Old 03-17-2012, 12:47 PM   #1
mdlesk
mdlesk is an unknown quantity at this point
S14 Parts :: Mostly OEM
I have tons of parts for sale from my '95 240. Most of these are OEM and some are aftermarket. Please see the pictures for the items. All prices are OBO
A couple of notes:
Xcessive Intake Manifold comes with Q45 MAF and KA Throttle Cable bracket. It was mounted and started once. Decided to remove it and put OEM manifold back on due to tuning issues I was experiencing.
Can't really see in the pics, but I have the S14 front bumbper support brace for sale.
I have the complete S14 Seatbelts; however, the driverside is frayed.
I was told the Catalytic converter is gutted
The exhaust manifold still have the EGR attached
One of the Steering racks has a leak. It would need to be rebuilt. I have a second one that I was told was good.
Aftermarket exhaust is the M2
Rear bumper is bent in a little at the flange (passenger side)
Also have the MRT Exhaust for the 2005+ Ford Mustang and Pacesetter exhaust for VW Jetta (86-??? model)
One of the tires has a slight leak. The wheels are 4-Lug pattern
Power window amp may not work
Fan shroud is broke so I will probably just throw it away.
Radiator was good when removed, I swapped out for an aftermarked one with dual fans
Oil pan was fine when removed. I bought one with a bung already welded on. Does not come with drain plug
Downpipe is ISIS SR20 SS one. It has the AEM No-Weld 02 Bung. The gasket for the No-Weld should be replaced.
Have 4 full sets of injectors for sale: KA stock, SR20 stock, 660 CC (forget brand), and ID1000's, The 660's and ID1000's were never used.
Complete airbag system available. Harness has been de-pinned. Steering wheel and passenger air bag not pictured.
Power Steering Pump is sold as is, not sure if it works or not
Feel free to ask any questions, make any offers, and request any parts. I may have it available.
All pics can be found here:
Index of /sale-items
Edit: Item List:
Oil Pan - $60 shipped
S14 Steering Rack (2 Available) - $75 Shipped for one that leaks, $125 shipped for good one
M2 Cat-Back Exhaust - $40 - Local Pickup Only
Gutted Catalytic Converter - $50 Shipped
S14 OEM Wheels / Tires - $75 - Local Pickup Only
OEM Rear Bumper - $50 - Local Pickup Only
ISIS SR20 Downpipe w./ AEM No Weld O2 Bung - $75 Shipped
Xcessive KA24DE Intake Manifold w./ KA Throttle Cable Bracket & Q45 Throttle Body - $450 Shipped
3rd Brake Light - $30 Shipped
Headlights - Sold
Corner Lights - Sold
Passenger Side Markers - $15 Shipped
OEM Radiator - $65 Shipped
OEM Cooling Fan - $50 Shipped
OEM Engine Fan - $50 Shipped
(4) KA24DE Injector Clips (1 has less than 1 inch of wire) - $7.00 Shipped
S14 Seat Belts (Front & Rear) :: Driver's side is frayed - $125 Shipped for all
Windshield Washer Reservoir - $30 Shipped
Coolant Overflow Reservoir - $30 Shipped
USDM Manual Climate Control - $40 Shipped
Misc Empty Blank Covers for Switch Panels (Cruise Control, Security, etc) - $5 Shipped Each
Soundstream DTR4.500 Amplifier - $75 Shipped
Complete Airbag system (Harness is depinned) - $100 - Local Pickup Only
Several S14 DCC Sensors - $15 Shipped per Sensor
S13 Dash Harness - $30 Shipped
Generic Coolant Overflow Tank - $10 Shipped
Stock KA24DE Injectors - $45 Shipped
Stock SR20 Injectors - Sold
Precision 687cc Top Feed Injectors - $200 Shipped
Injector Dynamics ID1000 Top Feed Injectors - $350 Shipped
OEM Fuel Pump - $50 Shipped
OEM Fuel Filter - $20 Shipped
Misc 6.5" Speakers - $15 Shipped Each
Air Filters - $14 Shipped Each
Aftermarket KA24DE Intake - $35 Shipped
Stock Air Box (Behind Bumper) - Sold
Hazards & Rear Defogger Buttons - $25 Shipped Each
Power Steering Lines - $60 Shipped for the set
Stock KA24DE MAF - $40 Shipped
Stock Motor Mount Brackets - $50 Shipped
Stock Power Steering Pump (Unsure if it works) - $25 Shipped
Apexi SR20 Intake Pipe - $60 Shipped
KA24DE Stock Downpipe - $80 Shipped
Stock Exhaust Manifold with EGR Attached - $35, Local Pickup Only
Stock 3 Piece Taillight set - $75 Shipped
Misc Silicon Couplers - $5 Shipped Each
Exhaust Manifold Heatshield - $15 Shipped
S14 Front Bumper Support - $50, Local Pickup Only
95 Drivers Side Window Switch - Sold
Power Window Amp - Sold
DSM Shift Knob - $15 Shipped
Stock Shifter - $35 Shipped
Stock Shift Knob - $15 Shipped
Stock Zenki Grille - $35 Shipped
(2) Crossovers for speakers / tweeters - $30 Shipped
Stock Shifter bezel (Boot needs replaced, no broken tabs on bezel) - $15 Shipped
TVG Logo Valve stem caps - $10 Shipped
Shine Auto Project Rear Valances - $75 Shipped
mdlesk is offline   Reply With Quote
Old 03-17-2012, 12:57 PM   #2
apexhumper
apexhumper's Avatar
apexhumper is on a distinguished road
Is any of the front end stuff available? headlights, turn signal, cornerlight etc
Dont sweat the petty things, pet the sweaty things.
apexhumper is offline   Reply With Quote
Old 03-17-2012, 01:11 PM   #3
mdlesk
Yes, I have the OEM headlights, corners, side markers, and should also have the turn signals. All are USDM. The headlights are a little yellowish and need cleaned. See the pics link in the first post. There are some pics of the lights and bulbs.
Old 03-17-2012, 01:16 PM   #4
Detroit.Tee.Tee
Detroit.Tee.Tee's Avatar
Detroit.Tee.Tee is an unknown quantity at this point
I have a 40m/bit connection and those pictures take a while to load. Holy GIANT pictures.
I am interested in a few items. I'll pop you a PM after I look at everything. With the size of those pics, It might be a while.
Detroit.Tee.Tee is offline   Reply With Quote
Old 03-17-2012, 01:19 PM   #5
Detroit.Tee.Tee
Sent you a PM. Didn't realize it was over 5 hours one-way.
Old 03-17-2012, 01:35 PM   #6
mdlesk
Yeah, it's pretty far. I can ship the smaller items, just don't really want to ship the exhaust, bumper support, bumper, exhaust manifold, etc.
I have added a resized folder: Index of /sale-items/resized
Pics in this folder should be quite smaller and load a lot quicker.
Old 03-17-2012, 01:36 PM   #7
Sidewayz silvia
Sidewayz silvia's Avatar
Sidewayz silvia is an unknown quantity at this point
How much for the window switches... do you have both driver and passenger
Sidewayz silvia is offline   Reply With Quote
Old 03-17-2012, 01:38 PM   #8
mdlesk
I only have the drivers side, not sure if it works, seems like the auto-stop is broke as it just moves freely. I can do $20 shipped for it. I also have the power window amp that I will throw in for another $10.
Old 03-17-2012, 01:46 PM   #9
apexhumper
apexhumper's Avatar
I need both headlights, the drivers corner light, turn signal and side marker, how much shipped to 91001?
Old 03-17-2012, 02:08 PM   #10
mdlesk
PM Sent. Headlights and Corners have been sold.
Old 03-17-2012, 06:30 PM   #11
mdlesk
First post updated with actual item list
Old 03-17-2012, 06:59 PM   #12
squarepegs
squarepegs is an unknown quantity at this point
Do you have an OBD2 dash harness by chance?
squarepegs is offline   Reply With Quote
Old 03-17-2012, 07:04 PM   #13
mdlesk
Nope, I have an S13 one, but not an OBDII. My 95 was OBDI and I retained the stock harness
Old 03-17-2012, 07:17 PM   #14
S14TEENZ
S14TEENZ's Avatar
S14TEENZ is an unknown quantity at this point
Front seat belt buckles in black shipped?
S14TEENZ is offline   Reply With Quote
Old 03-18-2012, 12:16 AM   #15
SaVAgES14
SaVAgES14 is an unknown quantity at this point
How much for the stock air box?
SaVAgES14 is offline   Reply With Quote
Old 03-18-2012, 12:33 AM   #16
Kom3t
Kom3t's Avatar
Kom3t is an unknown quantity at this point
Do u have front passenger seat?
Kom3t is offline   Reply With Quote
Old 03-18-2012, 06:53 AM   #17
mdlesk
No seats available
Old 03-18-2012, 07:03 AM   #18
Hughes
Hughes is an unknown quantity at this point
is the window switch driver or passenger side? also do you have the motor for the driver side? PM me plz
Hughes is offline   Reply With Quote
Old 03-18-2012, 09:08 AM   #19
j10oreo
j10oreo is an unknown quantity at this point
are you gutting out the interior??? if so do you have ashtray???
j10oreo is offline   Reply With Quote
Old 03-18-2012, 09:12 AM   #20
mdlesk
Not gutting the interior, just selling parts that are left over from my build. No ash tray available.
Old 03-18-2012, 12:05 PM   #21
william's'
william's''s Avatar
william's' is an unknown quantity at this point
how much for the side marker lights bulb sockets with some wire slack?
william's' is offline   Reply With Quote
Old 03-19-2012, 07:54 AM   #22
mdlesk
First post updated with prices. Please make some offers, need this stuff gone soon. I also tested the power window switch and it works, just missing the spring for the auto-up.
Old 03-20-2012, 10:49 PM   #23
Zeb
Zeb's Avatar
Zeb is an unknown quantity at this point
Hello,
I am interested in an egr tube for a ka24e as well as an intake boot if you have one. (between crossover tube and manifold) thanks
I have paypal ready for price shipped to 93103
Zeb is offline   Reply With Quote
Old 03-20-2012, 10:53 PM   #24
mmccall72
mmccall72's Avatar
mmccall72 is an unknown quantity at this point
got a m/t ecu and/or manual trans wiring harness?
mmccall72 is offline   Reply With Quote
Old 03-21-2012, 08:02 AM   #25
mdlesk
I don't have any parts for the KA-E; however, I do have quite a few Silicon Couplers. Do you know the inlet and outlet size that you need?
I don't have any m/t ecu or trans wiring available. I do have an auto ecu available. I will update the first post with it in a few hours along with the Part Number
Old 03-21-2012, 10:08 AM   #26
Zeb
Zeb's Avatar
Thanks anyway. Lookin for oem
Old 04-01-2012, 12:02 PM   #27
SaVAgES14
Where you at man? Trying to get that airbox.
Old 04-01-2012, 05:58 PM   #28
240zach
240zach's Avatar
240zach is an unknown quantity at this point
pm me pics of rear valences?
240zach is offline   Reply With Quote
Old 04-01-2012, 07:59 PM   #29
davisboy44
davisboy44 is an unknown quantity at this point
Got any pictures of the Xcessive intake?? there were none on your web page and i'm looking to see if it is the new style or old style from them
davisboy44 is offline   Reply With Quote
Old 04-01-2012, 08:05 PM   #30
mdlesk
Pics are there on website. They start @ #796. PM Me if you need pics of the runners.
