Old 03-13-2012, 02:34 PM   #1
ViciousCesar!
ViciousCesar!'s Avatar
ViciousCesar! is an unknown quantity at this point
Thumbs down Failed Smog test (high HC, CO, and NOx)
I took my car to get smogged and it failed miserably.
Here's what it read...
Car: 1990 stock KA24e 240sx
15mph:
HC max: 85 , measured: 101
CO max: .54 , measured: .75
NO max: 565 , measured: 655
25mph
HC max: 67 , measured: 104
CO max: .45 , measured: 1.43
NO max: 522 , measured: 690
So those were the numbers, can anyone point me in the right direction just by reading that?
Any and all help is appreciated.
ViciousCesar! is offline   Reply With Quote
Old 03-13-2012, 03:33 PM   #2
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
That wasn't a miserable fail haha.
What's the condition of the catalytic converter? Are there any leaks in your exhaust system? Any aftermarket exhaust components or engine modifications. Any check engine light codes? When did you smog it last? Did it pass then? Do you know the numbers for that run as well?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 03-13-2012, 03:46 PM   #3
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Yeah those numbers are not that bad, Mine where crazy high that they put the sniffer on and right away the guy told me NOPE!!!! that he wouldnt even take the car in so I checked all the smog parts and cleaned them good and i also had a bad injector too, which was part of the problem and i had a couple of cloged parts that where not working right.
andisan is offline   Reply With Quote
Old 03-13-2012, 03:50 PM   #4
Pandadub92
Pandadub92's Avatar
Pandadub92 is an unknown quantity at this point
smogged my single cam and it barely passed but it had 260K on it and the original cat and exhaust. i just made sure i changed my filter, oil, my plugs, cap and rotor and it seemed to help it pass. still a weak cat tho
Pandadub92 is offline   Reply With Quote
Old 03-13-2012, 03:58 PM   #5
Pandadub92
Pandadub92's Avatar
1989 stock KA24E S13
15mph:
HC max: 83 , measured: 83
CO max: .53 , measured: .27
NO max: 559 , measured: 231
25mph
HC max: 65 , measured: 65
CO max: .44 , measured: 30
NO max: 516 , measured: 435
Old 03-13-2012, 04:14 PM   #6
ViciousCesar!
No engine mods or aftermarket exhaust components. The cat seems to have been replaced by the previous owner when he replaced the original exhaust. The car passed smog since then (about 19 months ago). There is a leak at the gasket to the cat from scrapping. Check engine light is not on. I don't have the numbers freom the last test on hand.
Old 05-07-2012, 02:20 AM   #7
Zed Nismo
Zed Nismo's Avatar
Zed Nismo is an unknown quantity at this point
I would suggest fixing the leak at the cat and also make sure you have the heat shield on the exhaust manifold and the mid pipe going to the cat (Mid pipe heat shield has a fiberglass insulation in the middle). The heat has to be contained all the way to the catalytic converter for the converter to do it's job properly. That's why the heat shields were there in the first place as well. That helped me pass with no problems. I had a worst failure, went to smog 4 times before it actually passed.
Zed Nismo is offline   Reply With Quote
Old 05-07-2012, 06:53 AM   #8
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
I would suggest paying someone under the table to pass smog! What's the going rate like 140 or so?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 05-07-2012, 08:41 AM   #9
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Illegal smog is not going to work in California for much longer...
We need to just get the cars to pass correctly now...
If there is no CEL and all leaks are fixed, I would consider changing the catalytic converter and spark plugs for a total of about $150... And try testing again... I'm pretty sure that it will be enough...
In California this year, they have added more restrictions to get older cars off the road... It's getting more and more strict...
Nikeboy355 is offline   Reply With Quote
Old 05-07-2012, 10:10 PM   #10
bladetech8
bladetech8's Avatar
Trader Rating: (32)
bladetech8 is an unknown quantity at this point
Feedback Score: 32 reviews
^ I beg to differ.. If I'm waving $250+ in front of some smog dude's face, I'll be hard pressed to think he won't do anything but guarantee to pass me regardless of what bureaucratic bullshit is going on with the California BAR or EPA.. Money speaks and some things are just worth the calculated risk..
bladetech8 is offline   Reply With Quote
Old 05-08-2012, 05:48 AM   #11
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
i dont think your sposta tell people to break the law on here.
Plus if its stock it should pass anyway, try seafoam, it helps clean out the egr and iacv unless you want to pull them off and actually clean them.
Are you sure there's actually a cat in there? i see alot of hollowed out ones..
maybe clean the 02, make sure its super hot before you test it. i had to get a new cat for mine back when it was stock and it passed
best of luck man!
Tantwoforty is offline   Reply With Quote
Old 05-08-2012, 06:30 PM   #12
bladetech8
bladetech8's Avatar
Trader Rating: (32)
lol I believe we're all breaking the LAW in one way or another, driving modified 240's on a daily basis. Being low is technically illegal, but no one's fussing around in the "how to make your car scraping low" threads
But yeah smog stuff is kinda iffy or what not, so that conversation ends here.
Old 05-08-2012, 10:50 PM   #13
godrifttoday
Trader Rating: (82)
damm u pay 250? thats a grip...
Old 05-09-2012, 01:40 PM   #14
bladetech8
bladetech8's Avatar
Trader Rating: (32)
haha not really. It was just an exaggeration to make a point..
