Old 01-09-2012, 06:56 PM   #1
HOTBALLSJOHNSON
HOTBALLSJOHNSON's Avatar
HOTBALLSJOHNSON is an unknown quantity at this point
SPEC-RS Coilovers 350Z/G35
Selling My SPEC-RS Coilovers only 300 miles on them. $1100 if i get full asking price ill pay shipping
here are the specs -Also including pics of my car to show you how low they go also in the pics the Coilovers are not maxed out
Features:
SPRING RATES:
F: 62mm ID; 200mm length; 12kg/mm
R: 62mm ID; 210mm length; 10kg/mm
DAMPER SPECS:
F: 125mm stroke; 220mm length
R: 125mm stroke; 220mm length
- Pillow Ball Upper Mounts
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Dual-Cylinder Design
- Steel front brackets/ Steel rear brackets
NOTE: Damper extension knobs are included for the rear coil-overs.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
HOTBALLSJOHNSON is offline   Reply With Quote
Old 01-10-2012, 06:38 PM   #2
HOTBALLSJOHNSON
$ 900 Local pick up
Old 01-12-2012, 05:29 PM   #3
HOTBALLSJOHNSON
Bumpppppppp
