Old 10-01-2011, 11:31 PM   #1
RyanS13
RyanS13's Avatar
RyanS13 is an unknown quantity at this point
Ka running hot, but not overheating.
So about a couple weeks ago I turned on my ac which never works, but this time it decide to work. I ran it for about ten minutes and I noticed my temperatures start going up. They went up to about 210*.
Ever since then it's been running hotter than usual. Usually it was around 180-200. Now it usually runs about 200-220.
Keep in mind I don't have the stock little ac fan in my car, or a thermostat installed, which might be the problem, but why now and not before? It always ran around 180, even without the ac fan and thermostat.
So what could be going on? I'm trying to get this fixed before it gets worse.
RyanS13 is offline   Reply With Quote
Old 10-02-2011, 12:26 AM   #2
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
INSTALL THERMO / thread.
mattack69 is offline   Reply With Quote
Old 10-02-2011, 01:00 AM   #3
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Man, why arent you using a thermostat ????
SLiDe_WaYz is offline   Reply With Quote
Old 10-02-2011, 01:03 AM   #4
90white240
90white240's Avatar
90white240 is an unknown quantity at this point
Shoot Im thinking about taking mine out too. My car has been overheating.
90white240 is offline   Reply With Quote
Old 10-02-2011, 01:11 AM   #5
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
thats normal casue the ac condenser gets realy hot so some of the heat is absorbed by the radiator look up how ac works if you dont believe me
screw you guys im going drifting
abunai the drifter is offline   Reply With Quote
Old 10-02-2011, 01:17 AM   #6
RyanS13
RyanS13's Avatar
But I haven't turned the ac on since that day, and it still runs consistently hotter.
Old 10-02-2011, 01:21 AM   #7
RyanS13
RyanS13's Avatar
I took it out a long time ago when I was running into problems. Never really had a reason to put it back. But could that cause it to magically run hotter out of nowhere?
Old 10-02-2011, 01:27 AM   #8
abunai the drifter
you may want to bleed the air form the system and thermostat would not hurt, check your fan clutch to see it it loose, pressure test the cooling system and cap, hope this helps
Old 10-02-2011, 01:33 AM   #9
RyanS13
RyanS13's Avatar
I've bled it plenty of times, it hasnt helped. Last time I tried to put a thermostat in it didn't open properly and water started flowing out of the radiator. So I took it out again. But I want to get it back to were ot used to be.
Old 10-02-2011, 01:57 AM   #10
abunai the drifter
try a new fan clutch and pressure test the system to see if you have any leaks and check your cap to see if it at the right pressure
Old 10-02-2011, 02:03 AM   #11
RyanS13
RyanS13's Avatar
Haven't replaced the fan clutch, but the system is good. Doesn't leak or anything. And the cap is almost brand new, it's good, it doesn't push water out of the overflow or anything.
Old 10-02-2011, 02:06 AM   #12
abunai the drifter
ok then that seems to be your problem good luck
Old 10-02-2011, 04:00 AM   #13
keytops
keytops's Avatar
keytops is an unknown quantity at this point
Lol, running your car without a thermostat does NOT make it run cooler. It does quite the opposite actually and then some. I'll try to keep it simple, if you dont believe me google it.
Initially the car will take longer to warm up which will wear out your motor, engines are meant to be hot 180°F±30°F to be exact and engine tolerances are made accordingly. Also your oil needs to be hot to reach the proper viscosity, if your oil is 10-30 its 10w viscosity when it's cold and 30w when its hot. The lower the number the thinner the oil, the thinner the oil the less protection. The oil is not meant to operate at it's cold viscosity for long either, so the oil will break down and become more and more like water.
Ever wonder why the car warms up with no thermostat? You would think that the hot water would flow out of the motor, cool off in your koyo and return to the engine a few degrees above ambient temp. Well even that big @$$ koyo cant break the laws of thermodynamics. The water flows so fast it never has a chance to cool off, even with the thermostat wide open there is still some resistance to let the water cool off. Running with no thermostat greatly decreases the efficiency of the radiator. Think about it like this; with no thermostat the whole system is the same temprature (everything is HOT) vs. a normal system where the motor pumps its hot water to the top of the radiator and sucks in nice cooled water from the bottom.
Lastly a hot engine runs cleaner, all that carbon and soot cant burn up so its just hanging out on your piston tops and against your cylinder walls wearing your rings, all that expensive stuff.
If you dont understand then google running with no thermostat. If it was so good everyone would be doing it. Even the pro race teams use a thermostat, it's not just there to give better emmissions or something.
One thing about thermostats, DO NOT BUY ONE FROM AUTOZONE!!! Not pep boys or o'riley's either. Stant=POS. Those are all cheap chinese junk. when it sticks you'll be sorry. Go OEM... its not much more.
OEM 170° $17 at this link or $30 at the parts counter THERMOSTAT GENUINE NISSAN OEM
Nismo 145° $48 at this link or $80 and 3 days wait time at parts counter
NISMO JDM LOW TEMPERATURE THERMOSTAT
Originally Posted by Hashiriya415 View Post
I'll google it tomorrow and let you know. Please wait.
keytops is offline   Reply With Quote
Old 10-02-2011, 04:05 AM   #14
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
Thumbs up wish they still had the like option, LIKE! and a thumbs up =)
rebornS14 is offline   Reply With Quote
Old 10-02-2011, 09:36 AM   #15
SLiDe_WaYz
SLiDe_WaYz's Avatar
He is definitely correct, when I originally bought my car it had a stock automatic KA, I never could figure out why it would always go to hot when stopped then when cruising it would go under operating temps and would never regulate temperature properly. Well come to find out previous owner took out the t stat, which caused a leaking headgasket and fried piston rings which resulted in me getting a SR.
I would def get a Nismo or OEM T stat because I tried autozone and o Rielly's they never worked properly. Just make you you install it properly. If the t stat doesn't fix it I would def look for a H Gasket leak.
Old 10-02-2011, 11:42 AM   #16
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
keytops is absolutely correct. Running your engine colder is worse than running it hotter.
jacobs13 is offline   Reply With Quote
Old 10-02-2011, 12:57 PM   #17
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
...What? There is so much misinformation here it makes my brain hurt.
The lack of a thermostat will not cause your car to overheat OP. Not possible. That's not to say you should be running without one, but it won't cause the problem you're having. You have another problem somewhere. Check the system for air bubbles, corrosion, clogs, leaks, or a broken pump. Check your temp sensor/gauge to be certain it is functioning properly and not sending you on a wild goose chase. The stock sensor/gauge combo isn't known for it's accuracy in the first place, though on second reading it seems you might have an aftermarket setup. Check it anyway. If all else fails, check compression. Headgasket may have already gone south. There are a lot of factors in this kind of thing.
Prime is offline   Reply With Quote
Old 10-02-2011, 01:55 PM   #18
RyanS13
RyanS13's Avatar
Picked up a thermostat this morning, installed it, And of coarse, the piece of shit isn't working right. The heater never gets hot inside the car, and the temperature started rising pretty fast. It got up to about 210 and I shut it off.
So if the heater never gets hot that means the thermostat is stuck closed or not open enough correct?
Also I looked at the fan clutch, it seems to be spinning pretty slow. You could pretty much reach in there with your hand and stop it pretty easy. So that is a part of the problem too.
But what the hell is up with these thermostats? This is why I took it out in the first place to not have to deal with this bullshit.
Old 10-02-2011, 02:54 PM   #19
waxball88
waxball88 is an unknown quantity at this point
I always boil test my thermo's before they go in.
waxball88 is offline   Reply With Quote
Old 10-02-2011, 02:59 PM   #20
RyanS13
RyanS13's Avatar
I did! It opened! I guess maybe it's just not opening enough? The heater isn't getting hot.
Old 10-02-2011, 03:05 PM   #21
RyanS13
RyanS13's Avatar
Old 10-02-2011, 03:11 PM   #22
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
The fan not spinning fast enough IS your problem. You also have another problem, your thermos... none of them are working right. That problem probably isn't the thermostats but something else. Maybe installation?
VNG704 is offline   Reply With Quote
Old 10-02-2011, 03:13 PM   #23
abunai the drifter
if your heater is not getting hot it means that coolant is not getting to it and you have an air pocket when you bleed it next time trun your heater on and run the car
Old 10-02-2011, 03:14 PM   #24
RyanS13
RyanS13's Avatar
No it was installed properly. Spring facing towards firewall, jiggle thing at 12 o'clock.
Old 10-02-2011, 03:26 PM   #25
Bboy/dorikun88
Bboy/dorikun88's Avatar
Bboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the roughBboy/dorikun88 is a jewel in the rough
Send a message via AIM to Bboy/dorikun88
if your heater isnt getting hot u may have a restriction in your cooling system causing the issue. run your car with the rad cap off at idle and look for flow if it jus blurps coolant everywhere u have a problemo!
Bboy/dorikun88 is offline   Reply With Quote
Old 10-02-2011, 06:45 PM   #26
jacobs13
jacobs13's Avatar
sounds like my friends ka. Got it with no thermo, put one in and it overheats. We soon find out it was the headgasket. the previous owner tried to cover up the fact it had a blown hg
Old 10-02-2011, 07:03 PM   #27
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
no heater could mean blown hg
ddf2006 is offline   Reply With Quote
Old 10-02-2011, 07:27 PM   #28
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
How about bleeding it some more...KAs are notoriously pain in the ass to bleed. It took me literally days to bleed the damn thing.
CLICK HERE!!!
Old 10-02-2011, 07:47 PM   #29
RyanS13
RyanS13's Avatar
I got it figured out. It was the fan clutch. And the thermostat I put in it this morning was garbage. I took it out, swapped out the fan cultch, and it's all good now. Back to right around 180* all the time.
I knew it wasnt the headgasket. Ive dealt with a few head gasket problems on these cars already, it wasnt that. I knew it was something else.
Old 10-02-2011, 07:52 PM   #30
Zenki_516
Zenki_516's Avatar
Trader Rating: (30)
Zenki_516 is an unknown quantity at this point
Feedback Score: 30 reviews
Exactly... bleed it till you think its good, then bleed it again. repeat 6473 times.
Still Thug.
Originally Posted by ka-titties View Post
i'm from Florida so i'm retarded....
Zenki_516 is offline   Reply With Quote
