Old 10-06-2011, 03:35 PM   #1
jakez
jakez is an unknown quantity at this point
Horrible compression test results?
So my redtop overheated pretty badly the other night because I was driving a lot harder than normal and forgot to turn the fans on. Saw white smoke coming out of the exhaust at a red light and immediately jumped on the highway so I could keep it cool nonstop on the 20 minute ride home where I had some coolant/water waiting.
Dry test
1. 135psi
2. 145psi
3. 125psi
4. 138psi
Wet test (squirt of oil in each cylinder)
1. 160psi
2. 178psi
3. 175psi
4. 177psi
For all tests I cranked it 6 times, maybe should've done like 10 and gotten a higher reading. Spark plugs nice and tan. Engine was very warm also.
At least 2 adjacent cylinders aren't low, so hopefully the headgasket isn't totally fucked? As soon as I popped the radiator cap off (and let the steam and shit rush out) and started pouring coolant in the cars idle and temp was fine. And the car also seems to pull the same except in the top of 3rd/4th/5th it kind of breaks up a bit sometimes.
'93 240SX SE Coupe SR20DET Red Top / '06 300C SRT-8 / '03 E55 AMG
jakez is offline   Reply With Quote
Old 10-06-2011, 03:38 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
What do you mean Wet and Dry Test? Dropped oil in the cylinder? If thats what you meant, just having a blown HG wouldnt bump your compression.
CLICK HERE!!!
Old 10-06-2011, 08:05 PM   #3
jakez
Yeah wet test as in a squirt of oil in the cylinder. I thought they were called dry/wet. You're saying the head gasket should be fine? 125 seems awfully low
Old 10-06-2011, 08:14 PM   #4
s14fbs
s14fbs's Avatar
s14fbs is an unknown quantity at this point
Send a message via AIM to s14fbs
sounds like u need rings reguardless with that low of a compression
u should do a leak down test
and maybe invest in a fan controller
s14fbs is offline   Reply With Quote
Old 10-06-2011, 08:34 PM   #5
fliprayzin240sx
I'm saying a blown HG is the least of your worries. When you drop oil in the cylinder, it doesnt seal up the HG, just the rings. So just the fact that it bumped up means its sealing the rings.
Disconnect the crankcase hose to the T on the valvecover...I got a feeling you got some smoke coming out of there, or atleast got air pulsating out. That means air is getting thru the rings and pressurizing your crankcase...that means rebuild time.
CLICK HERE!!!
Old 10-07-2011, 12:06 AM   #6
Dpacro001
Dpacro001 is an unknown quantity at this point
buy a new engine
Dpacro001 is offline   Reply With Quote
Old 10-08-2011, 12:02 AM   #7
dpacro
dpacro is an unknown quantity at this point
I have a sr20det red top long bloc ready to go if you need.
dpacro is offline   Reply With Quote
Old 10-11-2011, 09:17 PM   #8
jakez
Ok leak down test results are below.
Cyl #1 57%
Cyl #2 68% spark plug didn't look too good, kind of dark with light tan specs all over it, other 3 plugs look fine
Cyl #3 59%
Cyl #4 56%
I took the oil fill cap off and could hear air coming out of there. Didn't hear anything out the exhaust.
Car is drunk on coolant, I'm refilling it after almost every drive, and when I fill it to the neck and squeeze the radiator hose it bubbles every time I squeeze instead of releasing the bubbles once and for all, is that a problem? No coolant in the oil or oil in the coolant though. Startup is also really rough now and the engine shakes more than normal at startup and at idle.
Any ideas what I'm looking at replacing?
Old 10-11-2011, 09:37 PM   #9
jakez
Also this was done with a tester from harbor freight that sets at 15psi, not sure if that makes a difference..
Old 10-12-2011, 03:03 PM   #10
fliprayzin240sx
Yah, that engine's done. Time for a rebuild, new HG and fresh piston rings.
CLICK HERE!!!
Old 10-12-2011, 03:15 PM   #11
jakez
Ok so, trying to understand what I need to purchase to get it into good shape.
1. OEM head gasket
2. OEM pistons
3. OEM piston rings
4. OEM valve stem seals
Should be good to go with that hopefully.
Old 10-12-2011, 03:45 PM   #12
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
You don't necessarily need new pistons. But yeah, rings, stem seals, and a head gasket sounds right. Also, if you have oem head studs, you'll need to replace those.
Hoffman5982 is offline   Reply With Quote
Old 10-12-2011, 04:01 PM   #13
fliprayzin240sx
Since you're pulling the rods off, might as well get some fresh bearings too and the cylinder could probably use some honing since you're slapping fresh rings.
CLICK HERE!!!
Old 10-12-2011, 04:39 PM   #14
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Also, if the engine's ever been overheated ... probably should look at getting the block decked and the head resurfaced or your new HG isn't going to seal properly and you'll just have to do it all again...
Darren is offline   Reply With Quote
Old 10-12-2011, 05:03 PM   #15
KOME
KOME's Avatar
KOME is an unknown quantity at this point
Those numbers seem way far off from one another. In wet and dry.
Wets only got gonna temp seal your rings man. Just hope it's actually just your rings. Not that that's the best news.
KOME is offline   Reply With Quote
Old 10-12-2011, 05:34 PM   #16
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
1. OEM head gasket
2. OEM pistons
3. OEM piston rings
Why not just upgrade that shit while you're at it?
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 10-12-2011, 05:54 PM   #17
jakez
Never planned on dumping build kind of money into this SR motor,but never planned on screwing up and overheating either lol. If I'm going to drop it off at a shop to have work done it'll be for a 1jzgte engine like my buddy just did with the same car. But I don't want something that powerful in this type of car, so right now I'm just looking at getting it running nicely again.
