Old 04-06-2004, 12:56 PM   #1
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
300zx brakes vs. Skyline brakes
Is there really a difference between the two other that a slight apperence?
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 04-06-2004, 12:59 PM   #2
ICKY
Account Closed
ICKY is an unknown quantity at this point
Send a message via AIM to ICKY
as far as i know, there is none.
ICKY is offline   Reply With Quote
Old 04-06-2004, 01:06 PM   #3
s14unimog
s14unimog's Avatar
Trader Rating: (22)
Thats exacty what I thought, but someone said there is, also are they the same as JDM s14 brakes?
Old 04-06-2004, 01:07 PM   #4
OptionZero
OptionZero's Avatar
yup they are
Old 04-06-2004, 01:10 PM   #5
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
jDm tYte its the hOtness y0 fo' sure!!!
So bascially other than bragging rights of "yo I got dem skyline brakes..." theres not point to them? If they are the same,then the 300zx 30mm brake pads work?
Ghettokracker71 is offline   Reply With Quote
Old 04-06-2004, 03:26 PM   #6
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
There is a difference between the GT-ST and GT-R brakes if you want to be specific. The GT-R uses a brembo. 300zx uses a 280x30mm rotor size.
Upon searching, here's some better size info:
350Z standard brakes:
Rotor size 296mm x 24mm
Nissan 2 pot calipers, same pads as 91-02 Maxima
300ZX (Z32) brakes:
Rotor size 280mm x 30mm
Nissan/Sumitomo 4 pot calipers
R32 GT-R brakes (sold through Nismo USA as "Skyline" brakes):
Rotor size 296mm x 32mm
Nissan/Sumitomo 4 pot calipers, same pads as Z32
350Z track model brakes:
Rotor size 324mm x 30mm
Brembo 4 pot calipers, same pads as R33/R34 GT-R, BMW 850
http://www.zilvia.net/f/showthread.p...ne+gt-r+brakes
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 04-06-2004, 03:48 PM   #7
Ghettokracker71
Talking
(skyline)296mm x 32mm uses the same pad as (300zx)280mm x 30mm ??? Hmm are you sure?
Anybody know about clearence issues with the skyline caliper vs. Z32 or brake lines? How to hook it up...
Because of the larger caliper size the skyline caliper SHOULD disspate heat faster even though its using the same pad??
Hmm...Z32 rotors work with skyline calipers?
Last edited by Ghettokracker71; 04-06-2004 at 03:49 PM.. Reason: another question/thingy
Old 04-06-2004, 04:13 PM   #8
Salty_X
Salty_X is an unknown quantity at this point
I didn't see where that was said, but I wouldn't doubt it. The calipers are identical appearance-wise, the Skyline caliper is just 2mm wider to accomodate the rotor.
The calipers are 2mm wider, so clearance is similar. Most wheels that clear Z calipers will clear Skyline calipers. They hook up the same as Z calipers.
The caliper itself is only a fraction larger (only in width) than the Z caliper. The rotor on the other hand will have better heat capacity (because of increased mass) and quicker heat dissipation (because of increased surface area).
Probably, but what's the point? There is no point. Why pay extra money for a 4-piston caliper that's designed for rotors 2mm wider, when you can get an identical 4-piston caliper that's designed for the rotor you'll be using. The Skyline rotor is the best part of it's braking system, and if you're not using that then it's not worth it to get Skyline calipers IMO.
Salty_X is offline   Reply With Quote
Old 04-06-2004, 05:27 PM   #9
zombieman
zombieman is an unknown quantity at this point
i notice that getting the calipers from a skyline is much cheaper than getting the ones off a z32.... they have a complete set on ebay right now going for $250 http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT and only one person bid on it.
zombieman is offline   Reply With Quote
Old 04-06-2004, 09:13 PM   #10
Ghettokracker71
Theres where he said it ^^
And thanks salty for the response,I geuss to get them on a 4 lug you have to have them redrilled :-\
Old 04-06-2004, 09:18 PM   #11
s14xman
s14xman's Avatar
s14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of light
Send a message via AIM to s14xman
my friend swaped skyline brakes on his z32 and he needed a spacer for his stock wheels. so i think there is a difference in wheel clearence. Im really glad he got them because now i have his old brakes and his old wheels=)
FRontline (marinating since 02)
s14xman is offline   Reply With Quote
