks for any help.
Matt_240 is offline   Reply With Quote
Old 03-20-2004, 01:53 AM   #2
Matt_240
Internet Drifter
oh yeah more information. my car starts fine. sometimes idle is shaky(like goin up and down from 600-900. sometimes its ok.
Old 03-20-2004, 02:32 AM   #3
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
TPS thats my guess...mines starting to do it too
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 03-20-2004, 02:40 AM   #4
Matt_240
Internet Drifter
TPS? are you gonna clean it? should i just clean it with alcohol as well? is your car bogging like hell?
Old 03-20-2004, 10:34 AM   #5
twitchy
twitchy's Avatar
i dont know what to do with it.. Its not bogging too too bad just sometimes for now...Well have to see what happens..I want to try sparkplug wires and plugs first
Old 03-20-2004, 01:02 PM   #6
Matt_240
Internet Drifter
ok, im gonna try spark plug and wires first. then fuel filter. then clean sensors. if that doesn't work. then. clean throttle body. if that doesn't work then i dont know.
Old 03-20-2004, 01:50 PM   #7
twitchy
twitchy's Avatar
heres my 2 bits:
-changing fuel filter wakes up high end acceleration (using OEM FILTER) and goes so slowly you can hardly tell you were losing power...easy to do
-changing plugs seems to do little or nothing, i just regap and clean mine every so often..maybe a little perkier
-run some combustion chamber cleaner through the TB....idles nicer, runs stronger, uses noticeably less gas at first (although its starting to get bad again but I have an O2 sensor waiting to go in)
-fuel injector cleaner at every fill up to keep them clean
all this and the only thing I can tell affects the bogging (although again mine isnt severe and can be stopped by just hamming the gas) is the fuel injector cleaner...maybe ones clogged or something...as well check your plugs when you remove them..the inner valve cover gasket can leak oil into the sparkplug area and foul it up.....
Old 03-20-2004, 04:07 PM   #8
direb0y
direb0y is an unknown quantity at this point
funny, my car (sohc) and a friends (dohc) are doing almost the exact same thing.
something i noticed - sounds like the cat is clogged, running super rich, everything seems to run better with the intake off....
i'm thinking it has something to do w/ the maf
1990 240sx coupe, bone stock (for now)
direb0y is offline   Reply With Quote
Old 03-20-2004, 07:01 PM   #9
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
well i had bogging problems with my sr.....and it was due to the stock ka exhaust i had on it the turbo was getting too hot....i dont know if that helps you or not
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 03-21-2004, 09:00 PM   #10
Matt_240
Internet Drifter
ok, just changed my plugs, fuel filter, and cleaned all the sensors. evem put in fuel system cleaner. took it out for a drive 5 min ago. i tried starting it and it had irratic idle. would just die on its own if i didn't rev it. drove it around and it was fine until my engine started to warm up. then the massive bogging started again in all gears. im kinda lost.
could it be my distributor? i changed the rotor but could it be the whole distributor assembly itself? my spark plug wires look fine. im not sure about my injectors though. anybody have any ideas?
Old 03-21-2004, 09:34 PM   #11
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
I would check for some rotten vacuum hoses. When they become brittle and break, they may still look like they are fine, but are actually releasing the vacuum...
zero.counter is offline   Reply With Quote
Old 03-21-2004, 09:40 PM   #12
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
hmm!
did you mess up the connector to the MAF? I did that when I pulled mine off,and even though the actual electric meeting points were fine,the clamping system wasn't,and it was acting the same....try runing seafoam.....half into a vacumme line while the car is running....pull it off your brakes booster....then cut off the car,and put the rest into your crankcase,let it sit for an hour and drive around at NORMAL rpms until it stops smoking,that should greatly help (proble need it anyway)
Direboy could easily be right.....check your o2 sensor too,it could have some relation to this,but I highly doubt it would cause it....
EDIT:Only run seafoam a max of 500mis. before an oil change,and be warned...guys on zilvia will flame me for suggesting that and will proble say not to...
I still have a feeling its the MAF,you were talking about the primer dust and whatever,that could have easily started to kill it,and that means that cleaning it won't do you any good....can you check your ECUs code and post it?
Ghettokracker71 is offline   Reply With Quote
Old 03-23-2004, 04:23 PM   #13
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
my car was bogging also, does the the car smell like oil when your driving?? in my case it was the knock sensor, i think when i was trying to take out my oil filter i broke the clip for the knock sensor nad the rubber casing also ripped off, oil got on it..i just used denaturized alcohol and now its fine
smellslikecurry is offline   Reply With Quote
Old 03-23-2004, 08:04 PM   #14
misnomer
misnomer's Avatar
It could be any of a number of things. On my sister's SOHC, when it was bogging, it turned out to be a clogged catalytic converter.
Old 03-24-2004, 01:30 AM   #15
Matt_240
Internet Drifter
changed tps, checked distributor, isn't a clogged cat, and not MAF cause i switched it out and it still did it. took it ot a shop and came to the conclusion that it might be the EGR valve. the spring inside seems to be bad and keeps it open, hence causing it to bog. im gonna have them cap it off tomorrow with a plate and see what happens. i'll let you know how it goes cause it seems like a lot of people are having this problem and cant figure it out.
Old 03-25-2004, 11:45 AM   #16
Matt_240
Internet Drifter
ok. update:
1. changed tps - no change
2. checked o2 - fine
3. removed egr - slightly better but still almost same
4. vacuum lines dont seem to be leaking
i'll try and see if it could be the cat today.
keep the ideas coming guys cause we're starting to run out
symptoms:
1. idle bounces but steadies
2. as the car warms up, it bogs like crazy. i have to find a spot to keep the gas steady (like 3100rpm) and it'll be ok but as soon as i give it more gas, it bogs...
3. under no load, in neutral, when i steady the gas at 2k and then mash the pedal, it hesitates at 2500 rpm and then goes up.
oh yeah, and im running rich.
Old 03-25-2004, 11:57 AM   #17
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
Distributor...mine went out..did the same type of things...i would have to keep the idle at like 2500 rpms at a stop just to keep it running...talk about learning to heel toe...lol...then just wouldn't run at all...so, after doing all kids of other stuff, i changed Cap, Rotor, and Distributor itself (which sucks cause it's bank)...fixed it 100%...
but you said you checked the Distributor...so i dunno...how did you go about checking it?
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 03-25-2004, 12:20 PM   #18
Matt_240
Internet Drifter
a shop checked it for me.
Old 03-26-2004, 12:05 AM   #19
Matt_240
Internet Drifter
ok, im down to the wire..heres a list of things checked so far:
1. changed spark plugs
2. switched out spark plug wires
3. changed rotor and cap - distributor
4. switched out air intake temp sensor
5. switched out MAF
6. checked intake piping for leaks
7. checked all vacuum lines
8. removed egr - to get rid of a lot of vacuum lines
9. tested continuity from sensors(tps,MAF,Intake air, coolant temp) to ecu
10. changed tps
11. changed o2 sensor
12. made more ground
13. switched out ecu
14. changed fuel filter
last things to do is switch out coolant temp sensor and entire distributor with another. hopefully i'll find someone who has one. any other suggestions are more than welcome.
Old 03-26-2004, 12:06 AM   #20
mrmephistopheles
mrmephistopheles's Avatar
my problem: this should be in TECH TALK.
*moving*
Old 03-26-2004, 03:24 AM   #21
91rusty240sx
91rusty240sx's Avatar
91rusty240sx is on a distinguished road
clean your intake manifold...it does wonders...
91rusty240sx is offline   Reply With Quote
Old 03-28-2004, 06:26 PM   #22
Matt_240
Internet Drifter
still need help.
just changed coolant temp sensor and switched out my distributor with someone elses(& adjusted timing).
still the same. when i hold revs constant in neutral at 2000 and then, rev it up to 3000, the car bogs around 2500. when driving, it bogs when applying mid to high throttle but seems to regain control after it bogs. then it'll bog again after a little while. i dont know what to do anymore. last hope is changing out the fuel injectors and recheck vacuum lines. any other ideas guys? also, there was oil when i took out the hose that connects the valve cover to the intake. thats not normal is it?
Old 03-28-2004, 06:46 PM   #23
Ghettokracker71
KA
Old 03-28-2004, 07:39 PM   #24
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Did you put new wires on the car? How do you know it's not the wires. Bust out the ohmmeter and check your injectors. Should read 10.8 on each one. Good luck!
P.S. How's the exhaust smell?
S13Grl is offline   Reply With Quote
Old 03-28-2004, 07:58 PM   #25
Matt_240
Internet Drifter
yea, put new wires on the car. didnt test them though. i dont have an ohmmeter.
Old 03-28-2004, 10:55 PM   #26
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
Originally Posted by Matt_240
.... i dont have an ohmmeter.
I've seen them run from $15 to $30 for the inexpensive models in most autoparts stores. Multimeters can pay for themselves when troubleshooting.
Need a 96 driver side window switch. Feel free to pm me with a price
radhaz is offline   Reply With Quote
Old 03-29-2004, 04:17 AM   #27
Matt_240
Internet Drifter
any other ideas? these are new wires and i also switched them out with an extra set a shop had.
Old 03-29-2004, 05:37 AM   #28
dunno
dunno is an unknown quantity at this point
Send a message via AIM to dunno
I'd say it was an exhaust problem if you weren't running rich. I would check your intake manifold for clogging, and after that check your exhaust with a fine-tooth comb (not literally. this might induce more problems) from the headers to the muffler.
-Matt
dunno is offline   Reply With Quote
