Old 01-12-2012, 10:46 PM   #1
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
Angry ka24de 2k bog on stock timing? plus 5k rev limit? WTF
When I set my ka24de to stock timing here a bog around 2k and doesnt pull very well at all.
its pretty much at any position of the throttle.
when I advance the shit out it, it pulls pretty decent then starts to bog overtime. I clean the MAF every so often and it pulls great again at advance timing. but really shitty at the stock 20* BTDC.
BUT, I also have a 5k rev limit. in ALL gears and in Neutral.
also when doing abit of hard driving and reving my tach goes retarded and doesnt read correctly at all. Could my CAS be crap?
rwtf is offline   Reply With Quote
Old 01-15-2012, 06:39 PM   #2
rwtf
rwtf's Avatar
anyone?
Old 01-15-2012, 07:39 PM   #3
S13x88
S13x88 is an unknown quantity at this point
Check TPS?
S13x88 is offline   Reply With Quote
Old 01-18-2012, 12:57 PM   #4
rwtf
rwtf's Avatar
Update: Well I got a new maf from a friend and it cleaned up very nicely. and makes good power until it hits 3k. then its just like a loss of power.
I still hit a 5k rev limit and sometimes my tach will act funny.
Old 01-18-2012, 02:52 PM   #5
Eramo323
Trader Rating: (22)
Eramo323 is an unknown quantity at this point
Feedback Score: 22 reviews
Send a message via AIM to Eramo323
Safe mode? Reset the ecu
Eramo323 is offline   Reply With Quote
Old 01-18-2012, 03:03 PM   #6
89JDM240sx
89JDM240sx's Avatar
89JDM240sx is an unknown quantity at this point
Try and resetting the Ecu... You can also try a Auto Ecu will get rid of the Rev limit
89JDM240sx is offline   Reply With Quote
Old 01-18-2012, 05:44 PM   #7
rwtf
rwtf's Avatar
I wish I had a auto ecu to try. but I will reset it and see what happens.
Old 01-22-2012, 06:32 PM   #8
89JDM240sx
89JDM240sx's Avatar
Did you ever get the Ecu?
Old 01-22-2012, 07:47 PM   #9
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Not sure if this is the problem but check the 5th gear sensor in your transmission.. If the car thinks it's in 5th gear all the time it'll turn the speed limiter on in every gear. Which happens to be around 5k. Unplug your speed sensor go for a drive and see if the problem is still there.
pacotaco345 is offline   Reply With Quote
Old 01-22-2012, 08:36 PM   #10
rwtf
rwtf's Avatar
well the 4th and 5th gear sensor is unplugged. so I should unplug the VSS?
Old 01-25-2012, 11:42 PM   #11
rwtf
rwtf's Avatar
bump ((
MSSGLENGTH
Old 01-25-2012, 11:55 PM   #12
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
wiring perhaps.
at night, when it bogs, do you see any electrical woes, like dimming of headlights, or interior lights?
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 01-26-2012, 12:47 AM   #13
rwtf
rwtf's Avatar
The bogging is gone.
the 5k rev limit is will there.
Old 01-28-2012, 09:45 PM   #14
S13x88
Does it feel like you hit a fuel cut-off at 5k rpm? Like this:
http://www.youtube.com/watch?v=PcR8FMLo4U8
If it does, it's your TPS. Get a new one, read up on how to set the proper voltage, and try your car out again.
Old 01-29-2012, 12:31 AM   #15
rwtf
rwtf's Avatar
eh...not exactly. I will take a vid tomorrow.
Old 01-29-2012, 10:16 AM   #16
srking
srking's Avatar
srking is an unknown quantity at this point
thats the problem i have and i got a new fuel pump and mafs tps and filter plugs and wires too but my car does that now all the time but just wont go past 2500 rpm and it sucks.....
srking is offline   Reply With Quote
Old 01-29-2012, 12:30 PM   #17
rwtf
rwtf's Avatar
2.5k limit is MAFS. Get that checked out.
Heres it in Neutral.
http://www.youtube.com/watch?v=ST_sWuaq81s
Heres while i'm driving.
http://www.youtube.com/watch?v=RvR4z...ature=youtu.be
Old 01-29-2012, 04:28 PM   #18
srking
srking's Avatar
but i put a new mafs and i do need a air cleaner temp sensor if that does anythin?
Old 01-29-2012, 09:40 PM   #19
Corey121
Corey121 is an unknown quantity at this point
Is the car turbo? if so check the spark plug gaps, my ka-t was blowing out the spark at stock gapping
Corey121 is offline   Reply With Quote
Old 01-29-2012, 11:12 PM   #20
rwtf
rwtf's Avatar
Check the wiring to the MAF itself.
And no, the car isnt turboed.
Old 02-03-2012, 07:55 PM   #21
rwtf
rwtf's Avatar
bump
gdfghfgrhregsd
Old 02-05-2012, 04:18 PM   #22
rwtf
rwtf's Avatar
Alright, I got a chance to pulled codes.
I think I got 11 and 12.
CAS and MAF. I know the MAF is good cuz its runs good until it hits 5k.
It might have been 11 and 13. 13 is CTS which idk if it would cause this sort of thing.
Old 02-06-2012, 05:46 AM   #23
irax
irax's Avatar
check your 5th gear pos sensor for the 5k redline issue
irax is offline   Reply With Quote
Old 02-06-2012, 06:44 AM   #24
rwtf
rwtf's Avatar
The 4th and 5th gear sensor is un plugged. I also cleaned all the grounds and sanded them down to make sure they gor good connection
