Old 11-13-2011, 04:11 PM   #1
Davetheslave
Davetheslave is an unknown quantity at this point
VQ37VHR 240sx mount kit?
Does anyone know of a vq37vhr mount kit for a 240sx. I got a full motor swap from a rear ended nismo edition 370z(thats right the 350hp version) and am looking for a suitable install kit, and maybe a link to a install guide. I can't seem to find anything.
Davetheslave is offline   Reply With Quote
Old 11-13-2011, 04:17 PM   #2
xxjohns14xx
xxjohns14xx's Avatar
xxjohns14xx is an unknown quantity at this point
idk..
but i definitely vote you try and keep that auto rev match feature
xxjohns14xx is offline   Reply With Quote
Old 11-13-2011, 04:20 PM   #3
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
People will bow to you if you pull that off.
Please have a good, solid chassis to start with.
Marcus is offline   Reply With Quote
Old 11-13-2011, 04:21 PM   #4
xxjohns14xx
if you could get your hands on the whole 370 put the ENTIRE 370 harness in it and you will need the 370 pedal because its electronic
Old 11-13-2011, 04:23 PM   #5
Davetheslave
I will definatly do everything I can to keep every feature. I have a mint black 96 zenki shell I bought to swap. I will defiantly post a sweet detailed build thread once it's in motion.
Old 11-13-2011, 04:25 PM   #6
xxjohns14xx
thanks i will be waiting
Old 11-13-2011, 04:29 PM   #7
sexcii-zenki
sexcii-zenki's Avatar
sexcii-zenki is an unknown quantity at this point
niiiiice i def wana c this good luck
sexcii-zenki is offline   Reply With Quote
Old 11-13-2011, 06:10 PM   #8
jr_ss
I would imagine that the VQ35 mount kit would be the same, but don't quote me on that.
Old 11-13-2011, 06:28 PM   #9
Davetheslave
I read some where they were different but most of the stuff on the net is speculation :-(
Old 11-13-2011, 06:51 PM   #10
sexcii-zenki
i dunno where spring hill is but if ur close ill def let u try my mount kit its a mckinney n i know it fits the de and hr motors so hey u never know...
Old 11-13-2011, 07:06 PM   #11
Davetheslave
It's in Florida in hernando county. Pretty far from you. Thanks though.
Old 11-13-2011, 07:19 PM   #12
sexcii-zenki
hey i tried if not hiot up zfever im pretty sure they will know if it fits or if they can fab u up a kit
Old 11-13-2011, 07:22 PM   #13
Davetheslave
They are like 30 minutes from me. Id rather do it myself but I'm limited with aftermarket support so that may be the route I have to go. I know Martin and his guys do amazing work.
Old 11-14-2011, 09:07 AM   #14
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
The starter location will interfere when using the normal VQ35 swap kits. The swap can be done... pretty similar to the VQ35 swap with the slight differences such as a "must keep" drive by wire setup, Starter interference, Wiring, etc.
Coolwhip is offline   Reply With Quote
Old 11-14-2011, 09:17 AM   #15
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
have fun trying to fit the humungous timing solenoid against the fire wall....
but anything is possible with enough time and money
nd240sx3 is offline   Reply With Quote
Old 11-14-2011, 01:14 PM   #16
Davetheslave
Looks like it's back to the junk yard to get the gas pedal with throttle cables and I'll have to do quite a bit of firewall bashing to clear the starter. I read somewhere there maybe interference with the steering as well. I might have zfever tackle the wiring. I emailed wiring specialties and they don't offer this service yet.
Old 11-14-2011, 06:13 PM   #17
Davetheslave
Bad news. They had the pedal but the throttle cables are cut
Old 11-14-2011, 06:28 PM   #18
fckillerbee
fckillerbee's Avatar
^haha...umm....yeah.
that picture is dope! Why don't you just have a fab shop put it all together/ Make the mounts, and then have a wiring dude do it...like mr jeffe jordan.
Old 11-15-2011, 02:43 AM   #19
TigerII
TigerII is an unknown quantity at this point
Glad I saw this thread. I'm sure I would have ditched the throttle pedal in my haste to regain space once I pick up my motor.
TigerII is offline   Reply With Quote
Old 11-15-2011, 05:14 AM   #20
Davetheslave
Because doing it yourself is more rewarding and costs a lot less.
Old 11-15-2011, 05:55 AM   #21
Shift n Drift
Shift n Drift has a little shameless behavior in the past
a WHOLE LOT less
Shift n Drift is offline   Reply With Quote
Old 11-15-2011, 05:59 AM   #22
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
Throttle cable?
I thought it was DBW?
atutt is offline   Reply With Quote
Old 11-15-2011, 06:50 AM   #23
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
maybe he means throttle wires?
if you make this happen, im in for build thread
Tantwoforty is offline   Reply With Quote
Old 11-15-2011, 06:56 AM   #24
ZenkiCam
ZenkiCam's Avatar
ZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really niceZenkiCam is just really nice
Send a message via AIM to ZenkiCam
You said the throttle wires were cut... that doesn't matter... get each end and you can use your own wire in between.. don't let that stop you. Nothing a little splicing soldering and heat shrinking can't fix
ZenkiCam is offline   Reply With Quote
Old 11-15-2011, 07:22 AM   #25
Davetheslave
I meant the wires sorry
Old 11-15-2011, 08:03 AM   #26
nd240sx3
nd240sx3's Avatar
not to sound like i know everything... just trying to help u out! but u sound like u have no clue what so ever about what u are getting yourself into...i am actually finishing up my vq35hr build! http://zilvia.net/f/chat/397304-vq35hr-s13-build.html
i know u are doing the 37vhr but they are very similar and the starter is not even close to the firewall so u don't have to bash it in for that.... that big thing on the back of the engine, which will be in ur way is the VEL-assembly actuator ...the starter will actually sit on the steering rack.... its a pain in the ass... i have gone thru this.. if u read my build thread u will see i went and did RHD conversion because i didn't want to mess with modifying the sub frame or lowering the sub frame like the ls1 guys did in the beginning....for suspension geometry reasons. but i later heard (not sure if its true or if it will work on the 37) but i was told that to relocate the starter on an hr to the opposite side like the de u can swap the mid and sub oil pans from the hr to the de... but i also don't know if the hr or de trans is used...also i went with the factory ecu flashed with UPREV that removes BCM and NATS system... and u can keep the DBW setup which is what i am doing, the 350z pedal actually bolts right up to the s13 stock location, but u have to bend the pedal up a lil from hitting the floor... just my 2 cents...
Old 11-15-2011, 08:35 AM   #27
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
custom mounts will need to be made to answer ur question.
...any local fabricators in ur area should be able to pull something off
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 05-07-2012, 10:21 AM   #28
bluezenkis14
bluezenkis14 is an unknown quantity at this point
Please put up the whole build if you pull it off I've been thinking about doing this for about a month now and was thinking about how sweet it would be
bluezenkis14 is offline   Reply With Quote
Old 05-07-2012, 11:06 AM   #29
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
I was just throwing around the idea a while back about doing an VQ35HR swap into an S14, but you basically need an entire 350z to pick all the parts from. Good luck! I'm anxious to see this done.
onehundredoctane is offline   Reply With Quote
Old 05-07-2012, 11:46 AM   #30
Sideways_Saturdays
Sideways_Saturdays is an unknown quantity at this point
saw nd240sx3's build in stages in person...its doable, but break out the tylenol early...i also heard tell from him about a custom linkage for the starter, like a remote mount setup...but it was all custom 1off...food for thought...good luck with this. Also are you trying to keep the nismo diff?
Sideways_Saturdays is offline   Reply With Quote
