Old 03-28-2004, 01:03 PM   #1
heated heavy
heated heavy's Avatar
heated heavy is an unknown quantity at this point
Question Wheel Fitment Problem
My rims I just picked up are 15x7 with -2 offset and they stick out about 1" from the wheel well. I also have some 15x6.5 with a +7 offset for the front.
My question is in order to not make it look crazy gangbanger style should I just drop some excessive negative camber to tuck it in a bit and if I do do you think it might rub a bit on either my coilovers or the fender??
Also, should I stretch my tires a bit to tuck it in a bit even more?? I was thinking 195/45-15 tire sizes.
Please help out a wheel newb.
heated heavy is offline   Reply With Quote
Old 03-28-2004, 08:40 PM   #2
Legacy
Legacy is an unknown quantity at this point
HAHAHAHHA! It's not gangbanger style, it's called poor taste! Sorry, I have just never heard a so cal local linking overly nasty negative offsets to gangs.
Legacy is offline   Reply With Quote
Old 03-28-2004, 08:42 PM   #3
Legacy
oh yeah, and negative camber shouldn't create rubbing issues on the coilover. You'll probably have to run a ton of negative camber as well as roll your fenders. But actually, it probably wont be that bad.
Old 03-28-2004, 09:04 PM   #4
heated heavy
obviously you have never seen a crazy lowrider with wheels sticking out, but maybe im exagerating a bit.
do you think ill have to put spacers for the front wheels to even it out a bit?
