Old 03-13-2012, 05:36 PM   #1
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
KA kade cam combo selections
sup guys..lookion to see what stock cam combo are guys runnin..right now im rockin 248x232 on my s14,which has a nice lil pull to redline.i tried the famous 248x248 set up but it drags ass,seems like the accel dies off compared to the stock 232x232..both 248x2 and 248x232 set-up has a sexy ass idle lope though..i did try yesterday 232x248 set up which has a stock feel to it but seemed to me the accel was insane compared to the other set ups i tried..so post what u guys think..
project-D180 is offline   Reply With Quote
Old 03-13-2012, 07:38 PM   #2
whitenoise
whitenoise's Avatar
whitenoise is an unknown quantity at this point
Send a message via AIM to whitenoise
98 s14
im running 248 in 248 ex with the intake advanced 5 degrees
N/A impression: pulls hard like the 232/232 stock plus keeps going to redline up power wise to redline 6800. dynoed 141 whp/146 wtq with intake , header, 2.5 catback exhaust and high flow cat.
turbo impression: s14 t28, 550cc, z32 MAF enthalpy tune. little to no lag . just need to learn to shift precisely and quickly since u redline lightning fast . not dynoed yet.
no lopey idle . idles like stock idle should.
http://TM-SPL.COM
whitenoise is offline   Reply With Quote
Old 03-13-2012, 08:55 PM   #3
project-D180
advance..so that adjusting it clockwise correct...?
Old 03-13-2012, 08:56 PM   #4
project-D180
and the exhaust cam in stock position
Old 03-13-2012, 09:01 PM   #5
whitenoise
whitenoise's Avatar
i based it on this
http://jimwolftechnology.com/wolfpdf...STRUCTIONS.PDF
http://TM-SPL.COM
Old 03-14-2012, 01:52 AM   #6
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
I'm going to he doing the 240/232 Setup this weekend. Currently running the Stock 232/232 in my 95.
Other mods are:
N60 on Neo Tuned on the Road for 12.5-12.7 Steady from 2-6.4k.
Full 3" From Header Back (Test-Pipe)
2.75" CAI w/ 3" Ext.
No Dyno Numbers yet
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 03-14-2012, 05:53 AM   #7
project-D180
do u have jwt cam gears or redrilled yours?
Old 03-14-2012, 05:55 AM   #8
project-D180
how many teeth did you move it,i dont get how u can advance the cam on a ka jus by movin the gear by itself with timing chains...now advancing the cam n gear as one i understand but jus t the gear by itself im a lil lost so help me out a lil...lol
Old 03-14-2012, 07:21 AM   #9
tuktuk23
tuktuk23 is an unknown quantity at this point
Originally Posted by whitenoise View Post
nice link bro
tuktuk23 is offline   Reply With Quote
Old 03-14-2012, 08:29 PM   #10
KA240SX808
KA240SX808's Avatar
Read the JWT Link and you'll understand.
Old 03-15-2012, 07:39 AM   #11
project-D180
i got it set up like the link suggested an wow..the cams came alive compared to before,the pull is straight to redline which is nice..like to try this set up on a high comp motor ...any one else rockin somethin different that likes the out come??
Old 03-15-2012, 07:54 AM   #12
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
didn't search did you?
This is my friends set-up:
SOHC pistons
Cometic HG for 10.7:1 compression
248/248 Intake/Exhaust cams
Head port and polished with stock intake and z32 Ferrera valves (about 2mm bigger than stock)
both the block and head were deburred to remove hot spots
clevite rod cap bearings with ARP hardware
new OEM waterpump and oil pump gear
EGR capped
Swirl Control removed
Coolant to TB capped
RSR 3" Catback
New O2 and Temperature sensors
everything else stock, auto ECU
motor has excellent throttle response and is a blast to drive.
we took it to the dyno last night and frankly were a little disappointed
car feels faster than what the numbers state
we are, however, pleased with the shape of the powerband curve
read the rest of the thread while you're at it:
http://zilvia.net/f/engine-tech/91288-na-ka-faq.html
Old 03-15-2012, 08:03 AM   #13
project-D180
im talkin somethin higher than 10, like 11. n 12 cr on pump gas,n some real pistons not sohc cast.. dont give me that bull sayin u need race gass for 11 or 12cr,for one my 13 i had i ran 92,93 on je 11,0,1 pistons with no issues or det and 2 hondas run on pump with these cr all the time
Old 03-15-2012, 08:06 AM   #14
project-D180
anyway i jus wanna see what stock cam combo's people was doin n to see how they liked it
Old 03-15-2012, 08:25 AM   #15
Chaluska
...english much? or... punctuation much?
Old 03-15-2012, 08:54 AM   #16
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
where the hell on your original post did you specify a compression ratio?
but what's the point, seeing as you didn't even know about the timing change needed to make 248 cams work
I doubt this thread will be anything other than just forum clutter
compression is compression, what the hell do the piston type has to do with anything if they withstand the use intended?
the motor above was put together by a friend
SOHC piston compression was actually higher (the head was piruated) and the headgasket thickness chosen to keep the compression under 11.
Reason was because the motor was built to use pump gas and to test a few ideas about NA KAs we had.
you build something worthwhile to justify your shitty attitude and we can talk
but as it stands you just come across as a typical zilvia dumbass
good luck with your phantom build
Old 03-23-2012, 01:16 PM   #17
project-D180
u got it big dog
Old 03-23-2012, 01:21 PM   #18
project-D180
if u read the na section u would see that i had dyno #'s from my last na build makin 183 with a shitty tune n not dailing in the 264's i had bro..nate1 can also comment on that
Old 03-29-2012, 04:38 PM   #19
KA240SX808
KA240SX808's Avatar
I'm now running the 240/232 in my 14.
Powerband feels the same but I can feel a slight increase in power/pull. Its a Tad bit more peppy but nothing extravagant.
No bottom end loss or top end gain. Just a nice little what's feels like an increase throughout the entire powerband.
Sadly no dyno plot to back up these findings. But the butt dyno does approve.
Old 03-29-2012, 04:47 PM   #20
project-D180
niice..right now im on 248x248 set up. tryin to play around with the degree of the cams..i had it where idle was like stock,it felt a lil peppy nothin like stock..now i have it set up where it idle a lil like/sounds like a subie/muscle n it feels like it has waay more pull to it,nothin crazy..but im definitly thinkin of goin back to 232/248 set up i had before,waAy more response than my current n stock setup
Old 03-29-2012, 05:17 PM   #21
808drft
808drft is an unknown quantity at this point
I have mine set up as 248 (+5) x 248 (+2.5) havent dynoed yet but feels way better than my previous 248 (+5) x 248 (-2.5). On my previous I made 137hp and 140tq with basic bolt-ons. With the exhaust set as 2.5 advance mid range tq is awesome! Pulls from ~3.5k to ~6.5k then starts to die off.
808drft is offline   Reply With Quote
Old 09-29-2012, 08:50 PM   #22
project-D180
back from the dead..(zombie life)..anyone else out there playin with stock cams or after market cams?
Old 10-24-2012, 07:56 AM   #23
project-D180
no one else wants to chime in?
Old 11-29-2012, 09:30 AM   #24
Alpha1
Alpha1 is an unknown quantity at this point
Running a S14 KA im going to be messing around with my cams in a few weeks i been searching for some combos and i have read good things about 248/232, now im seeing your doing 232/248 so i might try out both and see what i like
Alpha1 is offline   Reply With Quote
