Old 04-14-2004, 11:33 AM   #1
pnkazn1
pnkazn1 is an unknown quantity at this point
Axxis Ultimates and new rotors dont fit?
I replaced the front pads and rotors without problems ( endless na-y pads). But when i got to the rear, it seems as if the new pads (axxis ultimates) and the rotors are simply too thick. I can't get the caliper over the pads. I tried to get the axxis pads on my stock rotors, but they I still coudlnt get them in. The car is a 93 13 hicas, has anyone else run into a problem like this?
thanks,
jonathan
pnkazn1 is offline   Reply With Quote
Old 04-14-2004, 11:44 AM   #2
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
Are you using a brake tool or needle nose pliers to turn the pistons in on the rear calipers?
Or have you already turned in the pistons as far as they will go? If so, the rotors are wrong.
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 04-14-2004, 12:31 PM   #3
nissantuner22
nissantuner22's Avatar
Trader Rating: (-1)
nissantuner22 is on a distinguished road
Feedback Score: -1 reviews
Send a message via AIM to nissantuner22
double check that the piston is in all the way. Also, make sure those little clips arent bound up in anything, or at a crooked angle. if everything is in right, it SHOULD go on.
Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ,
"Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247
"on the tounge... there is no guardrails."- citizen
nissantuner22 is offline   Reply With Quote
Old 04-14-2004, 04:05 PM   #4
pnkazn1
i nearly stripped and bent part of my brake tool forcing the calipers in, yet they still arent all the way completely in. I also dont think its the rotors cuz theyre skinnier if not equal to my old stock ones. How else can i push the piston in? how do u turn the piston ( just used a brake tool that you crank against it and it pushes it back)?
thanks,
jonathan
Old 04-14-2004, 04:31 PM   #5
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
if you go to autozone or a similar arts place they will have a universal tool that looks like a cube with little tab things on it.
the cube goes onto a ratchet and you turn the piston clockwise to push em in.
go to the store and ask for a "cube looking universal brake tool" it'll all make sence after you see the tool
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 04-14-2004, 04:50 PM   #6
ISTOTOSAO
ISTOTOSAO's Avatar
ISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enoughISTOTOSAO will become famous soon enough
open the bleed valve on your calipers and twist it back in with your hand. This all I ever do, (lots of different cars too). If thats not working I would think that something is wrong. Good luck.
ISTOTOSAO is offline   Reply With Quote
Old 04-14-2004, 05:17 PM   #7
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
thanks,
jonathan
im not sure if this makes a difference, but ive always taken the cap off the master cylinder reservior. i didnt have to use much force at all for the piston so make sure its open.
skatanic28 is offline   Reply With Quote
Old 04-14-2004, 05:55 PM   #8
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
jonathon,
I had the same problem, you get to a point where if you keep turning the caliper tool the piston does not go in anymore. This is what I did:
1. take off reseirvor cap, but watch the fluid level so it doesn't flow out
2. get a second person (who has strong fingers) to push at the same time as you are turning the tool.
OR
3. (the way I did it): in the caliper there is a slit/opening on the side, there is just enough space to slide a screw driver in there as a lever to help push the piston in AS you are turning the caliper tool. Becareful to PUSH and TURN at the same time, you don't want to risk damaging the caliper. Also becareful not to damage the surface of the piston w/ the screwdriver, just watch out.
Funny cuz my friend w/ a S13 pushed in his rear caliper pistons w/ ease and mine always take alot of muscle power, but the screw driver trick works well.
hope this helps.
edit: if you haven't cleaned off your rotors (if they're new) with brake cleaner do it ASAP before they go on the car!
yudalicious is offline   Reply With Quote
Old 04-14-2004, 05:58 PM   #9
yudalicious
If you open the bleeder screw/valve w/o stepping on the brake, it seems air will most likely get into your brake system... although this does not matter if you are bleeding the brakes.
Old 04-14-2004, 07:00 PM   #10
ISTOTOSAO
ISTOTOSAO's Avatar
yeah. I always bleed the brakes after messing with anything. helps to rotate fluid IMO
Old 04-15-2004, 12:13 AM   #11
pnkazn1
yeah i did have the mc's cap off, ill go out there in a day or 2 to try the cube expander tool , or perhaps some of the other tricks. I will keep you posted.
Is it also a possibility carbo tech sent me the wrong axxis pads? maybe for a non-abs car with smaller rotors would need a thicker pad?
Thanks all for your help,
Jonathan
