#2372 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
![]() Quote:
I'd personally sell the Expreme, and go back to stock with the wastegate welded on, and have it all extrude honed...you'd make out even and have the better manifold then as well. I'd be afraid of the Expreme cracking with the additional modification and weight hanging on it (as they crack as it is). You won't need clocking plates, but you will need to fab a way to keep the flapper shut (tack welding the back side of it, or fabbing a bar to keep it shut like the Suby guys do. And JWT S3 cams are the only way to fly if you want to make power, and retain OEM reliability.
#2373 | |
![]() Join Date: Sep 2011
![]() Feedback Score: 10 reviews
#2374 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
^I've done some searching about the isis z32 maf, and I've come across a couple people who had problems with it. Enjuku took care of them, and had them replaced. I came across a thread where Cody compared it to any other reman part from a auto part store. I don't know if that helps you any, but there you go lol.
#2377 | |
Trader Rating: (58)
Pretty is what it is. I prefer performance. The HKS stuff will work, but it will be finnicky after a while. Again my car sees as much track time as street time, so maybe my expectations for parts are higher. Nothing is more frustrating about parts to me is that you spend your hard earned money on them to be more reliable, and then when you spend money on track time and they fail...I instantly get pissed off. ISIS Maf's are (as Di-Devol pointed out) no different than any other parts store remanned unit. Some will work, some won't. It's the risk you take with it. If I'm paying 10 dollars for a steak, I don't expect it to be world class, but I also won't bitch about it if it doesn't taste like a 30 dollar one ya know? Profect B Spec II will work fine. Just follow the guide on EvoM on how to set it up.
#2378 | |
Trader Rating: (58)
JordanInnovations 240sxMotoring Leftfeed Performance etc etc.
#2379 | |
![]() Join Date: Jun 2011
#2380 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Monday i drop her off at DriftSpeed in LA for Koji to work his magic. Parts list- OEM conrod and main bearings with WCP coating OEM Thrust bearings *IF needed-CP pistons with top and side coating OEM master gasket kit. ProFab intake gasket 7-layer exhaust gasket Apexi metal HG Apexi AVCR (got a screaming deal on a bnib black edition) ARP headstuds Brand new AAC valve Brand new Water pump RPS CYN-R-G flywheel Competition Stage 4 sprung clutch kit Nismo 740cc injectors Circuit Sports engine mounts Nismo tranny mount GlowShift boost and EGT gauge JWT S3 cams Tomei Rocker arm stoppers And thats basically it. Still don't know if I want to be a ricer and route my external dump tube through my hood lol. After all is said and done I want to set the gt2871 to 20psi and see what happens. But in the end I might go with 18psi for longevity. All i want is a solid 380-400rw. Wish me luck!
IG/TikTok-ThatS14_Z06guy |
#2381 |
asking a stupid question and Just making absolutely sure before i order it, this is the .64 2871 where talking about rite?:
Garrett GT2871R-15 Turbocharger - Enjuku Racing Parts, LLC |
#2382 | |
Garrett GT2871R Turbocharger - Enjuku Racing Parts, LLC |
#2385 |
![]() Join Date: Aug 2010
Trader Rating: (25)
![]() Feedback Score: 25 reviews
what cam/valve spring combo is everyone using for this turbo?
i was thinking of tomei 256 poncams,bc valve springs and retainers. can i just use the stock valves and do a 5 angle valve job. or new valves? i'm looking for that sweet 350whp mark. current setup gt2871r .64 ar z32maf dw 810 inj. cosworth 1.2 headgasket hks ras acl mains,rod bearings arp mains and rod studs new oem oil pump,water pump and piston rings |
#2387 |
Since it is very hard to find pictures of anyone actually doing it, below is my installation of the .73AR T25-EWG-44 exhaust housing on a GT2871R, which allows for the use of a 44mm Tial wastegate.
PICS: ![]() ![]() ![]() ![]() ![]() Mod list: SR20DET #62 ECU previously flashed by Enthalpy (for now; Power FC or EMS Series 2 may be coming) Garrett GT2871R .73AR T25-EWG-44 housing All turbo hardware is stainless studs with copper lock nuts and nord lock washers Greddy tubular exhaust manifold, with 4 layers of ceramic coating Tial 44mm v-band external wastegate, 1.1 Bar, with custom dump tube Blitz i-sbc ID digital boost controller 7 layer exhaust gasket Circuit Sports braided turbo oil & coolant lines Splitfire coil packs Greddy/trust turbo elbow Greddy down pipe Invidia 3” full exhaust with Magnaflow 3” spun metallic catalytic converter, and extra 3” Magnaflow race muffler to quiet it down Greddy hot pipe Greddy front mount intercooler Greddy type RS blow off valve (Tial Q BOV already bought and to be installed next week with custom intercooler piping, HPS couplers and T-bolt clamps) BC264 12.0mm lift cams JWT cam gears Greddy valve springs Greddy/Trust rocker arm stoppers BC titanium valve spring retainers Wiseco 9:1 pistons, 86.5mm Eagle rods Wiseco pistons 9:1 compression ARP head studs Apexi 1.1 head gasket ACL race bearings New OEM timing set New OEM oil pump Circuit Sports oil block adapter 10AN Aeroquip oil lines to Offenhauser remote oil filter mount, Permacool 160 degree oil thermostat and CX Racing oil cooler Greddy oil pan Stance water pump pulley OEM Nissan water pump Samco silicone hoses Stance water neck spacer OEM Nissan thermostat Koyo race radiator Blitz radiator cap Circuit Sports coolant reservoir Dual electric Altima fans (DIF controller yet to be installed) Stock SR20DET S13 intake manifold, S13 throttle body (soon to install a 75mm TB and S14 TPS) Z32 N62 MAF Apexi Z32 suction kit Injector Dynamics 1000cc top feed high impedance fuel injectors HKS top feed fuel rail Aeromotive Fuel Pressure Regulator and -8 AN push lock lines Aeromotive -10 micron billet fuel filter Walbro 255LPH fuel pump A/C removed Rebuilt alternator RPS Max stage 3 clutch Nissan OEM clutch slave cylinder with braided stainless line B&M quick shifter Nismo rubber shift knob 1 piece aluminum lightened driveshaft Nismo motor mounts Impressions: The installation of the T25-EWG-44 did not allow enough space to mount the Tial MV-R waste gate directly on the turbo housing, so my mechanic fabricated a 90 degree elbow (like what ATP sells) to mount the Tail vertically below the brake master cylinder. He then custom fabricated a dump tube down inbetween the bell housing and firewall. Overall the installation turned out very clean. The Greddy tubular exhaust manifold with 4 coats of ceramic coating turned out fantastic. It is a very stout manifold compared to everything else I have seen. Driving impresson? Man that waste gate dump tube is obnoxiously loud ![]() So far I haven't been able to get an Enthalpy tune that will work on the car. It runs rich at idle (11.5-12:1 AFR), no load going through the gears 14.7:1, on boost around 13.4:1 range, which means I have to be disciplined to stay out of boost. I am installing a new Aeromotive 340lph Stealth pump tomorrow and a 60 amp relay direct to the trunk/hatch mounted Odyssey PC925 battery. It appears to be more laggy than the previous .64AR setup, but I think it is possibly because it is slightly lean and not getting enough fuel to spool to full boost in the 3.5K RPM-4K RPM range (It won’t hit full boost until 4K, which is too late). I also suspect that maybe the 1.1Bar waste gate spring is too high and I should lower it, which would let my boost controller to more of the work. Since I have had trouble getting a ROM tune to work, I have been thinking that I will have to either go with an AEM EMS Series 2 standalone or an Apexi Power FC D-Jetro. Several pro-am drifters locally have had issues with the EMS rev lifter causing displaced rocker arms or shims, when it has never happened with a Power FC. Thus, my mechanic is currently suggesting that the Power FC is a good option. I will be doing whatever it takes to tune the car will be tuned properly, within the next week or two max. |
#2389 |
yes, the MV-R clears the brake master cylinder by probably a half an inch I think. I will have to take better pictures.
PSI in Portland will be doing the tuning by the way, so I will probably be down in your neck of the woods quite soon. Garage Autohero did all the work. |
#2390 | |||
Trader Rating: (58)
The difference in .64 housing cars to .86 is night and day...and I can see the ATP housing being similar. It's possible, but unlikely. Tial gates aren't very 'lazy' and usually begin to open only slightly before their spring pressure is reached. Again this would be a stretch more than anything. Usually you fight issues like that with smaller springs, not the larger ones.
#2391 | |
-Tim |
#2392 | |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
#2393 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
I had a rocker jump off at about 5k rpm. Had my PFC D-jet set to about 7k and had tomei RAS installed. So it can happen with the PFCs.
This was on my 2871R setup also.
#2394 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
#2395 |
I tried 12 pulls on the DynoJet (75 degF ambient temp, ~15% RH) and got the same results each time. How/why is the torque so high? (TQ number seems ridiculously high!) Why does the power and torque dip down? Can you guys help me figure out what's going on here?
**I appologize for the crappy pic!** ![]() This is an S15 SR with an S13 Enthalpy tune for a Z32 MAF, HKS 264/264 cams (no more VTC), 830CC Douchewerks injectors, and a 2871R .64. The engine CP pistons with the stock compression ratio. Stock intake and exhaust manifolds, stock S13 coils, and stock S13 throttle body. The plugs are just cheap Denso's for a Z32. The AFR held at 10.2 on their sniffer, but 10.8 on my AEM. The boost spiked at around 24psi, and I'm not sure if it's the crappy manual boost controller or the turbo that causes it to drop back down to 18psi and hold there. My boost gauge was on par with theirs. Also, does peak boost at 4.5K RPM look right? |
#2396 |
Anyone have any insight to share on the FRSport internal wastegates? My stock wastegate finally gave up the ghost on my GT2871 and I'm considering all my options.
'89 hatch DD'd SR'd 2871'd - Sold 2006 Legacy GT Wagon |
#2397 | |
#2398 |
![]() Join Date: Feb 2011
Ugh, went to the track Sunday to get one more time on my stock turbo before I dropped the 2871 in, and I snapped the output shaft on my trans during my first burnout. I don't get what happened, my tires were still spinning pretty good. So now I have to get a new trans. Also getting a new clutch, fuck this spec garbage.
#2400 | |
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
And yea get rid of the spec. A brand I really like is DVD racing clutches. They also go by southbend clutches. I think I got the stage 3. |
