Old 01-22-2012, 07:10 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
Disadvantages of using r33 crossmember for RB install
What are the disadvantages of using the r33 crossmember to install an RB25 into an S14?
Does anyone make a driveshaft that will fit if you go that route?
Downpipe clearance issues? Steering rack issues? Motor sit too high or too low?
Any other problems? I've researched it a bit and can't keep up with the issues.
jacobzking is offline   Reply With Quote
Old 01-22-2012, 09:05 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
R33 cross member is actually the best setup, only issue you'd have on S14s is the elbow. You'd have to modify the elbow or basically re do it to clear the steering shaft.
CLICK HERE!!!
Old 01-22-2012, 09:20 PM   #3
silver350z05rb
silver350z05rb is an unknown quantity at this point
Yes , agreed, best way to go if you have it
silver350z05rb is offline   Reply With Quote
Old 01-22-2012, 09:56 PM   #4
fliprayzin240sx
Best setup but also the most expensive is R33 cross member and Syko mount setup. Kit comes with an elbow that will clear the shaft and will mate up to an SR20 downpipe. Then you still have to get or make a custom driveshaft. Roughly 46" for S14s from the back end to the where the input shaft spline starts.
CLICK HERE!!!
Old 01-22-2012, 10:00 PM   #5
JDM_Tuner
JDM_Tuner's Avatar
JDM_Tuner is an unknown quantity at this point
ive read that if you keep the stock intake manifold the hood wont close completely but ive never tried it.
JDM_Tuner is offline   Reply With Quote
Old 01-22-2012, 10:27 PM   #6
MeanS14
MeanS14 is an unknown quantity at this point
R33 crossmember made mine sit way too high and had all sorts of clearance issues with the elbow and other stuff.
Im using the stock s14 crossmember now with Top Hat Performance mounts and love how low and far back the motor sits right now. I think the r33 also sits the motor a little farther forward which sucks because there is already barely any clearance in front for a good fan setup
My current setup
MeanS14 is offline   Reply With Quote
Old 01-22-2012, 10:44 PM   #7
Melonburst
Melonburst's Avatar
Melonburst is an unknown quantity at this point
Not being Formula D legal is one of the disadvantages. But if its for the grassroots level competition its a better alternative. Its a stronger subframe that was built for the inline 6 torque.
Melonburst is offline   Reply With Quote
Old 01-23-2012, 01:03 PM   #8
jacobzking
My current setup
so with the top hat mounts, can you use the stock turbo elbow and the stock intake manifold? hood close, etc?
Old 01-23-2012, 04:46 PM   #9
Sileighty_85
Sileighty_85's Avatar
I have the R33 CM with SYKO Mounts, Zero Issues.
I have a build thread on dropping an RB into a S14. its called Project RB. Check it out
MeanS14 it sounds like you were using OEM mounts which would cause those issues
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-23-2012, 05:36 PM   #10
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Heres mine, r33 member and stock mounts, no issues closing hood, elbow etc.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 01-23-2012, 05:39 PM   #11
encludemeout
encludemeout's Avatar
encludemeout is making a name for him/her selfencludemeout is making a name for him/her self
What tranny mount are you using? I see yours is in an s13, which mine is too. I used an r33 crossmember on mine and it didn't work at all and ended up being a huge pain. Way to far forward, elbow was sitting on the steering rack, oil pan on the sway bar, etc.
encludemeout is offline   Reply With Quote
Old 10-28-2013, 09:55 PM   #12
MIKE 34
MIKE 34 is an unknown quantity at this point
does the stock s13 power steering work with the r33 crosmember ? i planing on using syko mounts.
MIKE 34 is offline   Reply With Quote
Old 10-28-2013, 10:00 PM   #13
fliprayzin240sx
S-chassis power steering rack will bolt up to any R-chassis crossmember. If you're using an RB20 and RB26, get an R32 cross member. If using an RB25, R33 crossmember. The angle of the engine mount tray is different between R32 and R33. R33s are flatter while the R32s are more angled in and works with RB20 and RB26.
CLICK HERE!!!
Old 10-29-2013, 08:59 PM   #14
KPNITRL
KPNITRL's Avatar
KPNITRL is making a name for him/her selfKPNITRL is making a name for him/her selfKPNITRL is making a name for him/her self
Flip is correct. Further assurance; thats what Im running. S13, R33 crossmember, syko mounts.
I never had any clearance issue, didnt even beat up the tunnel
KPNITRL is offline   Reply With Quote
Old 10-29-2013, 09:11 PM   #15
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Any way of fitting the clutch fan with an R33 crossmember in either s13 or s14?
Ilya is offline   Reply With Quote
Old 10-30-2013, 05:00 AM   #16
NismoPlsr
NismoPlsr is an unknown quantity at this point
I'm working on it in my s13; it is real tight. S14 has loads more room and a lot of people have run the clutch fan.
My problem is that I am running a Parts Shop Max highmount intercooler so I can't push the rad forward enough to make room for the OEM fan flipped on the clutch. I have machined the flange on the clutch and going to try to run the s-chassis GKtech fan without the RB adapter. Not sure if it will work yet.
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
Old 10-30-2013, 10:47 AM   #17
double zero
double zero's Avatar
double zero is an unknown quantity at this point
so I have a s13 with a r32 engine x-member. I fit my rb20 and now my rb25 with their stock mounts with no issues with the hood closing. with stock intakes and aftermarket(on my 25).
Iam here for the free ethanol!
double zero is offline   Reply With Quote
Old 10-30-2013, 03:35 PM   #18
teddyjr
teddyjr's Avatar
teddyjr is an unknown quantity at this point
+1 on Syko and the R33 cross-member. Mine turned out SO nice and factory looking. The stainless turbo elbow clears the steering with about 1/4 inch. I did have to massage the area behind the starter for more clearance. The shifter is in the exact center of the opening. Highly recommended solution. Oh, I abandoned the stock power steering cooling "loop" in favor of a 350Z PS cooler and that looks tight and factory too.
teddyjr is offline   Reply With Quote
Old 10-30-2013, 04:21 PM   #19
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
I was using mckinney motorsport mount with my rb26/s14
Realy good set-up eith nothing bad to say about it !
Now that zerolift is out there , i would probable go with them , its a similar design but cheaper
For the elbow/downpipe just get one made
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 10-30-2013, 05:26 PM   #20
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
There are no disadvantages. Anything else is just Fisher Price, Mickey Mouse-ass bullshit.
omgRWDgoodness! is offline   Reply With Quote
Old 10-30-2013, 09:03 PM   #21
EnemyS15
EnemyS15 is an unknown quantity at this point
The only thing I have noticed some people saying is the clearance between firewall and the hump of the starter. Some people say you need to notch the firewall in a 1/2 - 3/4 inch @ that starter hump. I personally didn't have that issue with my 33 crossmember and syko kit, in my s14.
I agree with flip and the others. It's the best way to go about installing rb25 into s chassis.
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html
EnemyS15 is offline   Reply With Quote
