Old 02-17-2012, 09:21 PM   #2251
NAIRB
NAIRB is an unknown quantity at this point
most people seam to like 255-40-17. 275s are pushing it, but it has been done.
NAIRB is offline   Reply With Quote
Old 02-17-2012, 09:24 PM   #2252
benz88
benz88's Avatar
benz88 is an unknown quantity at this point
I guess 255-40's and i could still tuck?
benz88 is offline   Reply With Quote
Old 02-17-2012, 09:26 PM   #2253
NAIRB
yea deff, 10s might be a tad of a stretch though, a 9 or 9.5 would be pretty square with a 255.
Old 02-17-2012, 09:29 PM   #2254
benz88
benz88's Avatar
this is a 255/35/18 on a 10. Which im guessing would be close stretch wise to a 255/40/17 right? Now what offsets should I be looking around? +30?
Old 02-17-2012, 09:31 PM   #2255
NAIRB
yea it should be the same
Old 02-17-2012, 09:36 PM   #2256
twinspool
twinspool is on the path to ruintwinspool is on the path to ruin
get that out of here no stretch!!hahaha for offset it depends do you want lip/concave or flatface honda wheel on there?
twinspool is offline   Reply With Quote
Old 02-17-2012, 10:04 PM   #2257
mikerbike
mikerbike is an unknown quantity at this point
Here's my 255/40/17 RT615K on a 9.5 +12 under stock metal. I posted it a few pages back and said it was ~-1* camber. Then I measured again. It's more like -0.5.
I also run a 17x9 +32 and 0* camber on my other car with much less of a roll. If I had a 245/40, it would be 'flush'. I didn't take note of my inner clearance, but it sticks in my mind that I have another inch before the wheel would hit the coilover. Meaning a 17x10 +43 with a proper sized tire should fit inside and have about the same fitment on the fender side.
But I've also never looked at control arm clearance. That could be a problem.
mikerbike is offline   Reply With Quote
Old 02-17-2012, 10:31 PM   #2258
benz88
benz88's Avatar
I think I would be more worried about Coilover clearance no? Also can you run 255's up front?
Old 02-18-2012, 06:15 AM   #2259
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
i run an 18 x 10 +18 up front with a 265 and its pretty close to the coil over.
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 02-18-2012, 07:10 AM   #2260
Black R
Black R's Avatar
Black R is an unknown quantity at this point
For a 10" wide wheel all around, my preference is to run -1 offset.
I would love to be able to run 11" wide up front in -13 offset.
Black R is offline   Reply With Quote
Old 02-18-2012, 07:38 AM   #2261
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
LOL, you would need like 65mm overs on the front in order to run a 315 tire on an 11" with -13 offset.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 02-18-2012, 09:16 AM   #2262
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
You'd never have problems with understeer again though...
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 02-18-2012, 10:17 AM   #2263
mikerbike
That depends on camber. I loaned out my 17x9s for a Proam event happening today, so these pics are taken with my 18x8.5 +32.
My fingers are up to the second knuckle and have room to spare from the coilover, which seems to be about 3/8" closer to the wheel than the body at this point.
Here's the clearance to the control arm. My fingers are up at the first knuckle and they are squished. I think 2 fingers at the second knuckle would be a more appropriate measurement.
And, with a 17" wheel both of these measurements will be a bit different, as the coilover and control arm are sloped away from the center of the wheel. So maybe a 17x10 +43 wouldn't fit.
Old 02-18-2012, 11:01 AM   #2264
Black R
Black R's Avatar
I'm down!!!
Old 02-18-2012, 01:29 PM   #2265
benz88
benz88's Avatar
so a 265 on a 17x10 +20 will clear stock metal, Sweet time to order suspension and wheels.
Old 02-18-2012, 04:38 PM   #2266
Broadfield
Broadfield's Avatar
Absolutely will not clear stock S13 metal. You would need a 10" wheel in the +40 area in order to run a 265. This also depends on if you want to be able to tuck a little tire. I actually ran the same exact wheel you speak of: 10" +20 with a 265 tire.... I had a 25-ish mm pull. This is the setup below:
Note: the 265's I had ran kind of wide. So depending on the tires you choose you may be able to go a couple mm lower on the offset. But now we're really getting specific.
My Portfolio
Please Share
Check Out My Builds
Old 02-18-2012, 06:18 PM   #2267
mikerbike
Oh, I assumed he meant stock metal, not un-rolled, un-pulled stock metal.
Old 02-18-2012, 06:53 PM   #2268
benz88
benz88's Avatar
What did you run in the rear? this looks perfect.
Old 02-18-2012, 06:56 PM   #2269
benz88
benz88's Avatar
I dont mind rolling and pulling the fenders(to an extent). I just meant no Overs in the rear and no FG front overs.
Old 02-18-2012, 10:32 PM   #2270
Broadfield
Broadfield's Avatar
Flashback(exterior) « Broadfield's Blog
My Portfolio
Please Share
Check Out My Builds
Old 02-20-2012, 02:01 AM   #2271
Wreckless35
Wreckless35's Avatar
Wreckless35 is an unknown quantity at this point
Send a message via AIM to Wreckless35
XXR 526 18x9(+20)-f & 18x10.5(+25)-r
Michelin Pilot Sport 255/40-f & Yokohama AVS ES100 275/35-r
PBM 10mm spacers-f & Ichiba 25mm spacers-r
Origin 20mm front fenders & Origin Type1 50mm rear overs
-2.0 front camber & -2.5 rear camber
Originally Posted by jasoncanseeoh View Post
fucking gangster.
Wreckless35 is offline   Reply With Quote
Old 02-20-2012, 08:29 AM   #2272
Broadfield
Broadfield's Avatar
Sorry man, that's definitely NOT max tire fitment. You have 50mm overs... you could/should be running at least 315's out back.
My Portfolio
Please Share
Check Out My Builds
Old 02-20-2012, 08:32 AM   #2273
Broadfield
Broadfield's Avatar
I assumed he did too, which is why I posted mine with pulled metal. As in he wouldn't be able to run what he wanted without pulling it since the setup he wanted was the exact setup I had in the pics.
My Portfolio
Please Share
Check Out My Builds
Old 02-20-2012, 08:51 AM   #2274
ebayDM
ebayDM is a well-known jackass
hey guys
I have a quick question
Can i Run a 17x9 +22 with a 235/40 and clear FLT-A2s in the front of an s13 without a spacer?
Thanks
ebayDM is offline   Reply With Quote
Old 02-20-2012, 09:18 AM   #2275
Wreckless35
FIRST POST:
Originally Posted by a_ahmed View Post
This thread is for people with s chassis cars who own or know someone who owns s chassis car(s) with maximum rubber and maximum wheel width for grip in mind -- whether this be for street or track or both.
It's for the slowly growing crowd of enthusiasts who are more swayed towards lapping/maximum grip from their car as opposed to drift or looks. Those who own their car and attempt to make their car meet or exceed the performance of modern sports cars, supercars heck even hypercars... whether they just have a street car and do it for personal achievement or race it at the track. Whatever this may be to you if you are someone who likes to see/have/drive on with 255 on an 8.5", 275/285 on a 10", 3xx on a 11"/12", etc... please post.
I'm running 255/275 setup on 18's unlike the rest of the peanut gallery who mostly post on here on 17's throwing out 225/235/245 numbers! Granted I can go as wide as I want but don't shit on me cuz it's not up to your standards.
P.s. you're right, I could be running 3xx IF I wasn't running spacers, it's only round 1 of 1,000... Let it go!
fucking gangster.
Old 02-20-2012, 10:19 AM   #2276
silviaks2nr
silviaks2nr's Avatar
Then take off the spacers and run wider tires then post again in this thread. I fit 295/30/18 on mild pull on s14 and I think I could pull off a 305 pretty easily.
Old 02-20-2012, 02:44 PM   #2277
Wreckless35
Sure, will do... when the lovely EXPENSIVE rubbers I'm running burn down. Enough said, STFU!
fucking gangster.
Old 02-20-2012, 03:39 PM   #2278
SicBastard
SicBastard's Avatar
That first post was made in 2007! We've learned a lot about how much tire you can reall stuff under an s-chassis since then. People were questioning IF a 275 could fit in '07, now we're questioning how to get 315s without overfenders.
That being said, 275s are still manly tires, even if the most up-to-date MAX tires guys have moved on.
Old 02-20-2012, 04:17 PM   #2279
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Life begins at 335/35/17, this is the size I really want for my coupe! I think I could run them on a 12" wheel (?). But at a 12" width what offset is the highest I could run before hitting the coilover? That would help determine how much of a flare would be needed.
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 02-20-2012, 04:57 PM   #2280
gsracer
i know right......
circa 08 295s 18 x11 +18 stock body, stiff suspension... ill have to look for it but i have a pic of 315s under stock sheet metal around that time
ANTI-STRETCH NAZI
