Old 10-22-2011, 12:03 AM   #1
boost addict
boost addict's Avatar
boost addict is making a name for him/her selfboost addict is making a name for him/her self
driveshaft and quick release questions
so i searched but couldnt find a definitive answer, my cars getting tuned friday and im looking toward 400+ whp. i cant really see the stock driveshaft holding it since it has that rubber joint. what are the s13 driveshafts good for? also i just ordered a nrg 2.5 qr and dont have p/s so im wondering if the extra strain will cause it too develop a lot of play
boost addict is offline   Reply With Quote
Old 10-22-2011, 10:48 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
It will hold, rear end and shfts will handle 600hp.
CLICK HERE!!!
Old 10-22-2011, 11:12 PM   #3
harrypotter
harrypotter is an unknown quantity at this point
I don't get it! Are you worried about your steering shaft or your drive shaft?
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 10-23-2011, 09:46 AM   #4
boost addict
Haha my actual drive shaft and also the strain of no p/s on a a quick release
Old 10-23-2011, 01:29 PM   #5
boost addict
And what about launching the car with radials or even slicks? I'll prob get a 1 piece ds by then but I'm jw
Old 11-13-2011, 03:12 PM   #6
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
even with slicks, your main concern wont be the driveshaft, it will be the stock axles/CVs snapping
ShakotanGazelle is offline   Reply With Quote
Old 11-13-2011, 05:56 PM   #7
trsebert
trsebert is an unknown quantity at this point
the release should be fine.
trsebert is offline   Reply With Quote
Old 11-13-2011, 06:38 PM   #8
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
You can get a solid steel driveshaft for around $300. It can tighten up throttle response slightly. An aluminum one piece driveshaft can enable you to drop 8 pounds of rotating mass and costs in the $400 range. I just ordered a one piece aluminum driveshaft on Friday, and already had one in my last car (supercharged Mustang Cobra)
Seraphim38 is offline   Reply With Quote
Old 11-13-2011, 06:42 PM   #9
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
dude stock driveshafts are tough as hell. you will blow your tranny to pieces before your DS goes. So when you go Z32 trans you will get the 1 piece DS that comes with the kit and you're all done!
JSimpson is offline   Reply With Quote
Old 11-13-2011, 07:19 PM   #10
Anon9mouz
Anon9mouz's Avatar
Anon9mouz is an unknown quantity at this point
See I'm having problems with mine when I can feel it in my seat at certain speeds or in I turn to the right for dome reason. I think my carrier bearing is going out and from I heard it would be an endless process of having to replace them so I would assume its cheaper just getting the 1 piece. So idk but I think ima have to get a 1 piece from the DS shop on eBay. Seems like it should eliminate my problem and help me in the long run lol
Sent from my PG86100-EVO3D-using Tapatalk
Anon9mouz is offline   Reply With Quote
Old 11-13-2011, 08:11 PM   #11
JSimpson
Oh yeah if your middle bearing is loose then that DS is shot. But regardless, HP did not cause that. 20 years of age did. Clutch kicks are much more efficient with a 1 piece DS...
Old 11-13-2011, 08:13 PM   #12
Anon9mouz
Anon9mouz's Avatar
True u r right so that's what ima try to get for myself for Christmas lol or my bday 10 days later
Old 11-16-2011, 10:26 AM   #13
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Don't worry about the quick release, I got a couple friends to get the NRG quick release in their cars after they saw my set up, they have swapped hondas with no power steering and the quick release they have are fine with no play, they've had these set ups for three years.
Mishkin_707 is offline   Reply With Quote
