Old 01-07-2012, 10:39 PM   #1
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
S14 Leaking Massive Gas! HELP!
JasianBlazin is offline   Reply With Quote
Old 01-07-2012, 10:41 PM   #2
Sileighty_85
Sileighty_85's Avatar
does it only leak when running?
If so, then you might have a loose line at the tank.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-07-2012, 10:43 PM   #3
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Are you sure you installed the fuel pump correctly and you didn't damage anything?
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 01-07-2012, 10:51 PM   #4
JasianBlazin
Trader Rating: (24)
Old 01-07-2012, 11:01 PM   #5
chetos13
chetos13's Avatar
chetos13 is an unknown quantity at this point
Send a message via Yahoo to chetos13
It's maybe leaking from the fuel lines that connect to the fuel pump
TEAM ELITE
chetos13 is offline   Reply With Quote
Old 01-08-2012, 09:36 AM   #6
OLDSCHOOLRICE
OLDSCHOOLRICE's Avatar
OLDSCHOOLRICE is an unknown quantity at this point
The rubber hoses that connect to the pump start to rot. When you replaced the pump the return hose from the pump to the hard lines probably cracked/tore. This would explain why the engine still runs but you’re dumping fuel on the ground. If I remember correctly the rubber hose section is probably only about 12” long.
OLDSCHOOLRICE is offline   Reply With Quote
Old 01-08-2012, 11:16 AM   #7
jr_ss
My bet is you didn't tighten down a connection at the fuel pump/tank fittings when you changed the pump out out...
Old 01-08-2012, 05:25 PM   #8
JasianBlazin
Trader Rating: (24)
Old 01-08-2012, 07:17 PM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Make sure the rubber seal is seated properly. Clean the threads on the cap and the neck, will help when you twist them back together.
CLICK HERE!!!
Old 01-08-2012, 08:04 PM   #10
JasianBlazin
Trader Rating: (24)
Old 01-08-2012, 08:18 PM   #11
Sileighty_85
I had this issue I think I put the seal on first then the line cap with a twisting motion... not 100% sure though
後輪駆動車1番
1986 SR86 - 200ish
Old 01-08-2012, 08:19 PM   #12
jr_ss
If you're trying to reuse the factory seal you're going to have a helluva time getting it right. Best option is to purchase a new seal from Nissan. Over time the fuel vapors seep into the seal and expand it, making it extremely difficult to reuse.
Old 01-08-2012, 08:48 PM   #13
JasianBlazin
Trader Rating: (24)
Old 01-08-2012, 08:58 PM   #14
JasianBlazin
Trader Rating: (24)
Old 01-09-2012, 01:00 PM   #15
JasianBlazin
Trader Rating: (24)
Old 01-09-2012, 01:02 PM   #16
Sileighty_85
check ECU for codes
後輪駆動車1番
1986 SR86 - 200ish
