Old 03-24-2012, 01:06 AM   #1
ilovmy13
ilovmy13 is an unknown quantity at this point
sr20det SOLID LIFTER shimming problem
im having a problem. I have installed valve springs and tomei solid cams. I did the calculations with a feeler gauge, and the results ive gotten seem as if the valve are sitting to low. Most off the numbers i got are to high that tomei doesnt even make shims that large( above 3mm). I even put the stock shims (3mm) on top of the retainers and after installing the rocker and cam the rocker just can be moved around easily ( there is to much clearance between the cam and rocker). WHAT IS WRONG?!?!? is it the cams, the valves ?!?!?
ilovmy13 is offline   Reply With Quote
Old 03-28-2012, 06:20 AM   #2
ilovmy13
anyone any input
Old 03-31-2012, 08:54 PM   #3
jedi03
u try calling tomei yet?
Old 04-07-2012, 02:36 PM   #4
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
I had a similar problem a couple years ago. What happened with me is that the machine shop ground the top of the valves too much (they used 91 SE-R Specs) so it caused too much of a gap. If that's the case, you'll need new valves.
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 04-08-2012, 06:15 PM   #5
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
^^^^ what he just said is spot on.
I just had a customer with a similar situation,except machine shop xyz,sunk the hell out of his valves(cut seat toooo much) so his head was too tight. So i had to take it all apart & grind the stem tips & hand fit each valve!!!!
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 04-12-2012, 10:03 PM   #6
jilo
jilo's Avatar
jilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of light
i had this same problem and fixed it by cutting shims from feeler gauge and putting it under the sla in its bore. it just shims the sla up higher so you need a smaller shim. works fine for me, no problems at all.
"just throw in like 8 packs of BBs and do a burnout.
DIY shot peen, done and done."
jilo is offline   Reply With Quote
