Old 11-03-2011, 07:28 PM   #1
Touge180sx
Touge180sx's Avatar
Touge180sx is an unknown quantity at this point
SR20 Running MAP atmosphere iacv?
Im running a map sensor on my S13 SR20 and am wondering if I can delete the iacv tube off the cold pipe and just put one of these filter/breather on the iacv?
Is the iacv like a check valve so air will not flow out of it under boost?
Any help would be mucho appreciato!
Touge180sx is offline   Reply With Quote
Old 11-04-2011, 08:49 AM   #2
cotbu
cotbu's Avatar
No it's not. Completely delete it with a plate or cap it off temporarily.
Where's your map sensor located?
Old 02-22-2012, 01:25 PM   #3
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
im also wondering if i can just run it without connecting to the cold pipe. its going to be a daily driven car so reliability is an issue. i'll be running a map sensor with AEM EMS..
R@ddy is offline   Reply With Quote
Old 02-22-2012, 01:26 PM   #4
Silvia352
Silvia352 is an unknown quantity at this point
cap the intercooler fitting and delete the IAC itself with a delete plate.
the IAC needs to read incoming air (through and IC pipe) not an open breather
Silvia352 is offline   Reply With Quote
Old 02-22-2012, 01:29 PM   #5
R@ddy
Trader Rating: (32)
ok. and just adjust the idle at the throttle body and the EMS?
Old 02-22-2012, 01:33 PM   #6
Silvia352
your AEM with have a cold start/warm start tuning table.
Old 02-22-2012, 04:24 PM   #7
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
as we are on this topic and without need to start a new thread ( sorry for the threadjack OP ) is this option viable with a PowerFC on a MAP setup ?
Big Zee is offline   Reply With Quote
Old 02-22-2012, 04:56 PM   #8
rellik27
rellik27 is an unknown quantity at this point
I would like to know more info as well I dont have my iacv plugged in. I idle at around 1300 I just have it there not connected.(power fc d jetro)
rellik27 is offline   Reply With Quote
Old 02-22-2012, 08:30 PM   #9
Silvia352
You can run map sensor on anything, even stock ecu. It's called speed density.
map sensor is an option on power FC as well.
Old 02-22-2012, 09:04 PM   #10
Chris28
Chris28 is an unknown quantity at this point
You need a piggyback or standalone to run speed density. Stock ECU doesn't support it by itself.
Chris28 is offline   Reply With Quote
Old 02-22-2012, 09:16 PM   #11
Silvia352
You are correct, my example was off. My wording was meant you can run map on any form of piggy back it doesn't have to be a full standalone.
