Old 10-13-2011, 06:40 AM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Need SR downpipe- Suggestions?
1. I need a new 3" downpipe for an s13 sr going into and s14. What do you suggest? How are the megan ones with flex pipe? Anything else I should look at? I'm not afraid to spend decent money if REQUIRED but I also do not believe in buying just for a brand name.
2. Do all 3" downpipes reduce to 2.75 inches at the turbo side? Is this normal?
Thanks
gotta240 is offline   Reply With Quote
Old 10-13-2011, 07:43 AM   #2
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I have one for sale that came off my S15 SR. It never sold when I parted it all out. It's a Blitz and has very good ground clearance... $100.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 10-13-2011, 08:00 AM   #3
slim
slim's Avatar
slim is an unknown quantity at this point
^^^ thats a smoking deal! id jump on that if i were u. my experience has been that if u dont spend the money on good parts now, u will have to at some point. i had a cheap downpipe on mine then upgraded to tomei turbo elbow and the crappy downpipe hit frame rail and made a bunch of noise. picked up a rs*r downpipe and not only was it bigger than the cheapy it was routed better and didnt hit frame at all. most of them do bottle neck right after the turbo. i think its for access to the three bolts but i dont know. i ve always heard megans exhaust parts have trouble sealing but that might be due to the gaskets they supply.
slim is offline   Reply With Quote
Old 10-13-2011, 08:50 AM   #4
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
The only downpipes I know of that don't have the 2.75 entry at the turbo are the elbow-dp, two in one setups. Don't know if you can really call that a dp. $100 for a blitz dp is a good deal considering all name brand dp cost alot more. That said, I'd like a flex in mine.
VNG704 is offline   Reply With Quote
Old 10-13-2011, 10:48 AM   #5
colombianbryan
colombianbryan's Avatar
colombianbryan is an unknown quantity at this point
to be honest i dont think downpipes have a big difference between brands. they are all 3 inch for turbo at least from what i know. i mean i have a circuit sport dp which is the only part of my car that i went cheap on and have no problems. has great ground clearance and looks like any other dp. i rode in my friends 240 and he had a greddy dp and both sounded the same.
I love drifting into curbs and guardrails
colombianbryan is offline   Reply With Quote
Old 10-13-2011, 12:45 PM   #6
VNG704
VNG704's Avatar
The only difference in dp is clearance. That and some of the cheap ones like the no-name ebay ones, for example, use cheaper thin metal and thinner flanges. As far as sound goes, I think that's determined by the muffler and resonator if equiped. There isn't much to research into when buying a dp. It's all been tried and done, search the topic. Megan would be fine if you're looking at that, it does have a flex as you say, which I personally like. Or the above Blitz, they make great products and he's selling it cheapo.
Old 10-13-2011, 12:48 PM   #7
slider2828
slider2828's Avatar
Blitz as mentioned is mandrel bent, so is one other company. Other than that.... its the same.
Turn and Burn!
Old 10-13-2011, 12:49 PM   #8
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
i have a blitz downpipe on my s13 for years, and it has awesome clearance. my car is slam and it doesnt hit anything unless its a speed bump
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-13-2011, 01:09 PM   #9
!Zar!
!Zar!'s Avatar
Any 3" sr downpipe will work.
The standard down-pipe with the flex location at the bottom is alright if your car isn't horribly low.
A vast majority of down-pipes have a slightly narrow neck, but it isn't anything to worry about.
Right now my car has an XS Engineering down-pipe which gets rid of the cat and mounts directly to the catback.
Ground clearance is pretty good, and it gets rid of a flange, so one less thing to catch on the ground/leak.
http://www.frsport.com/XS-Engineerin...ET_p_9402.html
Old 10-13-2011, 01:15 PM   #10
Emeru
Emeru's Avatar
Emeru is an unknown quantity at this point
If your car is super low, dont get a flexpipe, eventually from scraping it will create a hole and you will have a major exhaust leak,
like everyone says go with the Blitz from broadfield cant beat the price,
i personally bought an HKS and the quality for being HKS really sucked.
Emeru is offline   Reply With Quote
Old 10-13-2011, 10:21 PM   #11
95BoostedS14
95BoostedS14's Avatar
95BoostedS14 is an unknown quantity at this point
I have a Megan racing dp on my s14 sr, good clearance and no complains on it so far.
95BoostedS14 is offline   Reply With Quote
Old 10-13-2011, 10:27 PM   #12
S14Lee
S14Lee is an unknown quantity at this point
i have a cx racing downpipe on my s14 sr and have no complains for the price i paid for it
S14Lee is offline   Reply With Quote
Old 10-13-2011, 10:30 PM   #13
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Isis is good and nice for the price, I have a mtx trust downpipe and I have no complaints
SLiDe_WaYz is offline   Reply With Quote
Old 10-13-2011, 11:15 PM   #14
dopplganger1
dopplganger1 is an unknown quantity at this point
I have an apexi thats got good ground clearance and there is always the pbm cobra flex pipe which i'm waiting for now
dopplganger1 is offline   Reply With Quote
Old 10-14-2011, 12:25 AM   #15
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
i have an s13 megan that i dont like. the holes to bolt it up are a little off and it creates a small exhaust leak.
nissansrdub is offline   Reply With Quote
Old 10-16-2011, 12:47 AM   #16
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Powered by Max Cobra 100% If you don't buy the Blitz from Toby.
I have one and it is awesome, the vertical flex is the only way to do it. The horizontal flex is pointless and decreases ground clearance tremendously IMO.
om3ga is offline   Reply With Quote
Old 10-17-2011, 10:24 AM   #17
gotta240
How much does that PBM one go for?
Old 04-18-2012, 02:58 PM   #18
Conrad 2NR
Conrad 2NR's Avatar
Conrad 2NR is an unknown quantity at this point
PBM is out of stock
www.motoredge.wordpress.com
Conrad 2NR is offline   Reply With Quote
Old 04-18-2012, 04:42 PM   #19
usdm180sx
usdm180sx's Avatar
Are you guys sure about that? I have the Blitz and clearance SUCKS. It dips down for about a foot and a half then dips up an inch. This causes my car too scrape really bad. I don't know what the hell Blitz was thinking when they designed it. I would suggest the PBM cobra when they get more in stock or if you don't wanna spend extra get an RS-R or Espelir downpipe. They tuck pretty nicely. I just bought an RS-R.
-Norm!
Old 04-18-2012, 04:48 PM   #20
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I have an HKS 3" downpipe. I'd say quality is pretty damn good. Not sure how other dp's compare in respect to the frame rail but mine is about 1/2 inch lower than the frame rail itself at its lowest point.
Old 04-18-2012, 05:26 PM   #21
Conrad 2NR
Conrad 2NR's Avatar
Wouldn't downpipe clearance also depend on the elbow positioning and how high up the bracket to the gearbox is?
Someone mentioned the Isis combo had good ground clearance, but I really want the PBM with flex.
Old 04-18-2012, 06:27 PM   #22
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
ISIS Downpipe, ISIS Testpipe, Buddy Club Spec 2.
Sits with the frame rails.
Pinggg is offline   Reply With Quote
Old 04-18-2012, 08:34 PM   #23
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
if You could afford to make oval equivalent of 4" tube custom downpipe or all the way to the muffler exhaust (the bigger the better) it'll be the best you can have I think.
cured13 is offline   Reply With Quote
Old 04-18-2012, 08:49 PM   #24
Boost_Fiend
Boost_Fiend is an unknown quantity at this point
i have an isis elbow and downpipe w/ cat delete and it fits great with my custom catback never had a problem. best set up for the $$ imo.
Boost_Fiend is offline   Reply With Quote
Old 04-18-2012, 08:56 PM   #25
Conrad 2NR
Conrad 2NR's Avatar
I already have the Buddy Club Spec 2.
What turbo elbow are you using?
Old 04-19-2012, 06:49 AM   #26
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
Get something with a flex on it to relieve some stress as well as vibrations. I hear ppl have problems with their turbos getting loose cuz they dont have the flex pipe. I bought a megan but it alread3 has a huge leak from scraping.
c-los13 is offline   Reply With Quote
Old 05-16-2012, 10:13 PM   #27
Conrad 2NR
Conrad 2NR's Avatar
THIS + Isis elbow
msglngth
