Old 01-24-2012, 06:53 AM   #541
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
Im running regular coppers one heat range colder. In either case I'm gonna go with iridiums bkr6eix should work fine in the application.
I dug a little deeper and realized what the problem, For some reason when i would give it just 1 degree of timing more at 6000+rpm , the battery voltage would drop drastically to 11.5 volts, the super charger belt and the alternator belt are on the same pulley.
Its really strange, i have two logs with the same occurrence when i add the timing, i think the belt is slipping on the crankshaft. The belt is pretty old so I'm gonna change the belt and the plugs and do some logs and see if it gets better.
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 01-24-2012, 01:08 PM   #542
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
I hated v8's until I saw this thread
mau5trap is offline   Reply With Quote
Old 01-24-2012, 01:20 PM   #543
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
hey jerry
u can jump alt to main positive terminal
it may help
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 01-25-2012, 06:02 PM   #544
turbociv910
turbociv910 is an unknown quantity at this point
Originally Posted by JDMRIDDAZ View Post
hey jerry
it may help
not if the belts not turning the pulley.
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 01-25-2012, 06:35 PM   #545
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Idk if anyone said this but did you do a ls swap in it haha. Thats the first that pops in my head when i see this motor with that manifold.
Old 01-26-2012, 12:12 PM   #546
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Belt slippage doesn't make a lot of sense. That supercharger takes >25 horsepower to turn, the alternator takes <8 hp. If there's enough tension on the belt to keep the supercharger making boost, then there's definitely enough tension to keep the alternator spinning. Also, alternators are designed to make their full rated amps at idle. So they should have no trouble at 6000 rpm even if the belt is slipping a ton.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 01-26-2012, 12:49 PM   #547
gsracer
Then I'm at a loss, maybe the alternator is going out? Its charging 13.2 volts at idle, that seems a little low.
ANTI-STRETCH NAZI
Old 01-26-2012, 07:10 PM   #548
turbociv910
is boost dropping also? do you have a map sensor to log?
Old 01-26-2012, 08:10 PM   #549
SicBastard
SicBastard's Avatar
Yeah, it should be a little closer to 14.0 volts.
Old 01-26-2012, 08:35 PM   #550
gsracer
well in typical fashion with me, after hours of work it was something simple.
3.5 hrs of changing alternators, redoing belts , tensioners, and what not. Still 12.8-13.0 volts at idle. Long story short, main fuse box power wire was loose, tightened the stud, voltage at 14.1 volts.
ARGGGG.
of course said wire was buried behind the dashboard and a nightmare to get to.
ANTI-STRETCH NAZI
Old 01-26-2012, 08:58 PM   #551
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
LoL I hate when that happens.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 01-27-2012, 06:08 PM   #552
epik1
epik1 is an unknown quantity at this point
damn this has been an epic 19 pages sir, hats off to you. Nothing but results!
epik1 is offline   Reply With Quote
Old 01-28-2012, 08:53 PM   #553
gsracer
ok so final results...
Everything was sorted, no more misfiring. It doesn't make any more peak power than before.... just more power everywhere else thats not the peak. I threw timing fuel, etc nothing would increase. Seems like I'm at the limit of the cams at this point, theres nothing more that could be choking it at this point other than the tiny cams...
heres the results
heres a comparison on paper... made 45whp peak and about 48wftlbs tq increase in the mid range and top end. Not bad in the end in my opinion. Average power increase was 30hp and about 30ftlbs to the wheels everywhere in the power band.
and just for fun heres a video on the way home from the dyno, notice the wheel spin in 3rd gear from a 60mph roll all the way to 90mph... awesome. lol
http://www.youtube.com/watch?v=MH1q8eUox0Y
ANTI-STRETCH NAZI
Old 01-28-2012, 09:08 PM   #554
Chamb-O
Chamb-O's Avatar
Chamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the roughChamb-O is a jewel in the rough
freakin cool man
great idea about the manifold
Chamb-O is offline   Reply With Quote
Old 01-28-2012, 09:13 PM   #555
SicBastard
SicBastard's Avatar
So are you finally happy with the power? Are you going to leave it alone, or are you already saving up for cams?
Old 01-28-2012, 09:21 PM   #556
gsracer
um i guess lol... not. Ill probably leave it alone for a while, till i get bored again.
As for the cams... you mean these custom 272 duration 12.5mm lift with custom titanium retainers and super tech valve springs that have been sitting on a shelf in my garage for two years collecting wd40 and dust because I'm too lazy to install them... haha lol
ANTI-STRETCH NAZI
Old 01-28-2012, 09:57 PM   #557
SicBastard
SicBastard's Avatar
You just had the intake off, and retuned, and never thought to take the extra two hours to install those!!! WTF?! In the video it looks like you're shifting at 7200 rpm. How much higher will you push it with the new valvetrain? Is the long block stock?
Old 01-28-2012, 10:12 PM   #558
gsracer
lol.. if it was 2 hrs, it would be done by now. Unfortunatly to change the heads, because of the headers, the motor has to come out of the car. Its just a pain. I also have head studs and such to go with it.
The long block in the car is stock. Redline is set at 7100rpms.
The heads are good to 8000-8500rpms so i was told, so if i ever blow it, ill open up the clearances on the rods an mains, install arp rod bolts and see what happens. Lots of people don't know but the bottom end on this motor is 6 bolt main, 4 studs and two bolts coming in from the side with a huge girdle stock.
Bit of mis-information on my part, its been so long, i thought the new cams where 12.7 there not, there smaller..
Heres the specs between stock and my new ones.
stock
Advertised Duration 240* Intake, 240* Exhaust
Duration @ 0.050" lift 177* Intake, 176* Exhaust
Maximum valve lift 0.368" Intake, 0.355" Exhaust
new cams
Advertised Duration 272* Intake, 272* Exhaust
Duration @ 0.050" lift 185* Intake, 185* Exhaust
Maximum valve lift 0.420" Intake, 0.405" Exhaust
ANTI-STRETCH NAZI
Old 01-28-2012, 11:35 PM   #559
SicBastard
SicBastard's Avatar
8500 rpm is only 4612 f/s average piston speed. The stroke is so short (3.256"), and the rods and crank are forged, I don't think 8500 rpm will be a problem at all for the bottom end.
Here's some average piston speed calculations that I made for the 4.0" stroker crank that's going in my LSx on the left. On the right gives you something to compare piston speeds to. Most engine builders say to stay under 5000 fpm for a high quality fully forged bottom end as a rule of thumb.
RPM FPM
7000 4666 LS7 (stock with titanium valves and rods)
7200 4800 Modern F1 (1.6" stroke at 18000 max rpm)
7500 5000 Honda b16 at 9900 rpm
7650 5100 R07 Nascar engine
8200 5466 Tosto Drag machine
Old 01-28-2012, 11:40 PM   #560
SicBastard
SicBastard's Avatar
Also are you sure on those cam stats? The modern comp cams lobes have .050" durations that are only ~50 degrees less than their .006" (advertised) durations. Your difference of ~90 degrees seems really strange and lazy. Who spec'd and ground those lobes for you?
Old 01-28-2012, 11:47 PM   #561
gsracer
It was franklin camshafts in new zealand.. .down there these motors are fairly common in dirt sprint cars, maybe it has to do with the VTC in the head. I don't really know much other than that.
Its per there page with the exception that the lift was a custom profile.
Nissan - Camshaft Profiles
ANTI-STRETCH NAZI
Old 01-28-2012, 11:52 PM   #562
SicBastard
SicBastard's Avatar
Yeah their RB and SR profiles look much more traditional. Probably VTC like you said or limits of the hydraulic lifters. Is your VTC functional and tuneable?
Old 01-29-2012, 12:03 AM   #563
gsracer
yes it is, i can pretty much set it to do whatever i want... its worth a lot of tq under 4500 rpm... it gives something like 20 degrees of overlap on unto 4500 rpms when it switches off and goes to close to zero over lap, above. At least thats where i have it set now.
Unfortunately i can't control how many degrees of overlap it will give, its basically an on or off switch. Ive tried both ways, fully on till 6000 rpm and fully off, and where the two dyno plots intersected i went about 300 rpms above that and set that as the crossover point.
Ive probably logged close to 100 pulls and 4-5 hrs on the dyno with this car trying different things
ANTI-STRETCH NAZI
Old 01-29-2012, 08:27 PM   #564
k0013
k0013's Avatar
k0013 is an unknown quantity at this point
wow man you've got to have one of the most tested and tuned street VH's in the country! Just want you to know your hard work is not going un-noticed. Your laying the groundwork for a new movement in the S chassis community in America. thanks bro!
k0013 is offline   Reply With Quote
Old 01-29-2012, 08:31 PM   #565
k0013
k0013's Avatar
On a side note, I remember long ago when you built that thing the first time and you got those cams, shortly after you put them up for sale because i guess you had decided you didn't need them because you were going to boost the VH. never got an answer back when i asked if you were still going to part with them a little while ago. guess this is my answer! lol! keep on truckin man! I love this ongoing build!
Old 01-29-2012, 09:05 PM   #566
SicBastard
SicBastard's Avatar
I don't think the VH is going to catch on. It never came with a manual transmission, so you need a expensive adapter. And the newer VQ makes more horsepower with only 2/3 the discplacement! And if you're not a Nissan loyalist the LS just makes so much sense. It is fun to watch oddball stuff like this progress though!
Old 01-29-2012, 09:24 PM   #567
gsracer
Thanks for the compliments, over on our forum we have quite a few swaps going on, i think theres at least 50+ vh cars now but...
Originally Posted by SicBastard View Post
]And if you're not a Nissan loyalist the LS just makes so much sense. It is fun to watch oddball stuff like this progress though!
what he said.....
ANTI-STRETCH NAZI
Old 01-29-2012, 10:22 PM   #568
n8RPS13
n8RPS13's Avatar
Trader Rating: (22)
n8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of light
Feedback Score: 22 reviews
I still plan on doing this swap in a vert or a coupe once I move back.
WASTED I AM!
n8RPS13 is offline   Reply With Quote
Old 01-30-2012, 01:17 AM   #569
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
haha thanks for the shout out, i just installed another HPX 3.5" and worked wonderful i think you just got a bad MAF man, reguardless car is running awesome. i think the 272's will max out the lightning maf lol
Review Thread
bardabe is offline   Reply With Quote
Old 01-30-2012, 07:56 PM   #570
turbociv910
the VQ35 is a rice box when it comes to exhaust note, id take the vh just cuz it sounds cool. Though the sound of a cammed LS
