Old 03-01-2012, 07:20 AM   #1
hstylez
hstylez's Avatar
hstylez is on the path to ruinhstylez is on the path to ruin
PowerFC Turbo/Injector Downgrade Question
S14 SR which is currently tuned with a PowerFC D-Jetro (map sensor)for this setup:
GT2871R .86AR
850cc Injectors
Megan SS manifold
I'm switching to the following setup:
S15 Turbo
525cc Injectors (STI)
Stock Manifold
Obviously I will need a tune for this to run well after all the changes. My question is: do you think I can get the car running well enough to drive it(out of boost) to a tuner 100 miles away? If so, what values in the PowerFC can I adjust to correct the injector difference since that is my main concern.
7/6/12 Update: To anyone who ends up searching for this and is curious of the result, the injector scaling worked perfectly and the car runs fine. Simply all I did was scale the injectors based on the new size. New size is 525cc, stock is 370cc. Divide 370 by 525 and you get ~71%. That is the value I used on the PowerFC and the car is running great. Heading to the tuner this weekend for fine tuning.
S13 Coupe SR20DET
hstylez is offline   Reply With Quote
Old 03-01-2012, 07:34 AM   #2
Croustibat
You can, but this requires a wideband lambda sensor. You could just try multiplying injection time by 2, it will be safe. They may have similar latency, but if it bogs down on idle try changing the latency to a lower value.
I dont know how you do that on a powerFc though.
Old 03-01-2012, 07:42 AM   #3
hstylez
hstylez's Avatar
Thanks for the reply. Fortunately I do have a wideband sensor. I was told there is a 'injector scaling' on the powerfc which sounds like it would accomplish what you suggested.
S13 Coupe SR20DET
Old 03-01-2012, 09:42 AM   #4
rellik27
rellik27 is an unknown quantity at this point
May I ask why you are downgrading? also you can try finding an s15 power fc stock settings to match it up. Im runnning a d jetro also on an s14sr with stock almost everything lol.
rellik27 is offline   Reply With Quote
Old 03-01-2012, 04:11 PM   #5
Croustibat
It will be easy then. If you see you are going leaner than 15/15.5 on cruise, enrich a bit. You need to be in the 12 or lower when booting it. Idle ... it can be lean, like 15-16-17.
Your timing and fueling maps depend on engine load, running a smaller turbo will just prevent from using the "highest" part of the maps, so timing wont be a problem. You could pull 2° if you feel the need to be safer.
Old 03-01-2012, 05:29 PM   #6
hstylez
hstylez's Avatar
I'm building a track car and the output of the GT2871R is more than I need right now.
Excellent. Thanks for the info. So do I want to be under 15 while cruising? I suppose that's my main concern since it's 100miles basically all highway.
S13 Coupe SR20DET
Old 03-01-2012, 08:28 PM   #7
Blues13
Blues13 is an unknown quantity at this point
You can adjust the injector duty percentage on the Power FC commander or using Datalogit. It's under the settings. Just monitor the AFR if you can as mentioned and you should be fine off boost.
Blues13 is offline   Reply With Quote
Old 03-01-2012, 08:51 PM   #8
jspaeth
jspaeth's Avatar
You don't need Dataogit to do this, you can very easily do this from the commander under Settings\Injector
Daily driven
Old 03-01-2012, 10:54 PM   #9
Blues13
I know.. I said commander OR datalogit..
Old 03-02-2012, 04:31 AM   #10
Biggamehit
Biggamehit's Avatar
Biggamehit will become famous soon enoughBiggamehit will become famous soon enoughBiggamehit will become famous soon enough
Send a message via AIM to Biggamehit Send a message via MSN to Biggamehit Send a message via Yahoo to Biggamehit
you selling the injectors?
Facebook: Pink Ranger Drift
Biggamehit is offline   Reply With Quote
Old 03-02-2012, 06:23 AM   #11
jspaeth
jspaeth's Avatar
That is completely my fault, I apologize for not reading your response carefully enough!
Daily driven
Old 03-02-2012, 06:38 AM   #12
Croustibat
Depends on temp ... i mapped my engine to be at 14.5 / 15 on cruise and idle, and it works fine. Too rich is not good either, it washes out the top of the cylinders, resulting in cylinder wear at that place but not under. If you even have an egt gauge it is even better. Or you can monitor oil temp/water temp... if it rises too much, go a bit richer. If you cruise at 15:1 it should not be a problem though. Just dont drive at 120mph
Old 03-02-2012, 07:05 PM   #13
jspaeth
jspaeth's Avatar
I have my AFR's setup to be in the 15.5-16.0 range under vacuum (enough vacuum to cruise at 75-80 in 5th gear without accelerating) then tapering down to 13.5 or 14.0 at 0 boost.........works really well, I get awesome gas mileage and never any knock.
Don't have an EGT gauge but can't imagine that this is a problem at all
Daily driven
Old 03-02-2012, 08:38 PM   #14
Kingtal0n
Kingtal0n's Avatar
The factory has the A/F drop to around 12.5:1 (3" Hg) before boost. Just sayin'
Old 03-03-2012, 10:12 AM   #15
inopsey
the factory ecu also runs 10.1 or richer on 13 psi and holds that afr from the second it makes boost. everyone knows factory ecus are very safe and designed to be reliable for 99% of the factory engines at the cost of peak power.
Old 03-03-2012, 12:00 PM   #16
Kingtal0n
Kingtal0n's Avatar
Yeah, whats wrong with that? How much power do we lose for that safety? I am not saying dump 10:1 at 13psi- but a little safety net during spool is not a bad thing.
Old 03-03-2012, 02:33 PM   #17
jspaeth
jspaeth's Avatar
I agree with the safety net thing, but I don't thing 13.5 is an issue at 0 bosot. I've never once gotten ANY knock.....then again, maybe my timing at that level of manifold pressure is very conservative....?
Daily driven
Old 03-04-2012, 10:34 AM   #18
Kingtal0n
Kingtal0n's Avatar
Oh no, I never said you were wrong or indicated any argument. You can get away with 14.2 usually even at 7psi even on a stock T-25 as long as you at least have some plumbing length, like with a side mount. SR20 engines are very tolerable of a wide range of operating conditions. But conditions change, it gets hot sometimes, going up hill, in fifth gear, and we hit those load conditions as "going into boost" which translates to "spool time" where the subtle lack of fuel rears it's head as a cylinder pressure spike eats away at your internals perhaps without registering any knock.
I was just pointing out a margin of safety- something that we like to keep as large as possible, right?- that is nearly free to own (nearly: you DO pay for the extra fuel). Not many margins of safety are free, for instance forged pistons are added to an engine to increase safety margin sometimes at the cost of performance). But they are far from "free".
Old 03-04-2012, 04:28 PM   #19
jspaeth
jspaeth's Avatar
Yeah, that is all correct.
now, in a completely unrelated side story, my AFRs for boost >14 psi are literally in the low 10s.
now THAT has gotta be costing me something, right?
Still haven't gotten around to bringing them more into the 11.5 range
Daily driven
Old 03-04-2012, 07:20 PM   #20
hstylez
hstylez's Avatar
Is the fact that I'm going from a tubular SS manifold to stock a cause for concern? If I was running a MAF I wouldn't be concerned at all however I'm running the Power FC with the MAP setup..
S13 Coupe SR20DET
