Old 10-03-2011, 05:06 PM   #1
Slims
Slims's Avatar
Slims is an unknown quantity at this point
Brakes locking up (all 4)
This is driving me bat-shit crazy. My brakes keep locking up, not just one, or two, but all four. I want to say its a pressure issue with the master. the master cylinder was replaced. after this started happening, so unless both are bad??... I can use the ebrake all day, and ill be good. The second I step on the pedal they start to tighten up and get smoking hot. I took the pins out and made sure they were not sticking and re-greased them all. a few were stuck but I pulled them and cleaned it all. gave me no resistance when put back in.
when they locked up today, opened the bleeder valve on the front passenger side. the pressure in the system shot out when i cracked it. after that all 4 spun fine. I took it around again, and it stayed soft for a few miles. after breaking a few more corners, they tightened up again. i went to the front drivers side and cracked the bleeder. same thing happened, pressure shot some fluid out and they turned fine. did this with the back as well, same result.
I don't think the lines are collapsed, since i replaced the front two. it seems like its all pointing to the master, any other suggestions or ideas?
breaks have been properly flushed and bled. still no change.
Slims is offline   Reply With Quote
Old 10-03-2011, 05:11 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Break | Define Break at Dictionary.com
Brake | Define Brake at Dictionary.com
Carry on now.
Old 10-03-2011, 05:21 PM   #3
Slims
Slims's Avatar
I would say something but since the admin even feel like posting BS ill probably get a ban or something, I spell like ass thanks for pointing it out. problem still not solved, post edited.
Old 10-03-2011, 05:35 PM   #4
ThatGuy
Admin Asshole
ThatGuy's Avatar
No ban. You came here asking for help fixing your car.
I simply started by trying to help fix you.
Good luck.
Old 10-03-2011, 05:43 PM   #5
S14DB
AFC #1
S14DB's Avatar
Was the new master bench bled?
Old 10-03-2011, 06:12 PM   #6
Slims
Slims's Avatar
Good luck.
Point taken, no ones going to take someone spelling retarded seriously. Just on edge after getting no where with this. my bad. thanks.
@S14DB: yes it was.
Old 10-04-2011, 05:16 PM   #7
Slims
Slims's Avatar
changed the master again. it lasted a little bit longer but still locked up on me. lines have been changed, front calipers changed, master bench bled, lined bled, new master. Im leaning towards a rebuild kit for the calipers, but im at a loss.
Old 10-04-2011, 07:53 PM   #8
S14DB
AFC #1
S14DB's Avatar
Same brand master? Sounds like the drain back isn't working when you release the pedal. Did you re adjust the pedal when you replaced the MC?
Old 10-04-2011, 08:12 PM   #9
carmaniac1993
carmaniac1993's Avatar
carmaniac1993 is on the path to ruincarmaniac1993 is on the path to ruin
did you put the correct fluid in it?
carmaniac1993 is offline   Reply With Quote
Old 10-04-2011, 08:43 PM   #10
cotbu
cotbu's Avatar
Have you tried adjust the brake booster piston/rod/7mm nut? Normally, you don't do this but it's probably your problem. try looking into at least.
Old 10-05-2011, 03:40 AM   #11
Slims
Slims's Avatar
Cotbu: I'll have to check it. I have a fair amount of play in the pedal so I'm not sure.
Maniac: 100% on that one
S14DB: I'll check that as well, the only thing I'm skeptic on is it pushes down pretty par the first few pumps driving. You think if it's not fully disengaged it could be restricting flow back?
Old 10-05-2011, 07:49 AM   #12
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I would say adjust your pedal / push rod. You'll want to adjust your brake lights to activate once the slightest sign of braking pressure is felt.
Old 10-06-2011, 12:25 PM   #13
Slims
Slims's Avatar
Adjusted the break pedal since the push-rod coming from the booster was in to tight of a place to adjust. Bled the lines again, and the fronts don't lock anymore, they rub a bit but never get tight. The back is locking up worse though, it use be be able to be turned with some good elbow grease, locked now.
Gona try to do a pressure flush on all the lines, rebuilt calipers all the way around and see where I get.
Old 10-13-2011, 01:34 PM   #14
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
Willing to bet its the booster. Ive heard of this happening with cars swapped form auto to 5sp, but can still happen with a bad 5sp booster. my 2 cents.
スカイライン
vw203 is offline   Reply With Quote
Old 10-13-2011, 02:01 PM   #15
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
I have a feeling its the push rod. I had the same problem with my previous hatch. There is a special tool that will allow you to do the job.
Slammed Assassin is offline   Reply With Quote
Old 10-14-2011, 06:01 AM   #16
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
I had a problem with one of my calipers sticking, turned out when I went to rebuild the front calipers I found that the bracket the pad is seated in was a bit rusty and the pad wasn't being allowed to smoothly go in and out. Took some sand paper to it and smoothed it out, never a problem since.
onehundredoctane is offline   Reply With Quote
