Old 02-24-2012, 12:29 AM   #1
2legit2quitt
2legit2quitt's Avatar
2legit2quitt is an unknown quantity at this point
Send a message via Yahoo to 2legit2quitt
s13 S13 rack n pinion/inner tie rod
hello guys, a few days ago i put my car up on a lift and took a look at my rack and pinion. First of all the reason i did this is because sometimes as i brake i hear a pop/knock. As i lifted the car and took a look i saw that both booths on both left and right side are ripped and power steering fluid is leaking. My QUESTION is do i have to replace the whole rack and pinion or i can just order some new bushing, inner tie rods, and 2 rubber booths for both left and right side? suggestions/help will be very much appreciated!
'89 sr20 hatch-sold
2legit2quitt is offline   Reply With Quote
Old 02-24-2012, 01:06 AM   #2
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
If fluid is leaking from the rack and pinion seals then the rack will need to be rebuilt or replaced.
Also these cars use auto trans fluid as power steering fluid.
az_240 is offline   Reply With Quote
Old 02-24-2012, 01:27 AM   #3
mitcheyismyname
mitcheyismyname is an unknown quantity at this point
when you brake, do you also feel a slight or severe jerk in the steering wheel?
cuz i have the same problem, but ive replaced my rack and the problem still persist. my friend narrowed it down to my coilover strut being bad.
mitcheyismyname is offline   Reply With Quote
Old 02-24-2012, 01:30 AM   #4
2legit2quitt
yes i do! wheel jerks to the right and i hear a pop/knock as well sometimes when braking.
'89 sr20 hatch-sold
Old 02-24-2012, 01:32 AM   #5
2legit2quitt
dang lol these things are sort of expensive ill try to rebuild. its leaking from the rubber booths because they are ripped, thats why i was asking if i can just get new rubber booths and replace my bushings and inner tie rods, but i guess i need a whole new rack and pinion
'89 sr20 hatch-sold
Old 02-24-2012, 01:44 AM   #6
az_240
az_240's Avatar
Trader Rating: (41)
The rubber boots are not designed to hold the fluid..... They are just there to keep dust out.
The seals inside the rack are what you need to replace.... it's not an easy job from what I hear. Most people take it to a shop or buy reman.
Old 02-24-2012, 02:12 AM   #7
2legit2quitt
I guess it's time for a new rack then lol
'89 sr20 hatch-sold
Old 02-25-2012, 09:19 AM   #8
dawnattack
dawnattack's Avatar
dawnattack is an unknown quantity at this point
not necessarily new...you can get a rebuilt one...i got mine for less than a brand new one and looks and performs as new.
dawnattack is offline   Reply With Quote
Old 02-27-2012, 10:16 PM   #9
240sohc
240sohc's Avatar
240sohc is an unknown quantity at this point
rack & pinion
I recently replaced my original rack & pinion due to the same issues as yours. I bought a remanufactured one from summitracing.com for $193 plus core charge of $75.00(refundable with return of old rack). The unit came freshly painted with new seals, o-rings, inner tie rods, boots and warranty. I also replaced the power steering pressure line(autozone $75) and return hose as recommended.
or you can get a rebuild kit for around $70 from autozone.
240sohc is offline   Reply With Quote
Old 02-29-2012, 10:56 AM   #10
mr.man.performance
mr.man.performance's Avatar
mr.man.performance is an unknown quantity at this point
Are you sure it's actually leaking fluid or if you're just seeing the inner tie rod's grease...
mr.man.performance is offline   Reply With Quote
Old 02-29-2012, 10:59 AM   #11
mr.man.performance
You can get everything separately if you want. I believe frsport and some other venders carry silicon boot replacements. Inner tie rods and a steering rack rebuild kit are easy to find.
Old 02-29-2012, 11:39 AM   #12
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
the popping noise you hear is not from steering components. check your strut rod bushings or heim joints, if you have heim joints, lubricate them with silicone based lubricants. also check the bolts that hold the strut rods under the radiator core support. when you buy a rebuilt rack and pinion, they usually come with new inner tie rods. if power steering fluid is not actually dripping on the ground from the rack seals, you might just need new boots.
rcdad123 is offline   Reply With Quote
inner tie rod, power steering, rack and pinion
