Old 02-17-2012, 12:09 AM   #1
ke70 sr20det
ke70 sr20det is an unknown quantity at this point
SR sr20 redtop with t28 (what power ??)
i have searched and had similar kind of thread but minor things have changed .. i dont have dyno so asking ere
my mods
s15 turbo
fmic
3inch down pipe
3 inch custom exhaust
ruff fpr
k&n intake
avcr
bosch 130lph fuel pump
stock maf
stock injectors
stock ecu
i dunno where to set my boost but now at .65 how far can i go on stock injectors
ke70 corolla sr20det redtop t28 s15 7 psi stock motor
ke70 sr20det is offline   Reply With Quote
Old 02-17-2012, 01:07 AM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
got pics of your ride ?? Stock injectors are going to hold you back and I would change the maf also
s13 @ fullboost is offline   Reply With Quote
Old 02-17-2012, 01:13 AM   #3
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
370cc.... i'd GUESS around 220-240 whp is max on 370cc.
Old 02-17-2012, 01:17 AM   #4
ke70 sr20det
its a corolla not s13 in next two months m going aem with map for the time being i wanna play with stockies
here you go
Old 02-17-2012, 01:18 AM   #5
ke70 sr20det
but what should be my max boost on 370s
Old 02-17-2012, 01:19 AM   #6
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Before upgrading to Cams and more boost I was running your similar setup at 11psi and it ran just fine. You wouldn't want to go any higher then 11psi since you're already flowing more air with the T28 then you would with a T25.
kojiki88 is offline   Reply With Quote
Old 02-17-2012, 01:19 AM   #7
s13 @ fullboost
yes I am aware of that do you have pictures ?
Old 02-17-2012, 01:25 AM   #8
ke70 sr20det
yea have posted pics for you i know its pretty plain car like aw11 mr2 two tone
Old 02-17-2012, 01:28 AM   #9
ke70 sr20det
Originally Posted by kojiki88 View Post
Before upgrading to Cams and more boost I was running your similar setup at 11psi and it ran just fine. You wouldn't want to go any higher then 11psi since you're already flowing more air with the T28 and you would with a T25.
ahan thats seems fair amount of boost plus m on avcr so i really dont know how to play i have set it to .65 and gain 30 percent throughout so any help over here would be appreciated aswell . i am running 130lph fuel pump with 40 psi fuel set at fpr and v power 7 plugs gap at .30
Old 02-17-2012, 01:37 AM   #10
kojiki88
kojiki88's Avatar
IDk about your fuel pump, I have the walbro 255LPH and if I remember seeing it correctly Mine is set at around 43psi at the FPR. Again Im not sure but either way my setup isn't stock anymore I have 740cc Injectors and Z32 MAF. I would just upgrade your fuel pump to a walbro 255lph to be on the safe side and if you ever decide to upgrade you'll already have a good pump in there.
Old 02-17-2012, 01:51 AM   #11
ke70 sr20det
it is same as waqlbro 255 but yours is in line mine is external i was using 044 pump before on same setup i was blowing alot of fuel and pig rich smell of fuel so when i just swapped this no more pig rich but some one also should tell me the setting of avcr ......
Old 02-17-2012, 01:59 AM   #12
kojiki88
kojiki88's Avatar
Oh ok my bad I didn't know. And sorry I don't know anything about the avcr. Good luck.
Old 02-17-2012, 02:09 AM   #13
ke70 sr20det
no prob at least you give me some feedback which will help me a bit on boosting
Old 02-17-2012, 02:23 AM   #14
zurud
zurud is an unknown quantity at this point
Do 30 psi for a while like 1 hour straight . See what it will do. Then increase to 45 psi. Make sure to take video and post it here
zurud is offline   Reply With Quote
Old 02-17-2012, 10:38 PM   #15
ke70 sr20det
if your talkin bout boost then m not that stupid like you and talkin bout video my car still kills s13 and s15 becuz m lightweight
82 corolla sr20det t28 - YouTube
82 corolla sr20det vs salmans 2jzgte single pink silvia - YouTube
Old 02-18-2012, 12:14 PM   #16
RedSiBaron
RedSiBaron is an unknown quantity at this point
Im sure with limited changes you can hit 270/280
Id get together with a tuner with sr experience and work with them on tweaking your build
RedSiBaron is offline   Reply With Quote
Old 02-18-2012, 01:03 PM   #17
nomoremk2
nomoremk2 is an unknown quantity at this point
So from what I gather you're slapping on a bigger turbo, not tuning and asking a bunch of dudes on the Internet what boost you should run? Goodluck dude.
nomoremk2 is offline   Reply With Quote
Old 02-18-2012, 01:25 PM   #18
kalypso123
(ノಠ益ಠ)ノ彡
cool car, throw some chromed steelies on it. :0)
Old 02-18-2012, 03:56 PM   #19
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Leave the boost where its at if you're still running the stock ECU/tune. When you get your AEM, get some 740s and Z-maf, should be able to boost 18 psi on that S15 turbo and get you up to about 310-320hp.
CLICK HERE!!!
Old 02-18-2012, 06:00 PM   #20
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
my mods
s15 turbo
fmic
3inch down pipe
ruff fpr
k&n intake
avcr
stock maf
stock injectors
stock ecu
leave it at wherever the factory wastegate is set at
you can get away with 10-11 though, I would have a wideband in though.
Big Zee is offline   Reply With Quote
Old 02-19-2012, 06:38 AM   #21
zurud
S15 come with 480cc injectors on that turbo. stock wastegate. Do the math. 370/480 +*/\*//*//*++
Old 02-19-2012, 07:08 AM   #22
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
Read....read the post...
He said redtop w/ t28...
So no 440's....
Jesus, for the people smashing on him just b/c its so cool, you think you would read the damn post.
To the original poster, thats a pretty clean car, man. Props on the sleeper.
I would definetely avoid going near 1bar on those small of injectors, and the others have already iterated about your MAF also being a limiting factor. You can look through the For Sale section on this forum, people are selling larger injectors all the time that you could match up with your AEM/Map setup.
But for now, I would honestly just listen to Big Zee, leave it the wastegate set where it's at. Good luck, and keep us updated!
nismoracingsx is offline   Reply With Quote
Old 02-21-2012, 04:05 PM   #23
slim
slim's Avatar
slim is an unknown quantity at this point
I kept mine at the 7 psi. Never went lean on me but after 10 psi the 370s are maxed and it only takes a second to melt a piston right? I just played it safe and waited till I got my 440s.
07 ugm STi-07 titan se-99 civic si sold-92 sil coupe-89 240 hatch
slim is offline   Reply With Quote
Old 02-22-2012, 02:47 PM   #24
ke70 sr20det
while swapping my turbo was blown so friend of mine gave me s15 turbo for free how could i resist and the reason y m asking because i dont have dyno
Old 02-22-2012, 02:47 PM   #25
ke70 sr20det
not a fan of chromes
Old 02-22-2012, 02:50 PM   #26
ke70 sr20det
i already have sard 880cc just waiting for aem and for afm ill say bye bye and do it map and 310 and 320 is good amount i know i wish i had dyno
Old 02-22-2012, 02:53 PM   #27
ke70 sr20det
So no 440's....
thank you i just wanted a simple car with no rice looks just like aw11 mr2 two tone .... m at 11 psi and avoid going more so ill wait for the ecu
Old 02-22-2012, 02:54 PM   #28
ke70 sr20det
its becuase i have hks wastegate on it so its set at 11 psi otherwise ill lower the boost ...
Old 02-22-2012, 04:23 PM   #29
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
I have a s13 blacktop with s15 t28 and stock injectors. Running like 12lbs of boost and I don't lean out. At full boost my AFR is reading ~10.8.
Yeah it'd be wiser to get bigger injectors and a different maf. Up to you!
daftphunk is offline   Reply With Quote
Old 02-22-2012, 11:24 PM   #30
ke70 sr20det
what is your fuel pressure ????
