Old 01-20-2012, 10:18 PM   #1
AnthonysSilvia
AnthonysSilvia's Avatar
AnthonysSilvia is an unknown quantity at this point
s13 ka24de not staying on.
hey just just swaped in my ka24de because i blew my last one. Now i have everything installed, and wires and plumbing, and now my car wont stay on! could this be because of timing??? please let me know if you know something.
AnthonysSilvia is offline   Reply With Quote
Old 01-20-2012, 11:41 PM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
You didnt really explain what is going on but i would say check all your wiring and all of your grounds. Also check your timing. Get a timing gun and see.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 01-21-2012, 10:23 AM   #3
AnthonysSilvia
my car will start but i have to keep on tapping the throttle to keep it on, all my grounds and wiring are fine.
Old 01-21-2012, 10:34 AM   #4
Pro ViZIon
Pro ViZIon's Avatar
Check your tps and see if its set correctly. Also make sure your getting enough fuel. Check all injectors and fuel pump.
Old 02-27-2012, 12:51 AM   #5
ardeine
ardeine is an unknown quantity at this point
how do you check if the tps is set wrong?? i have the same problem but seems like it might be timing because the engine shakes rough when i let go of the gas. could it be timing? seems like it is due to not bolting on the cams right or maybe something called the idle gear i have heard. any help is appreciated
ardeine is offline   Reply With Quote
Old 02-28-2012, 01:02 PM   #6
mr.man.performance
mr.man.performance's Avatar
mr.man.performance is an unknown quantity at this point
When you start it, does it sound like a loping v8? You might be a tooth off on timing. Also, check your vacuum lines.
mr.man.performance is offline   Reply With Quote
Old 02-28-2012, 02:27 PM   #7
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
Check for Vacuum Leaks as well.
Dorifto Machine is offline   Reply With Quote
